Question about Toshiba Satellite P105-S6227 Notebook
Power port connection
The power port connectsion seems to be inoperable. There is no power being transfered to the laptop when the cord is plugged in. I would like to get the schematics so that I know how to open up the box and visually inspect the port connectiong to the Motherboard.
  • Toshiba Master
  • 32,281 Answers
I would check the power adapter first before dismantling the laptop.
Test the power plug on the adapter with a multi-meter, the voltage should be slightly higher that the voltage that is printed on the label on the bottom of the power adapter.
If the voltage is zero or very low the the adapter is faulty and needs to be replaced.
Posted on Jul 19, 2009
My HP pavilion laptop has a problem when I power it the lights just go on then off
Start by making sure its plugged in and charging. most laptops have a light that is on if the cord is plugged in.if its plugged in and there is no light one wiggle on the connection on your power cord. start at the wall and check every connection. if the light blinks than you power cord is bad or the power port in the laptop has disconnected from the mother board. Some computer stores will have a loaner universal laptop charger you can borrow. I recommend borrowing there universal before you buy a new power cord
Jul 25, 2014 | Computers & Internet
Connect usb port
Check all computer connections and cords. Is the powerstrip for surge protector light indicator bar (usually inside the off/on switch itself) on?
All it takes is a pet to walk over it or a foot to bump a cord and break the power connection. Mine do it all the time. Check the power on/off button on the printer to see if it accidently got powered down.
Sep 19, 2013 | HP Officejet Pro K5400 All-In-One InkJet...
I have an AspireOne netbook that has always worked till yesterday when it did not want to come on. It lights up for a couple of seconds and turns off. It did this last night ... but finally did come on...
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Apr 14, 2011 | Acer Aspire One AOA150-1570 Notebook PC
The power plug doesn't seem to connect properly and, when it does, the charging light invariably flashes and fails to charge the battery.
Try purchasing a new power cord and if that does nt work then it would be the port on the laptop itself and if that is the case then that is not fixable and will need a new motherboard or computer.
Mar 26, 2011 | Acer Computers & Internet
How to connect my d-link 2 my pc's (laptop and desktop) for data transfer
power on switch , have two patch cord with you, first connect in pc's eathernet port and second in laptops eathernet port,connect those cables to switch's lan port respectively start the switch and turn on pc and laptop and main thing enable sharing in remote desktop.
Mar 02, 2011 | D-Link DES-1008D 8-Port Ethernet Switch...
Power port problems
I think it is problem with your power cord
you should get it replaced soon so that your battery does not get short
May 20, 2010 | Gateway 6510GZ Notebook
My power cord not charging battery
you may have damaged the power input port.
broken solder joint. or your power supply took a dive. if you have a DMM 'meter' check the power supply to see if you are getting power from it.
if it is the power input port, you will have to either open up the laptop and see if it is a fixable soldering job or take it to a pro.
Happy Fixing =)
Jul 11, 2009 | Dell Inspiron 6000 Notebook
Logitech Alto Connect 3-Port USB Hub
There is a port for the a/c adapter on the bottom side where the USB ports are.
Looks like its supposed to come w/ an A/C power cord
See package contents
U can purchase a universal power adapter from Radio Shack if needed.
Jun 05, 2009 | Logitech Alto Connect 3-Port USB Hub
Toshiba P15 S479 Laptop
I had the same problem. The AC adapter connections on the mother board had to be resoldered.
Nov 04, 2008 | Toshiba Satellite P15-S479 Notebook
Open Questions:
See all Toshiba Satellite P105-S6227 Notebook Questions
Toshiba Satellite P105-S6227 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
