Question about ASUS G2P Notebook
Asus G2P battery problem
Computer didn't run under battery power supply at all. After power cord disconnection immediately stuck up and only restart of computer can help. The same problem appears if start notebook with battery supply only. Windows starting on and immediately stuck up. Nothing else I can do only restart of computer. Please advice
Have acer 7540 On restart have error 0211 key
Try this fix:-
This problem was on a Gateway NV52 running Vista Home Premium (64) and this is how it was resolved, with the help of their tech support:
1. Turn off computer and unplug power cord.
2. Disconnect all external devices
3. remove battery
4. press power button and hold for 10-15 seconds
5. plug power cord back into computer and press power button.
6. Check LED's and listen for power supply fan.
7. If LED's are on or power supply fan starts spinning, watch for boot screen
8. If computer begins to turn on, turn it off.
9. Reconnect battery and external devices.
10. Press power button and make sure computer starts.
Sep 22, 2014 | Computers & Internet
The battery led blinking red/green
Disconnect power cord. Please take out the battery. Hold down power button for a minute and then connect only power cord. Restart it again.
Jun 24, 2013 | ASUS Computers & Internet
Asus Eee notebook startup issues
Unplug the power supply and remove the main battery, press and hold power for 60 seconds to get rid of any residual voltage. Re-install the battery and connect power supply, if no change! take laptop back to the place of purchase since warranty will apply.
Mar 20, 2012 | ASUS Eee 4G Notebook
No power
Try disconnecting the power supply and start it on battery only.
After you see a screen display of some kind, the power supply can be reconnected.
If this does not work, then remove the battery and start the computer using the power supply only.
After the computer start up sequence is complete, the battery can be re-inserted into the computer.
If the computer continues to misbehave on later restarts, then follow the more rigorous BATTERY RECALIBRATION Procedure below.
1. Now, after the system is up and running with both the battery inside and the power supply connected, after taking note of the current settings so that they can be restored later, set the power plan to High Perfomance, set the computer to Never Sleep on Battery and on Power Supply, disconnect the power supply and allow the computer to run until it shuts itself off due to a low battery condition. This will discharge the battery and performs phase one of battery re-calibration.
2. Next, plug in the power supply, while leaving the battery in place and restart the computer. Allow the battery to fully recharge while leaving the power plan at High Performance and the Sleep to Never. This performs phase two of battery re-calibration.
3. Then, disconnect the power supply and allow the computer to run until it shuts itself off due to a low battery condition, again, now that it has a possibly better, fuller charge than in the previous charge/discharge cycle.
4. Again, restart the computer, connect the power supply and allow it to completely charge the battery.
5. Shut down the computer, disconnect the power supply.
6. Restart the computer and allow the computer to run until it shuts itself off due to a low battery condition again.
7. Now the battery has been recalibrated. Connect the power supply, restart/resume the computer and allow the battery to fully charge again. The Power Plan and Sleep Mode can be set back to their original settings at this time.
8. The above procedure should only need to be performed every six to twelve months to recalibrate the battery.
This condition sometimes happens to my HP Presario when I have left the power supply plugged into the computer with the battery in for several days or weeks at a time, without running on the battery alone for a while to discharge and recharge it a little bit.
HP recommends that when running your computer for more than two weeks from the power supply, the battery should be removed to slow the aging of the battery, which can cause the battery to lose capacity or fail prematurely.
May 23, 2011 | HEWLETT-PACKARD Hewlett Packard HP 15.6"...
Battery of my Acer Aspire 4810T does not work. With the power supply plugged in, the indication of the battery is "85% available (plugged in, not charging). If the power cable is disconnected, the...
There are three possible reasons why your computer is experiencing this power problem. What you need to do is to isolate the component that's causing it.
These are the parts which should be checked:
1. Power supply
2. Battery
3. Motherboard of the laptop.
Here's the procedure that you have to follow:
Remove the battery from the computer.
2. Power the computer up with the power cord only without the battery on it.
3. Check if it works perfectly without any problems even if the battery is out. If it works, then, the battery needs to be replaced. (Note: Batteries are disposable parts. They usually die after 2 years of usage depending on how you use it.)
4.If no go even without the battery on it, check the ac adapter or cord if there's a light lit on the box of the cord. If no lights on it, double check the connection. If connections seem ok but no power, then, replace the power cord.
5. If power cord seem fine, check the hole in the computer where you plug in the cord. What you need to check is if there are any sign of damages. Wiggle the cord and see if there are lights lit in the laptop.
I hope this help.
Apr 13, 2011 | IBM ThinkPad T40 2373 Notebook
My power light comes on then ngoes off immediately
1. Turn off the computer
2. Removed battery and disconnected power cord .
3. Wait, for 5-10 minutes
4. Plug the power cord back in but DO NOT reinsert the battery
5. Holding down both the Insert/Scroll button, hold the power button down for 20-30 seconds, release the power button. still hold the Insert/Scroll button press the power button normally should come up and Windows should boot.
6. Restart hit ESC it should open the BIOS and reset to default. restart computer should come back.
Feb 19, 2011 | HP Compaq Presario F500 F700 and G6000...
Notebook Asus G2P Recovery cd 2/3 problem
check your hdd.. and cd rom drive..
Jun 20, 2009 | ASUS G2P Notebook
Asus g2p max ram
You got two memory ports. One on the bottom of the unit.The second one is on top of your Notebook. To reach it you have to remove the keyboard. There are three small points on the top of the keyboard to unlock it. Under the keyboard you will find a metal protector with one screw which protects the second ram...
By the way: The Bios only recognizes up to 2 of ram.
System Profile ASUS G2P Standard Memory 0 MB (removable) Maximum Memory 2.0 GB Slots 2 sockets System Notes PC2-4200/5300 DDR2 SDRAM SODIMMs
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 04, 2008 | ASUS G2P Notebook
Stuck in standby mode
unplug the cord from the power supply open the case and disconnect the cord from the power supply to the motherboard then press the power on button this will release the leftover electricity from the motherboard than after 30 seconds plug the cable back into the motherboard and plug in the cord to the power supply and try to restart the computer ok please let me know how this goes goood luck
Aug 05, 2008 | Computers & Internet
ASUS G2P Notebook Logo
141 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
