Question about Dryers
No hot air in clothes drier - but tumbles and control screen lit, normal
I'm presuming the heat element needs replacing or a wire to it has disconnected. I wish to open up the drier and apply a multimeter. I've removed the Torx screws from the back of the drier, including two holding the top down with a lip in the way of the back sliding up. I presume there are some clips somewhere preventing the top moving. I'd like some advice on how to open it up without snapping any clips.
  • Sais Apr 26, 2013
    Model: Miele Navitronic T 4882C front loading clothes drier.
    New Friend:
Depending on the model, once youve removed the 2 screws at the back, the whole top should actually slide backwards and then you should be able to lift off, it should not take a great deal of force but may need a nudge. most just slot backwards.
re the heating, the element should be behind the back panel, and should be easily accessible, you will easliy be able to tell if its bust, as it will actually be burnt out and collapsed, not nice and firm and springy.
to replace this is a doddle, about 7 quid from amazon just type in the model number and part to search and its as easy as unplug the old, plug in the new.
hope that helps.
Posted on Apr 22, 2013
Testimonial: "This particular model has two flanges coming down from the top of the drier at the back, each an inch wide, each with a screw. When I take the two screws out, the top doesn't slide back. I lifted it fractionally and saw another two matching flanges sticking down from the top on the inside of the rear wall, matching the outside pair. The screws appear to go through the outside one, through the wall, and into the inside blocks. These inside blocks/flanges stop the lid sliding backward. Unfortunately, I can't lift the rear of the top up enough to see what is holding it in place further forward. Thanks,"
3 Suggested Answers
richroth
  • 9472 Answers
SOURCE: hotpoint tumble drier wont heat
What is the model number?
Posted on Oct 20, 2012
  • 18 Answers
SOURCE: How do you remove top from a Hotpoint CTD80 tumble
2 screws at the back and then push the top towards the back of the machine...you might need to give it a bit of a wack, if it's too tight just take the 3 screws from the back of the side panels and things will loosen up a little
Posted on Jun 20, 2011
Bosch next 500 plus burning smell in dryer
Sounds like to me, but I'm no expert, the heating element is "over-heating and not getting the m"air" it needs to cool down enough to keep from burning. Literally I mean burn because the way a drier works is there is a fan at the heating element to blow the heat from the element to dry the clothes and if the fan is filled with lint it can't blow much air across the element and causing it to have the burning smell. I would check the fan blades and those are usually connected directly to the drier drive motor. I wouldn't use the drier until issue is resolved for the reason being is you can burn out the element and have to replace it too. Hope this helps you in you quest to the repairs of you drier :o) Jesus loves you John 3:16-17 (KJV)
Jun 16, 2018 | Bosch Dryers
I want to know that on my washing machine lg-80BKF21P model the time(min) 10 minutes was remaining and the washing process is done,it ends but after drying all is done but 10 minutes were remaining and...
tumble driers and combination washer driers have a 10 minute safety margin, where the heat fior drying is dispersed, to avoid people grabbing very hot clothing.. especially if it is not quite dry as this would make them, hotter to the touch.
Tumble driers usually continue to tumble, but blow cool air through the clothes to get rid of the heat, before stopping.
Oct 02, 2017 | LG Washing Machines
Hotpoint tumble drier wont heat
Oct 19, 2012 | Dryers
Our dryer doesn't dry clothes like it should, sometimes takes a long long time and other times quick and the clothes feel really hot, model # is DLE 2532W
see this causes and fix it. God bless you
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating Element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it. The proper ohm reading can be found in the service manual or sometimes on the tech sheet located somewhere on your dryer (9- 13 ohms is a common reading). Electric heating elements aren't repairable. The heating element is easy to replace. Check our videos for other types of dryer heating elements.
Thermal fuse / Thermal Cut Out / Thermistor
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel or behind the front cover. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing They are also round and made of metal and plastic. The thermistor is located on the blower housing usually. If any of the fuses do not have continuity replace it. Check for continuity if none replace, But before replacing check for obstructions. The fuses are very inexpensive and easy to replace.
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. Check all connections, make sure they are tight. Loose connections can lead to a fire. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Sep 27, 2012 | LG DLE2532W Electric Dryer
Whirlpool Cabrio dryer temperature won't get hot? What causes this problem?
Runs but will not heat
1.loose wiring----check terminals & wiring
2.defective centrifugal switch in motor---replace switch ( check linkage to motor)
3.defective timer---replace
4.open heat element---replace heat element
5..defective operating thermostat---test thermostat, replace if defective
6.fan or it's pulley loose on shaft---tighten set screw
7.incorrect heat or timer settings---reset timer
8.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
9.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 25, 2011 | Dryers
Drier spinning but doesn't get hot/warm.
Hi
If the dryer is not drying the clothes then you would need to check for the following things—
Electric Dryer---
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the amp reading at 240 V, it should have reading of 24, 21 and 3 amp (approx.) for 2 lines and neutral respectively.
3. Heating element may have turned or the connection to the element might be loose. Sometimes a shorted circuit element will keep on blowing the fuse or circuit breaker.
4. Motor wiring shorting to ground.
Hope this helps...
Daniel
Sep 03, 2010 | Zanussi TC7102W Electric Dryer
Drier shuts off
Thermostat controls heat. There is also a
motor centrifulgal switch, in the element
circuit, that the motor closes to insure
the motor is turning. Try another heat
setting. There is more than one
thermostat. You may have blown the
'thermal fuse' too, which requires
replacement. The elecment has a contact in
the 'timer'circuit too.
It is possible that your element has
failed also.
Tripped high limit. Must clean the lint
filter and the exhaust vent tube and all
the way in to the dryer. Hot air exit is
restricted.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 12, 2009 | Whirlpool LER5636P Electric Dryer
Asko Drier T741, Panel powers up, Press start Trips House Circuit
yes time for a full service take to your nearest electrical service place
Feb 22, 2009 | Asko T741 Dryers
No heat from my tumble dryer
Presumably the motor and fan are working.
Check filter, and if it is vented with a hose, make sure it is not blocked with fluff. if all seems to be o/k, then the heating element is probably faulty.
Please leave good feedback if this helps with your problem
Nov 26, 2008 | Dryers
Dryer does not dry clothes
If the dryer tumbles but does not warm up, you either have one or two blown thermal fuses, a burned out element if it’s electric, or a burned out igniter if it’s gas.
If one of the two thermal fuses are blown you will not get heat.  Thermal fuses blow (and are not resetable, they must be replaced) when the machine gets too hot.  Often this is caused by not enough air flow through the machine.  Check and make sure your exhaust vent is not clogged.  Clean it the best you can to get all the lint, dead mice, bird nests, etc. out.  Also make sure air is blowing out of the machine when it is turned on.  If not you have a blower problem.
The thermal fuses are located on the element casing.  They each have two wires coming out of them.  They are about 3/4 inch round with screw ears on the sides so they are about 1 1/2 inch long and about an inch across.  With a multimeter, check the continuity across the terminals.  If there is no continuity the fuse needs to be replaced.
To check the element(s), you can either visually look and see if it is broken or check the continuity with a multimeter.  No continuity means the element is broken.  Replace if necessary.
To check for a broken igniter, take out the old one and look at it.  If it looks broken or very burned, replace it.
Oct 16, 2007 | Zanussi TC7102W Electric Dryer
Dryers Logo
42 people viewed this question
Top Dryers Experts
