Question about Hotpoint Aquarius WMA56 Front Load Washer
Change drum bearing on hotpint aquarius wf540 .
How hard is it too fix
  • 51 Answers
This is usually a very hard thing to do,, due to the fact that you have to separate the plastic drum housing to reveal the metal drum, and than you need to free it from the back portion of the plastic drum housing
Posted on Mar 13, 2009
I have a Hotpint Aquarius Washer/Dryer model number WDL520 that seems to have sprang a leak. First it was water only trickling from under the botton left hand side at the front. Now it gushes. Any ideas...
you could have a broken pipe on the filler or the seal has gone on the drum you would need to have a look, either way they are easy to fix or replace. drain pipe can leak if the pipe has come off the pump also check this but you will need to remove the case to get to look, always unplug the washer before touching any screws, remove case and look at the pipes and make sure they are seated in the right place.
Sep 09, 2017 | Hotpoint Aquarius WD640 Front Load...
Tip
How to change, fit and replace Washing machine Bearing
Here are a series of free videos to help you with your bearing problems and how to fix them
For all your free videos on appliance repairs remember to mark us down and leave feed back please
For all your parts visit our site http://www.apart4u.co.uk
This first video shows you how to diagnose the problem
The next Hotpoint video is on how to take the drum out
This Hotpoint video will show you how to change the bearings in the drum tub
the last one will show you how to change the spider or drum support as they are known
on May 27, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
The machine makes excessive noise when spinning and the drum feels to have some movement. I think that the bearing needs to be replaced. The machine is a 6 kg Not tried to fix it yet. Need advice on how...
quite a hard job if you never done this work before.....Depending on model bearings can be on its own kit or you will need HALF DRUM complete with prefitted bearings cost of this is around £75 ...plus labour at around 2 hrs.....If its under 5 yrs old Hotpont give a 5 yr warranty call charge is around £100,although this is all you would pay as the Parts are under warranty..Hope this helps.
Jan 06, 2011 | Hotpoint Aquarius WMA56 Front Load Washer
I have a Hotpoint WF540 washing machine. When it goes into fast spin, the spin cycle is quite noisy....on slow spin it is fine......could this be a bearing problem? If so how easy are they to replace?
Sounds like drum bearings most cases you need to buy half drum with bearings fitted if your very good at diy no problem if not call engineer.1st check concrete weights are not loose top and bottom.............you can buy parts @ espares.co.uk this will give you idea of cost which maybe quite high.
Apr 21, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Help to change bearings
For all your parts visit our sitehttp://www.apart4u.co.uk
utube.png You-Tube video "kG5HWQ0x2s0" placeholder (do not delete) utube.png
Apr 16, 2010 | Hotpoint Aquarius WF220 Front Load Washer
Aquarius WF540 sounds like bearings gone How do I take the top off to examine?
No need to remove the top.
Just spin the drum by hand from the front.
If it feels rough, or is rumbling, then the main drum bearings have failed.
There should be no noise at all.
Hope this helps.
Jan 15, 2010 | Hotpoint Washing Machines
Bearings very noisy on the drum
aquarius w f 541 1400 spin drum bearing noisy
Nov 14, 2008 | Hotpoint Aquarius WF000 Front Load Washer
How to replace drum bearing for hotpoint aquarius+ wf740
My machine is just over 3 years old and although there is no play in the rear drum bearing it is very noisey on spin.
It gets progessively loud the faster the spin speed.
Jun 18, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Drum bearings
as per soultion 2 this is a hard drawn out job involving a lot work and there is no guarantee the bearings will not shatter when trying to knock them out. better get someone in!
May 07, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WMA56 Front Load Washer Logo
257 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
