What is a Intel Network Connections 14.8.43.0
  • 3,799 Answers
Check your network drivers. And then when you find the one that isn't working-download and re-install it.
Posted on Apr 24, 2013
Intel 946 GZIS original motherboard Lan Problem
check the ethernet or usb lead connections make sure they are good with secure connections and you might have to reinstall the drivers
you will need to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled
If you are trying to connect through a modem/router the driver should have come with a disc provided by your ISP internet service provider or your motherboard disc
click start control panel administrive tools computer management device manager scroll to network adapters should see a yellow question mark? right click install drivers
hope this helps
Feb 11, 2012 | Intel D946GZIS Motherboard
I have a dell dimension 5100 and think the intel pro/100 ve network controller has failed, as the computer can't hold a steady Internet connection for longer than 5 mins, I can fix it for 5 mins at a...
the driver might have become unstable or it might be a problem with the modem/router or the connections
if you give your ISP internet service provider they will be able to test it online let them no what has happened all details and do this when the connection has gone
hope this helps
Jan 20, 2012 | Intel Computers & Internet
How to enable lan of intel board lan is not installed showing
If you are using a windows XP as an OS...make you have loaded all your drivers inclucing the LAN. Secondly from the START go the control panel--network and internet connections--network connections--you'll see the LAN icon/s.Right click on it and select Enable/Disable.
Jun 07, 2009 | Intel D845GVSR Motherboard
Unable to activate wireless lan
TRY GOING TO START, START SEARCH TYPE WIRELSS DEVICE
LOOKE IN DEVICE MANAGE FOR WIRELESS FOLDER
INPUT DEVICES
AS SO CHECK THE FOLLOWING FOLDERS ALLOWING COMMUNICATION BETWEEN THE LABTOP AND THE WIRELESS DEVICE AND THE COMPUTER.
NETWORKING AND SHARING FOLDER
PROBLEMS AND REPORTING
SECURITY FOLDER
SYNC CENTER IF YOU HAVE ONE
WINDOWS DEFENDER
WINDOWS FIREWALL
THE LAST 2 PROGRAMS IN THE LIST ABOVE CAN STOP THE DEVICE FROM WORKING.
YOU WANT MORE HELP I WILL HELP YOU IF YOU HAVE THE SITE CONTACT RODGANDYSR@GMAIL
ROD
May 12, 2009 | IBM TP R51 - P M715 1.5GHZ 256MB 40GB...
Hi, i accidentally deleted my intel pro wireless using the add/remove button when clearing up my computer. Now the wireless connections icon in the network connections section has gone and i can only...
The drivers are located at the Dell site at:
http://search.dell.com/results.aspx?s=gen&c=us&l=en&cs=&k=Intel+PRO%2FWireless+2200BG&cat=sup&x=9&y=6
Copy & paste the entire link in your browser
May 02, 2009 | Intel PRO/Wireless 2200BG 802.11g/b
My WZC (windows zero configuration) keeps getting turned off
Open Control Panel
Right click on Wireless Network Connections and select properties
The Properties window should open, click on the Wireless Networks tab
Put a check in the box for "Use Windows to configure my wireless network settings"
Click Ok
Sep 28, 2008 | Intel PRO/Wireless 2200BG 802.11g/b
Network problem
make sure u r in same work group,remove and instal in other pci slot and try,check cable connections up to server ,instal a antivirus progarm and scan ,if u are adwanced user u can use dos mode antivirus programes
pk86bhat@rediffmail.com
Mar 05, 2008 | Intel REALTEK nc-r150201 Network Adapter
Computers & Internet Logo
113 people viewed this question
David Payne
David Payne
