Question about Dell Dimension 4600 PC Desktop
Dell pc turns its self off
Hi My dell 4600 keeps turning its self off after starting for aprox 10 min,i then turn off power for a while then it starts again for a short time before clicking its self off again. Have checked power leads and conections inside pc Fan seems to be working ok Any help would be grate , its done mi head in! ps when it stops power light changes from green to orange. kind regards stan
    Brigadier General:
  • Dell Master
  • 3,400 Answers
Your PCs energysystem are proberly made to save energy.this can be
changed in the contrlpanel loo under energyprofiles.
there of the change of powerlight colour.
Posted on Apr 22, 2013
Testimonial: "Thanks lars much better now"
  • Sandeep Kumar Oct 11, 2013
    Also check the power supply coming on motherboard through SMPS.
3 Suggested Answers
kornho
  • 781 Answers
SOURCE: Orange Light permanently on motherboard. PC won't start
1. motherboards for atx form factor pc's are powered even when the computer is off, particularly if you leave the computer plugged in to wall outlet... you better do not work on you computer while power cable is still connected to both, your pc and the wall outlet..
2. I found this thread that may be helpful, it may be the motherboard may have gone bad, cmos is corrupted or something may not be seated properly...it could also be one of these: Bad CPU, BAD ram, Bad power supply.. read the thread for details:
http://www.dellcommunity.com/supportforums/board/message?board.id=oplex_other&message.id=23925&c=us&l=en&cs=&s=gen
Posted on Sep 25, 2008
  • 85 Answers
SOURCE: dell dimension 5100, power button has turned orange
If under warranty contact Dell? I had this same problem, a new motherboard and fan assembly fixed this problem. Bad capacitors on the motherbard.
Posted on Apr 12, 2008
Why does my screen goes to sleep everytime I start my computer
Go into power options and turn off the fuctions for when the hard drive turnes off and when the monitor turns off, that should keep the computer from going to sleep.
Apr 21, 2010 | Dell Dimension 4600 PC Desktop
My dell dimension 4600 doesn't come on. When i press to on button I get an orange light on the power light ( left hand one ) then nothing happens. can you help
Possibly a faulty power supply?
Faulty Power cable?
Faulty Video Card?
Try replacing each of these in turn , remove all components and try to boot with the basics - 1 stick of memory, no drives, just video
Then add 1 drive
Then add another stick of memory
Keep going till you work out whats stopping it from starting.
Regards
1234s282
Apr 18, 2010 | Dell Dimension 4600 PC Desktop
My dell dimension 4600 won't boot up and when you try to turn it off with the button it just starts back up.
It sounds like a back-up was started and now your system is trying to complete the task before it shuts down. You can turn it off by holding the power button down for 10 seconds. This will cause the power supply to shut down completely. You will lose any unsaved data and it may corrupt your back-up.
Mar 25, 2010 | Dell Dimension 4600 PC Desktop
How do I restart a Dell Dimension 4600 PC Desktop
Hello gabeymybabey,
If the computer is using Windows XP, do the following to restart the system:
•Click the Start button
•Click Turn Off Computer.
•Cick Restart
The computer will restart after the shutdown process finishes.
Also, here's is a link to the Dell 4600 Series user guide:
http://support.dell.com/support/edocs/systems/dim4600/en/4600i/index.htm
If this solution is helpful please click 'YES' by 'Was this helpful?' below.
Have a great day,
martyshaw152
Jan 31, 2010 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600 will not reboot. I have to turn it off, unplug the power, push the On/off switch for a moment, let it set for 15 min then it will reboot. I have recently upgraded from 256kb ram to 1gb,...
from what you describe, they system will not shutdown. So try the following:
  1. Boot to safe mode (F8 at boot) and then see if the system will reboot from the safe mode.
  2. Boot to the Safe Mode again, Start RUN MSCONFIG, edit the startup group, (Basically uncheck all the items in the startup tab) reboot in the normal mode then see if it shutsdown. If it shutsdown normally, then start adding items back one at a time until you identify the items that were causing the items.
Jan 12, 2010 | Dell Dimension 4600 PC Desktop
How to soft boot a dell 4600
I used the reset button on my last one whenever ctrl/alt/del failed to soft boot
my computer.
Here is what Dell Chat tells me to do if ctrl/alt/del doesn't work:
Turn off the system from the power button. Remove the plug to the
power supply from the back off the system tower.Then hold the power
button on the tower down for 10 secs ( with the power cord removed).
Reconnect the power cord and then restart the system.This time do a
normal shutdown.
Regards,
Pp
Dec 02, 2009 | Dell Dimension 4600 PC Desktop
System recovery dell dimension 4600
you need to press the
ctrl + F11 as soon as you see the Dell logo screen when you turn on the computer.
the trick is. as soon as you turn on the computer, press and hold on the ctrl key then keep tapping the F11 key.
Sep 30, 2009 | Dell Dimension 4600 PC Desktop
Dell OptiPlex GX260 PC Desktop keeps switching its self on !!!!!!
Check the pwer settings on Desktop-properties-screen saver- power options and set it from there. Disable Hibernation......sodeep
Mar 22, 2009 | Dell OptiPlex GX260 PC Desktop
Dell wont start up
On the back of the chassis, there are 4 LEDs above the PS2 connections marked ABCD what do they indicate? During the boot process the lights normally flash on and off green, when the boot process is complete, they should all be green GGGG.
If any are Amber then they are indicating a power on self test (POST) failure. AAGG is bad memory for example.
Post the indications
Aug 06, 2008 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600 PC Desktop Logo
106 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
