Circuit City ''esa'' TV picture curves in on sides
When I moved from Lubbock to Fairfield (TX), my tv started ''curving in on the sides''
  • 89 Answers
Curving in on ( hour glassing ) the sides is usually the indication of a bad regulator IC. Since it occured after a move, you may also have a bad solder connection or smal crak in the board. To check for cracks ( assuming you have unplugged the power and are relatively comfortable doing so) shine a flashligt from the top of the board ( with the components on it ) and examine the bottom of the board. If a trace is broken you can often see it this way
Posted on Mar 12, 2009
Samsung curve 65 inch has no sound, has picture.. Using Bluetooth curved sound bar, no sound on tv speakers either
Hi!
Check your power amp circuit. Or, check if it is feed by the power supply circuit. Good luck,
Serge.
Oct 09, 2016 | Samsung UN65HU8700 65"" Curved 4K Ultra HD...
I have a Samsung HL-T5676S DLP TV and the picture just recently started to look curved. In the middle of the screen it's straight but on the sides it starts to curve up. Any idea of what could be causing...
make sure you do not have anything sitting on the top of this tv. I have seen this on my tv by just gently putting pressure with my finger on top the screen starts to curve up at the edges.
Jan 14, 2010 | Samsung HL-T5676S Television
Rca f35670mb
hi there.im not familiar wih the model,but your fault lies in the east west correction circuit.excessive width usually means a short circuit e/w modulator diode,with the curved sides.normally,a narrow picture with curved sides points do dry jointed/open circuit polyester capacitor.if a firm slap has an effect,then its most likely a dry joint which makes for an easy life.the vast majority of east west correction circuits are based in tle line output stage,and generally not complex to fix.hope this helps,regads,steve.ps. look for s/c by 299 and by 228 diodes,check those..
Nov 05, 2008 | RCA F35670MB 35" TV
RCA Projection TV model #p61926
The convergence circuit is your problem and most times with this model the convergence power supply bd. is the problem.
Feb 11, 2008 | RCA P46921 46" Rear Projection Television
Samsung rear projection 42" green curves causing distortion just started
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
Dec 02, 2007 | Hitachi 50UX57B 50" Rear Projection...
Screen is curved inward on all 4 sides and there is a red, and a blue line that is curved at the top of the screen
This is a convergence problem.. possible deflection problem... you might need a tech to look at it...
Nov 19, 2007 | RCA HD56W66 56" HDTV
Shrinking picture
picture is starting to curve in from the sides like the shape of an hour glass. Is the tube shot? NO. is it something less costly? YES YOUR PROBLEM is in pincushion correction circuit.call skilled tech to fix it. it will not take much time. good luck.
Sep 22, 2007 | Televison & Video
Curved horizontal lines in picture
Its Sounds like Convergence Circuit,If you take the Back off and look on the right side you should see a Board with Big black Ics Mounted beside a Large Heatsink,Mark the wires where they go and Make sure the POWER is Off Pull the Board out and Inspect the Connections from the ICS,you find Circle Breaks,They need to Be resoldered and That should fix the Set....
Jul 20, 2007 | Samsung PCK5315RX TV
Televison & Video Logo
167 people viewed this question
Top Televison & Video Experts
Electro Med Services...
