Question about Pride Mobility Victory 3 Wheel Electric Scooter
Wont go forwards or backwards
Got new batterys .has a red light flashing above power indicator
  • 3 more comments
  • martin_alder Mar 13, 2009
    the motor is getting no power despite having new batterys it is in gear .it just got one flashing red light all electrics work lights ect.
  • martin_alder Mar 14, 2009
    its about 4 years old serial number on motor is 02050704 also in marker pen on control panel 0211BC1032206 light flashing on tiler all connections checked battery connections checked all ok .
    cheers
  • ruddski May 11, 2010
    How old is this scooter? if you have first 3 digits of serial # I can tell you what controller it has. Also are you talking about the rear tray were the light is flashing or by the battery indicator or the tiller in the front were the key goes. If you take the seat and shroud off there is a plug that connects the front of the scooter to the rear and 2 plugs were the batteries hook into to the harness, I would check those. Also check to make sure the battery connectors are hooked up with the red wires going to positive and the black to the negatives.
    the sequence of how many times lights flash is a diagnostic, how many flashes are you getting? Also was it doing this before the batteries were changed?
  • Anonymous Mar 19, 2014
    I have a chair that has been setting up for 6 months. Replaced both batteries. When you turn unit on battery indicator light flashes nine times the pauses then repeats. It will not move forward or backwards. Any help is appreciated.
Are you sure its in gear. the nob on the moter should be towards the front of the machine! Hope this helps
Posted on Apr 07, 2009
My nextbook 8 has a red flashing light and wont power on even after charging
Try taking out the battery and try turning it on with it plugged in. If it works, you need a new battery.
Jan 03, 2014 | Computers & Internet
Jazzy 1107 power chair won't move
3 flashes indicate that there is a short circuit to the left motor and battery connection. Check wiring and connections
Jun 14, 2013 | Pride Jazzy 1113 ATS Indoor Power...
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
When I plug it in to charge the red and amber lights stay lit and the green flashes and if i move the joystick everything is backwards push forward goes backwards left is right. b4 when it was plugged in...
sounds like a charger inhibit problem. Whenever you charge your chair the charger inhibit shuts down the chair so it can't be moved while charging. If you are getting this then that function is not working. Lets try this if you know of someone who has a chair or scooter with an off-board charger see if you can borrow it. Plug the off-board charger into the charger port located under the front of the joystick (don't have the on-board charger plugged in) and then turn the charger on. turn the chair's power on and you hopefully will see the lights blinking again indicating a charger plugged in (charger inhibit) the lights on the charger should be red and yellow (yellow turning green when fully charged) If you still get the problem with the off-board charger then your problem is in the controller or power module and this requires a new one. If Medicare paid for your chair you can call Repair Xpress @ 1-877-81-3733 or Roadrunner Mobility @ 1-800-467-2668 to have them fix it for you and bill Medicare for most of the repair costs. Hope this helps you
Oct 31, 2010 | Invacare Pronto M51 Power Wheelchair
No forward, only backward
Hi. If the light flashes 7 times, it has a speed controll fault. It might be the throttle lever ( wig wag ), or it might be the speed pot that controls your top speed.
Try moving the throttle lever ends up and down while you are driving the machine. Doing this wont fix it, but it will highlight the problem, if the throttle lever is faulty. Also try moving the speed pot back and forward a few times.
Good luck. Neil.
Jul 17, 2010 | Pride Mobility Products Hurricane PMV...
When I try to go forwards or backwards the red light flashes and I donot move
Hi. Count the flashes between the pauses, it is a fault code. Try putting free-wheel lever in the correct place. Different numbers of flashes mean different faults. Let us know. Good luck. Neil.
May 21, 2010 | Health & Beauty
Red flashing light
Find a new supply of "Duracell Ultra with M3 Technology" batteries and give them a try. The flashing red light is usually an indication that the batteries you have in the unit are not producing sufficient power to run the camera. Rechargable batteries are should have a rating of 2500mAh or above in order to provide enough power to maintain the draw from the camera.
Hope this helps!
OpenSource13
Apr 05, 2009 | Sanyo Xacti VPC-S60 Digital Camera
Flashing device status light
Ok the lightning bolt is your power indicator: solid green-charging, Flashing green-fully charged, flashing red-low battery, flashing red three times the once green-bad battery. the "trash can" looking one is your hard drive activity indicator it will flash while your hard drive is reading and writing.
Nov 20, 2008 | Dell Latitude D600 Notebook
Pride Mobility Victory 3 Wheel Electric Scooter Logo
228 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
