Question about Kitchen Ranges
Rheostat for stove top element
One of my stove top elements stays on high. It's either off or on full. Can I get a replacement control?
jsrock516
  • 5911 Answers
SOURCE: One element on my KitchenAid
Sure can. One element can easily be replaced. If your model number is correct, you can find replacement parts at searspartsdirect.com. Type in your model number in the Search menu and the surface elements can be found under the "Cooktop Parts" heading. I do not know which element you have that is bad, but they are identified as item 12 and by wattage rating. Use care when selecting to make sure you identify the correct element. The smaller elements have a lower wattage rating than the larger elements. There's also an illustrated view for easy part identification. Some parts come with directions on how to replace. If no instructions are available, or if you need further guidance, go to my profile page and click on "Tips and Tricks. I have a write up listed there on how to replace a glass cooktop. Those same instructions can be used to replace a single element. Instead of removing all the elements and cooktop, you will only have to remove and replace the one element. Just make sure you unplug the range before starting and handle the elements with extreme caution. They are considered fragile. It may also help to have a second person assist. I hope this answers some of your questions. If you need further assistance, please post back and let me know.
Posted on Apr 21, 2008
jsrock516
  • 5911 Answers
SOURCE: I have a Kenmore Stove
You could very well have an Electronic Oven Control (EOC) board problem. There two separate circuits that control the oven BAKE and BROIL functions. If you have replaced the BAKE element, and have ensured it connected properly, the only other component that controls that function, is the EOC. If you post back with your complete model number, I can double check to make sure. The model number will be located on a nameplate somewhere around the oven door opening or lower drawer opening. The reason I need to confirm is because some ranges have a separate relay control board.
Posted on May 28, 2008
tony2155
  • 64 Answers
SOURCE: Front left dual element on a Frigidaire ceramic
open the door and look under the top remove the screws and the top will lift
Posted on Jun 23, 2009
  • 491 Answers
SOURCE: surface light stays on when stove top is
THIS IF FOR SAFTEY BECAUSE WHEN YOU TURN THE TOP OFF THEY STILL ARE VERY HOT EVEN WHEN THE ELEMENTS ARE NOT SEEN BUT THEY GO OFF WHEN THE TOP GOSE COLD .
Posted on Nov 22, 2009
pride applia
  • 232 Answers
SOURCE: Largest element heat remains high in every position
you need a new switch no dought
Posted on Dec 24, 2009
Ceramic stove top large element on high and won't shut off until turned all the way off
The range surface burner control switch, that the knob is attached to, needs to be replaced. The link is an example, as I don't know the model. They are mostly similar between manufacturers.
Range Surface Element Infinite Switch Part Number 3148952 SAME DAY SHIP...
Feb 03, 2016 | Frigidaire Kitchen Ranges
How do get rid of F10 which is on the window of my Kenmore stove
The F10 error means that the high temperature sensor is reporting a runaway temperature and shut down to avoid a potential fire. Try unplugging the stove or tripping the circuit breaker to reset the code.
If the error recurs, unplug the stove (or turn off the circuit breaker) again. Look at the broiler and bake elements with a flashlight. If it has any damage (breaks, char, melting), you will need to replace the element. Check where the elements connect to the oven and replace them if there is any charring on the back wall.
If the elements are undamaged, you need to check the wiring to identify if the problem is at the elements, the high temperature sensor, wiring or the control board. You will need to access the wiring from the back of the stove. Disconnect the wires to the heating elements. Then disconnect the wiring connections at the high temperature sensor and the control board. Without a model number, I can't be completely sure of the resistance that should be seen at various points. Please post a comment with the model number of the stove and I'll try to confirm the expected and faulty resistance values. Most likely, the resistance should be under 50 ohms but above zero between the left and right contacts of the elements and the violet wires in the wiring harness at the control board. The high temperature sensor should probably have a resistance between 1,000 and 1,200 ohms. If the resistance is high, you'll need to replace the appropriate parts. (Note: if the wiring at the control board gives a reading similar to the resistance of the high temperature sensor, the control board is the likely suspect.)
I hope this helps. If your stove is under warranty, contact Sears/Kenmore to fix the issue. If you aren't comfortable testing the wiring, contact Kenmore for a service call.
Feb 04, 2015 | Kenmore Ovens
Cooking element on stove top goes on full heat,even when dial is set on low.
Electric, I presume. Disconnect power to stove, open backsplash, remove knob, replace control unit.(usually universal type). Available appliance repair shop. Careful with 220volt power!!!!
Sep 20, 2014 | Kitchen Ranges
My stove SVE47100C the elements in the oven do not heat.I have replaced the computer panel a year ago as well as the element
If both of the oven elements stopped working at the same time, and the stove top elements work then the problem is most likely in the high limit fuse. It is the common component to both oven elements.
The control could be bad, but I would have someone test the high limit first. It should read 0 resistance if it is good.
May 17, 2010 | Jenn-Air SVE47100 Slide-In Electric...
Troubleshooting electrical stove
Infinite switch, it's not cycling internal contacts are welded together, make sure control it's set on low, if the heat element. stays red hot, replace control (inf. switch).
Dec 23, 2009 | Kitchen Ranges
The element on top of the stove stays on
Replace the switch for the bad element. It is stuck internally in the ON position.
Jul 30, 2009 | Frigidaire FEF352 Electric Kitchen Range
Stove top burners and lower baking element not heating up
If all the elements are dead, check for blown fuses/tripped circuit breakers. There may be some in the range unit itself in addition to your electrical service panel. If one element is completely dead on all heat settings, the control is probably bad or there is a broken wire. If it is stuck on high for all control settings or is erratic, the control is bad - replacements are readily available and easily installed.
On ranges with push button heat selection, a pair of heating elements are switched in various combinations across 120 and/or 240. If some heat settings do not work, the most likely cause is that one of the heatings elements is burnt out although a bad switch is also possible. Kill power to the range and test the heating elements for continuity with resistance meter or multimeter.
For the lower baking element:
Again, check for blown fuses in the oven or tripped circuit breakers. The remove any wiring to the bottom element and test for resistance. If you get no reading (or a very high resistance) then your element is dead.
May 09, 2009 | Kitchen Ranges
Stove top elements f1 error code
Hi. you can try to reset the electronic oven control by unplugging the unit for 3 mins. if the problem still exist, you will have to replace the clock/control(electronic range control).
please rate and god bless:)
Apr 02, 2009 | Kenmore 24032\24036 Top Load Washer
Large element burns high
The problem is in the switch not the element.
Mar 24, 2009 | KitchenAid KERC507 Electric Kitchen Range
Kitchen Ranges Logo
53 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
