Question about Kenmore Oasis HE 27082 Top Load Washer
How to clean inlet filters?
I overdid it on the washer today and put in rugs that had way too much actual dirt. Duh. Anyway, I think the water inlet screens need cleaning but have no idea where they are. I also can't figure out how to pop the top on this machine (or do I remove the back with all those screws?) I think the top hinges back? Don't want to call the Sears man..... (Hector's a nice guy, but the call fee is huge and will be at least a week before they can come out). Many thanks
  • 5,911 Answers
I don't think inlet filters are going to solve your problem. Does the machine fill normally? If not, this was probably caused by mineral deposits and not the dirty rugs. It may just be a coincidence that a fill problem occurred at the same time. The inlet screens are located in the fill valves. You would have to shut the water supply off and disconnect the hoses to see them. There is a small screen inside each water inlet on the back of the washer. Washing heavily soiled items would not have anything to do with clogging the inlet lines. Now...if you overdid it with some heavy duty items like rugs, it would be reasonable to suspect that you may have clogged the pumps. I believe there are two pumps on the Oasis. One is a drain pump, and I think the other one is a recirc pump. You shouldn't have to open the top of the machine to get to them. The pumps can both be accessed by tilting the machine back and looking UNDER the washer. As you are looking from the front of the washer, the drain pump will be in the right rear of the machine and the recirc pump will be in the left rear. If you wish to check them, follow these steps: 1. Unplug washer. 2. Drain as much water as you can through the drain hose by using a shop vac. If the drain pump is clogged, this may not be possible. Or, it may take a little extra time. Otherwise, you may have a mess of water when you disconnect the hoses. 3. Disconnect hoses from pump(s) and look for any obstructions. You will have to tilt the machine backwards to accomplish this. You also will need to pull the machine away from the wall far enough so it will rest against the wall when you lean it back. Or, get the assistance of another person to help hold the machine back. 4. Carefully, disconnect wire harness from pump and remove mounting bolts. Remove each pump and look inside the impeller section. This is where dirt, sand and foreign objects generally get lodged. 5. Reinstall following the reverse order of the steps described. Now...if you go through all these measures and don't find anything, there is a filter in the wash tub under the inner basket. Cleaning this would require the removal of the nunator (agitator), tub ring and inner basket to get to. I can explain the steps to you if you like, but I don't know if this is something you would want to try to attempt. Cleaning the pumps and hoses is one ting, but removing the wash basket and other components can be a bit involved. Check the pumps first and let me know if you need further assistance. I hope this helps you.
Posted on Aug 04, 2007
Leaking water from the hose connections
Had the same problem w/the water inlet w/initial installation. When the water inlet was hooked to the faucet and into the washer, water leaked on the washer end. The manual tells you to put a new "flat" washer (provided) in the washer machine water inlet, but water still leaked. It's actually the not flat washer, it's more of an "U" shape washer that goes into the washer machine water inlet and fits right over the filter in the water inlet valve. Leak was solved, but faucet was on and water was not filling in the drum. Turn power on, select cycle, water level, and press start and water should start filling the drum.
Jul 28, 2013 | Haier HLP23E Top Load Washer
Washing machine drips water from top of tub.
THE WATER INLET FILTER IS MISSING , SO IT ALLOWS SOME FRAGMENTOF DIRTS INTO THE SYSTEM......U HAVE 2 LOSSE WATER INLET VALVE AND CLEAN
Feb 24, 2012 | Fisher and Paykel Washing Machines
I washed a rug and the back fell apart clogging the washer somehow so the water wont drain what do i do?
You may need to do more than just a filter cleaning. Your sump and hoses are all probably clogged too. Looks like you will have to take the washer apart and give it a good flush out.
WM2277 service manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 13, 2011 | LG WM2277H Front Load Washer
How do you clean or change the water filters?
If these are in the inlet part then you can back flush or use a good brush with a jet spray to remove all dirt within or out side the filters.
Dirt in the drain filters will be more and must be taken out to clean with water jet/air jet and brushing.
Sep 18, 2010 | Amana ALW480DA Top Load Washer
Washed a load of floor rugs now washer will not drain
sorry but one rug is ample for any machine,but the load weight alone is far to much on the machine,i have been in a testing factory and seen the things people put in machines and it would shock you,but back to your presant problem?basicly the whole dranage system is full of heavy dirt and needs cleaned badly.Try putting two dishwasher tablets through machine and see what happens but i must say i wouldnt have high hopes,i would think lower dranage pipes are going to be cleaned.if you want my help come back to me.adrian,,,,,,,
Aug 21, 2010 | GE Profile WPRE6100G Top Load Washer
Low water flow into washer. Rust-colored grit
Its normally held by two screws with a internay hose fitted to it should be quite simple o replace, make sure you fit inlet Filter too ,will stop dirt going into and damaging the valve in future, may be idea to get hot fill /feed tank cleaned....
Apr 06, 2010 | LG WM-2277HW Front Load Washer
My hotpoint water symbol is flashing
Check the water supply to the washer, make sure the inlet hose/hoses are not kinked or restricted in anyway.
Make sure there is sufficient pressure at the inlet valve..
Check the inlet valve filter is clean.
Please rate my solution.
Thanks.
Nov 16, 2009 | Washing Machines
My washing machine has had a high-pitched noise when it fills with cold water ever since we moved to a new house. This doesn't happen when it is filling with hot (or even warm) water. We've tried turning...
Are you sure you have the hot pipe on the hot inlet and the cold on the cold inlet ie red to red black to black (easily done), please check carefully. if OK then I think you have picked up some dirt in the inlet filter and this will need to be removed and cleaned,remove lid and follow pipes inside to plastic tank at top near drawer, filter housing can be seen there.
Aug 24, 2009 | Whirlpool Washing Machines
GE profile Harmony washer
The water inlet valve (also known as a mixing valve) is more than likely your culprit. If the water continues to run into the washer, the only thing that controls the water flow (besides the tap) is the inlet valve. If you live in an area that has hard water, or if you use well water, rust or sediment can be a common problem. If any has gotten beyond the sediment screens, dirt or debris may be preventing the small diaphragm inside the valve solenoid from closing properly. This will cause the valve to leak by. I would recommend you replace the valve since the screens are damaged. For future reference, clean with a cotton swab dipped in distilled vinegar. It does a good job at getting rid of deposits. If you post back with your COMPLETE model number, I can provide you with a part number and step-by-step instructions on how to replace it. In addtition, if you you're getting a lot of sediment, I may also recommend that you install an in line filter somewhere before the supply lines that lead to your washer. A whole house filter is a wise choice for this. This will prevent you from having frequent fill problems. I hope you find this information helpful.
Oct 02, 2008 | Washing Machines
Kenmore Energy Washer front load - about 5 - 7 years old
Hi mommo2,
I really hate those little rubber pieces that come off of those rugs, they really gum up everything. Just for future reference try to wash those outside with a water hose and a scrub brush. It will save you lots of money in repairs.
As for your current problem try to get as much out of the tub as possible. Then you will have to remove the small kickplate on the bottom of the washer. Get you some towels and a maybe a flat pan to catch some water. The panel will have a few screws around it that will need to be removed. Once you have removed the panel you will see your pump. The front of the pump has a filter that can be unscrewed and removed for cleaning. Unscrew the filter and get ready to catch some water. Maybe as much as a couple gallons. Once you have cleaned it out put the filter back in the pump and leave the panel off. Run the washer throught another cycle and clean the pump out again. You may need to repeat this several times. Hopefully this will solve the problem, if you still have draing issues you could have a clogged drain and for that you may need a plumber. Well good luck to you and I hope I helped. Mike Anderson mca0824@aol.com
May 02, 2008 | Kenmore 43142 Front Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
206 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
