Question about Welding Tools
Renegade Stick200 Welder Overtemperature Light Comes on as soon as I draw An Arc and Shuts Welder Down
5 Suggested Answers
  • 81 Answers
SOURCE: Everything comes on and the wire feeds. However it
Check that your ground clamp is connected to the work piece securely.
Posted on Apr 21, 2010
  • 3 Answers
SOURCE: My 130EN welder comes on
WITH MY EXPERIENCE ON MINE...YOU MAY HAVE COOKED YOUR TRANSFORMER...THUMBBUSTER
Posted on Apr 02, 2011
SOURCE: mastercraft arc welder
i have a mastercraft welder wire feed , the power turns on the wire feed works and the fan in side turns on but it will not weld not even a spark! can anyone help?
Posted on Aug 17, 2011
  • 1212 Answers
SOURCE: old AC180T welder has a weak arc no weld
Are you using cored wire? Or shieldgas? if the later, you may not be getting any to the gun.
If you are using solid wire without shield gas, you will get what you describe.
In the off chance you are using the correct combinations, you may have a loose connection in the circuit that adding resistance to the circuit and lowering the effective voltage at the tip. Make sure all connections are tight inside of the machine as well as the cables and gun assembly as well.
Posted on Apr 01, 2012
Kende weld no arc
make sure your work-piece has a proper ground. and maybe check your gas connection. no leaks. maybe turn gas down.
Mar 27, 2013 | Welding Tools
Tig Welding settings for Renrgade 160VRD welder
Your machine is a MIG welder only. You can't do TIG. Sorry.
Dec 25, 2010 | Miller RENEGADE 180 WELDER GENERATOR MIG...
M lincoln 225 arc welder runsfan comes on but will not strike an arc in any switch settings on front of unit.has been welding fine except for a year it would not arc in a few of the settings and now none...
Transformer is burned out. Various windings are taken off at different points to alter the amount of power, they have eventually burned right through , So that is why some worked and some didn't It has now completely gone. The cost to replace the transformer may well exceed the cost of a new welder.
Please rate my help++++Thanks for using FIXYA
Jun 18, 2010 | Garden
Mar 14, 2010 | Clarke Power Products Clarke 130EN...
My little 110 mig welder is arcing without trigger pulled
i believe that the trigger only send out the wire and does not control the arc the tip should be live as long as the welder is on
Feb 28, 2010 | Lincoln Welding Tools
Lincoln Weld Pak 100 arc welder troubleshooting
There can be a switch that makes the wire electrically "dead" so it can be fed through the liner. Also suitcase style welders have a sensor wire with a clamp that must be connected for the arc to be able to be struck.
Nov 22, 2009 | Welding Tools
Miller welder stsrts but shuts off new carb installed having problems with klinkage and carb adj/
Always look for the simple things like earth clamp, loose connections, coroded joints, bad solder joints , fuses, fuel filter, before you start pulling the set to bits,
Nov 18, 2009 | Miller RENEGADE 180 WELDER GENERATOR MIG...
Cooling fan/ lincoln 225 arc welder
the fan should be pulling air from the front of unit and out the back.
Jun 10, 2009 | Lincoln Electric K1297 AC/DC 225/125 Stick...
My lincoln welder/generator Ranger 8 will not idle up when stricking an arc, it will idle up if I plug in a drop light.
Sounds like your CT or CT board is bad. CT stands for Current Transformer. A CT senses an increase in voltage draw or current, which will trigger the idle solenoid.
May 07, 2009 | Lincoln Welding Tools
GIANT 200AMP INVERTER ARC WELDER NO POWER TO THE LEADS
remove the fan from the circuit and try it then, does it weld ok with the fan removed?
Dec 13, 2008 | Inverter 220 Volt Tig Arc Welder
Welding Tools Logo
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
