Question about Dryers
How do I remove the lint cover spindle from Simpson 39S555 clothes dryer
  • 142 Answers
SOURCE: clothes dryer stops
sounds like the drive belt has stretched, or the auto tension is low.
disconnect power and remove back cover, clean inside around motor resitor block wires, and inspect/ replace faulty components. good luck!
Posted on Jan 30, 2009
  • 686 Answers
SOURCE: back cover removal
you can't take the back off to get to the heating element. the front comes off. Look at the bottom edge on the front there might be a couple of screws if so take them out and remove the front of the dryer the door and all should come off be careful the door switch has a couple of wires remove them b4 taking away the front then you undo the belt and in the middle of the drum there should be 3 screws take them out and pull out the drum. now you should see the heating elements. if you'd like call me and i'll try to walk you through it 417-926-0106 Jim
Posted on Feb 18, 2009
SOURCE: My dryer (Simpson Minimax 150)
Probably the belt from the fan has broken. The fan is what moves the hot steamy air out of the unit.
try here for parts
http://stores.shop.ebay.com.au/ALLFIX-ELECTRICAL__W0QQLHQ5fSellerWithStoreZ1QQ_dmdZ2QQ_sasiZ1QQ_sidZ70171QQ_sopZ10?_nkw=Simpson+fan+belt&submit=Search&LH_TitleDesc=1
Posted on May 04, 2009
  • 98 Answers
SOURCE: Getting Hot, but not drying the clothes
there has got to be some restriction in the vent system. Take the vent pipe completely off and look in the tube coming directly out of the dryer. Also make sure the drum is turning good speed.
Posted on Jun 07, 2009
  • 159 Answers
SOURCE: I need to replace a simpson sirocco lint cover spindle
I'm not sure where you can get one as i am in australia but an appliance spare parts outlet should have one or order it in for you,alternatively try simpson or electrolux.
Posted on Jun 01, 2010
Model 41798702891 Kenmore stacked washer/dryer is collecting lint inside the door and putting lint onto the clothes.
I am not much of an expert with dryers but i'll give it a stab. Should there be a filter that catches the lint so that it does not go all over the clothes? Have you got the manual. If not, see if you can find the manual online and see if there is anything mentioned about a lint filter.
Dec 14, 2013 | Kenmore 98702 Stacked Washer/Dryer
I clean my lint trap from the dryer after every use, but i still get lint particles on all my clothes when I take them out! Its been happening every time and when i clean the lint trap its full. How do I...
Hi and welcome to fixya,
This problem can be caused by poor air circulation inside. In order to efficiently remove lint from clothes, load the dryer 1/2 of its drum capacity. It also helps putting fabric conditioner sheets to prevent clothes from charging static electricity which can attract lint..
Hope this helps,
levibit
Jan 05, 2011 | Whirlpool Clothes Dryer Lint Screen Left...
I need to replace a simpson sirocco lint cover spindle Do you no where i could purchase one. the plastic casing on the spindle has broken and the lint cover will not stay on.
Jun 01, 2010 | Dryers
Dog hair remains on clothes/blankets after washing
if you want suggested answers you have to provide make, model and type of washer ( top/or front load )
if it is a westinghouse , simpson, hoover or like make top loader , there is a lint catcher bag at the end of the center spindle cover that you simply pull up and unclip and turn inside out to clean
Soe put the detergent in that cover for the washing
Mar 18, 2017 | Kenmore Washing Machines
Fan in the Simpson Sirrocco 500 clothes dryer doesn't work.
It is both easy and cheap! I do believe there is a cover on the back of this model hiding the drive belt for the fan. It has iether broken or come off. If it has come off and lint or something of the like was not the cause it is quite possible that it has stretched and will require replacing =)
Feb 25, 2010 | Dryers
My dryer get to hot is simpson maxidry 505
sounds like it needs to be cleaned out,check outside to seeif the flapper is blowing open or if it is clogged with lint,if you have a leaf blower take vent line off of back of dryer and blow it out,vac inside of dryer and clean out the lint filter duct,if it's gas you should do this every year so you don't have a fire,electric every two years
Nov 08, 2009 | Dryers
My Simpson Sirocco 3500 clothes dryer emits burning smell!
1)check for something stuck between drum and dryer housing 2)check for stuck vent flapper at exhaust opening outside 3) check dryer lint screen
Nov 05, 2009 | Dryers
Clothes dryer stops
Jan 30, 2009 | Dryers
My dryer (Simpson Minimax 150) seems to be choked? It gets hot and the drum spins, but it doesn't dry clothes and upon opening the door, heaps of steamy air pours out. The lint filter is clean. Is there...
try here for parts
Jun 19, 2008 | Dryers
Simpson Clothes Dryer is smoking from the back
You should check your vent. is your vent in the front or back as some Simpson can vent in the front or back. You may be pluged with lint. safety therostat should shut down if too hot. but the lint may catch on fire. please check it before you use it again.. let me know what you find out? krazytech
Sep 10, 2007 | Dryers
Dryers Logo
54 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
