Question about Technics SC-DV290 System
Technics sc-dv290 when you press play it struggles to read the disc then HO2 comes up in display, followed by no play. Prior to this happening it happened a couple of times but worked for a little bit after, now it appears to have given up. any ideas pleas?!
  • paul read Aug 05, 2007
    has not really helped to be honest. i'd have thought with the premium sevice i'd have at least been told EXACTLY what the code HO2 means? sevice reset didn't work, ie reset it.
  • horseman192
    horseman192 Feb 17, 2013
    the same thing happens on my one - i opened the case and took a cd that i had in slot number one out - i have noticed that when i am trying to use slot number one in a dvd player this error appears - i just stopped using it and all other slots work just fine
    Brigadier General:
  • 6,966 Answers
Hi, An HO# display is an indication of an internal problem, HO2 - possibly optical pickup. For certain reasons, I would strongly suggest that you bring your unit to a qualified service professional or an authorized center. If you have your own reason(s) of venturing to trying to fix it yourself, a couple of tricks you can try (should you be feeling adventurous and gamble on loosing it all together): 1. If it is an electronic problem, do a service reset; with no disc & tray closed power on, simultaneously press play, pause and back buttons (5 seconds). Unit should reset indicated by blinking of display. If this does not work, try with the power off, press the 3 button then power on; or 2. If it is a mechanical problem, gently shake the unit to and fro. The idea is to partially dislodge the eye from its position, it might have been stuck. Opening the unit will also serve the same since you can do visual inspection. Look for any foreign object along the rail (sliding bar) or any possible obstruction to the operation of the mechanism inside. If none works, you're back to the first suggestion. Hope this works out for you and give you some ideas. Pls post again how things turn up and/or if you need more information. Good luck and kind regards.
Posted on Aug 04, 2007
  • Louie  Role
    Louie Role Aug 05, 2007
    I understand that the reset did not work. HO2 error refers to optical pickup problem which is made up of several components from the lens itself, the calibration circuitry, the connecting flat cable plus the the mechanical cradle it sits on. More often than not it is the eye (lens) that deteriorates faster than the other components. Bowever the calibration circuitry also plays a vital role, a mis aligned eye would give sysmptoms of a defective eye but can be rectified by calibration not replacement. Further if the cradle is stuck, you would have the same error because the eye cannot move over to the start of the disc.
    The error code can only give us a general location where to look. As earlier suggested, an on site qualified service personnel with test instruments would be able to better diagnose your particular problem.
SOURCE:
How do i connect technics turntable model SL-QD33 to technics stereo model SC-DV290 and what do i need to switch to on stereo to play records.
Have a look on the back input panel of the sc-dv290. Check for a "PHONO" input. If there is no phono input it will not play turntable. If there is: then plug it the turntable in and switch the SC-DV290 to PHONO mode.
Another way would be to purchase a "phono preamplifier" from ebay: Hook the turntable into the phono preamplifier, and the preamplifer into the SC-DV290 AUX input.
Feb 26, 2011 | Technics SC-DV290 System
My technics sc dv290 cd/dvd doesnt read discs what are my options if the laser has gone ? all electrics are working
Check replacing laser, opposed tonew unit. You'll probably be happier with a new unit.
Oct 19, 2010 | Technics SC-DV290 System
Technics dv290 system
i once had a panasonic dvd player which displayed the same code H02 and used the same drive mechanism as your player. this turned out to be a worn spindle motor and once replaced, all worked fine. you may well have the same fault. hope this helps?
Sep 06, 2009 | Technics SC-DV290 System
It wont read any disks and keeps coming up with DVD HO2 i've unplugged it for a while but it still comes up with the same message.
POSSIBLE solution
I had this problem a while ago comes up with that code then NO PLAY there are 5little discs inside that seperate the discs when theyre inserted these had come loose somehow I simply restacked them on the spindle, however they MUST go in a certain order or H02 will still appear, mine had numbers on them (but NOT consecutive) I just stacked em in ascending order. It worked great after that.
HOWEVER Ive just had the same problem again but the discs arent loose this time.
Mar 10, 2009 | Technics SC-DV290 System
Dvd wont play ...each time you insert a DVD it shows DVD HO2...
I had the same Problem, player was only 13months old when the error HO2 appeared (typical huh?) anyway 2 years of this thing getting shifted from cupboard,wardrobe,attic, (did'n't want to throw it out cause it cost me £700), finally it came to fix it or bin it time. scoured the net to no avail, lost the rag and half dismantled it..then during all of this ( oops I'm going on a bit LOL)
you can hear a sound as though the disc is trying to be read, after 100's of attempts to get it to work, I finally noticed the disc had not changed position. (disc was not spinning) pointed to the Motor??
what I did to fix this was unplug from main's, remove top cover until you can see the top of the dvd disc, got hold of a pencil with a rubber on one end, plug back in, switch power on, and gently pushed top of disc ( clockwise ) and it kick started it off
that was over 3 years ago and the player is still going strong
I know its a bit rough, but nothing ventured nothing gained ;)
Feb 17, 2009 | Technics SC-DV290 System
How do I switch off demo on a sl-dv170 technics?
got the sc-dv290 model, not sure but I'd asume they are all the same
PRESS AND HOLD [-DEMO] until "NO DEMO" is displayed
Feb 15, 2009 | Technics SC-DV290 System
Technics sc-dv290
Oct 26, 2008 | Technics SC-DV290 System
Technics ho2 no play error
u need a new motor in yr dvd player i had same problem so had new motor fitted cost 50 pound works now
Sep 20, 2007 | Technics SC-DV290 System
Won't play cds or dvds
you need a new motor in yr dvd player i had same problem had new motor works now
Aug 04, 2007 | Technics SC-DV290 System
Technics SC-DV290 System Logo
125 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
