Question about Retail Supplies
How can I warm the plates by myself? isn't it dangerous?
  • 27 Answers
Here are few methods warming plates. you can read all about them here:
http://www.thekitchn.com/tip-warm-the-plates-70284
Posted on Apr 22, 2013
1994 buick roadmaster temp light keeps turning on & off, but car isn't overheating, what can it be? What's your problem?
Usually a sign of a problem with the temp sensor or the wiring harness back to the computer.
Oct 13, 2012 | Buick Roadmaster Cars & Trucks
Clicking noise in bobbin area
it's possible that there is something wrong with the bobbin itself
try changing the bobbin to a different one.
try changing the needle
try cleaning under the needle plate & in the bobbin area for lint.
or the bobbin isn't setting in the bobbin case correctly- reinsert a
another bobbin into the bobbin case & see if that helps
or it could be something is wrong with the hook & hook race-
if the machine keep making the noise I suggest having the machine
checked at a repair shop
Sep 05, 2012 | Janome Sewing Machines
What range of cost to fix worn front suspension on 04 montana?
Have to ask a merchant of your choice
Only a person in business, can put together an
estimate for you.
I would do that work myself & just take it for
alignment
I wouldn't put much money into any van type vehicle.
Keep in mind that one isn't made any more & had many
issues.
Jun 13, 2012 | 2004 Pontiac Montana
Should the engine be running when adding coolant to my 2003 cadillac cts
If you just drained it & are refilling,then yes,the engine
should run & warm up until the thermostat opens & you
keep adding.
If it isn't hot & circulating thru the entire system, you won't
get it close to full with the rad cap off
Jun 10, 2012 | 2003 Cadillac CTS
Bobbin thread too loose in singer 9805c
change the needle
make sure the thread isn't coming off the thread take up lever
clean under the needle plate & bobbin area for lint or loose threads
try a different thread
make sure the fabric & needle & thread are compatable
do you have a manual?
Go to the singer website
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example 9805 ) don't a the C in the box
& click search--if you don't find what you need--contact singer customer service
Mar 19, 2012 | Singer Sewing Machines
The refrigerator is not cooling
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 26, 2011 | Amana Refrigerators
The temperature is staying constant at 51 degrees - and the freezer won't go below 35. What is preventing it from dropping to 42 & 0 respectively?
Your fridge is probably suffering from a fan failure or defrost circuit failure. One (or possibly more) of the following components has failed: 1) the defrost terminator or sensor, 2) the defrost heating element or 3) the defrost controller / timer. Items 1 & 2 will be found in the freezer compartment - behind the back wall. The 3rd item can often be found in the toe space at the bottom of the fridge - behind a kick plate. The fan I mentioned is located in the freezer - in the cooling coil compartment. It is used to pull air over the coil to cool it and circulate it in the freezer - and direct a portion of it into the fresh food compartment as well. If it has failed, temperatures in both the freezer and fresh food compartment will rise.
Before we go further - check and clean the condenser coils on the bottom of the fridge with a vacuum. They may be clogged with dust and dirt. Listen for the compressor and fan - are they running? Since everything inside the fridge is warm and getting warmer - the compressor should be running to try to cool it. If left to run like this for a long time however, can cause the compressor to fail. This is usually a deal breaker for repair due to cost. If the fan or compressor isn't running - you should probably call a repair person.
If you don't know how to work with electrical meters and tools or are not comfortable working in tight spaces (back wall of the freezer) with live electric parts, you should call a repair person. Also, refrigerants are under pressure and are very dangerous. If allowed to escape from the tubing, coils, etc. there is a very real danger of instant frostbite if it comes in contact with your skin. You can be blinded if it sprays into your eyes. These reasons make me believe that this is a complicated DIY type job and really isn't a good one for a beginner or even an intermediate to attempt. On the plus side, parts are relatively inexpensive, and a qualified person should be able to quickly diagnose the problem. Labor rates and parts markups can bring this repair up into $200 and up range, however.
If you can't swing that amount of money right now, unplug the fridge, empty the freezer (& fridge if needed) and completely defrost the the freezer. If you access the freezer coil behind the inside back wall, you can greatly accelerate the defrost process by leaving the freezer door open - or even faster still by directing a blow dryer at it. Once all the frost is melted, plug the fridge back in, allow to get cold & reload the freezer. Depending on how humid it is in your kitchen, you can put off the repair at least a month or more. If after defrosting it still fails to cool down, the freezer compartment fan described in the top paragraph has probably failed. Ideal temps for fresh food is about 34-36 degrees and the freezer is about -5 to 0 F.
If / when you do finally call, for service, have the freezer emptied & defrosted already - will save the defrost time by the repair person.
If you are comfortable performing this work, let me know and I'll get you more information. I hope this was helpful and good luck. Please rate my reply - thank you.
May 03, 2011 | Maytag 22 cu. ft. Bottom Freezer...
I have a Melitta ME1MSB that no longer heats the water or warming plate. can this be fixed?
I have the same problem and just talked with a local repair person. He said that this isn't fixable because he wouldn't be able to get a heating element for it. I am going to keep watching ebay for an ME1MSB that is missing the carafe or the basket and buy it, then use it for parts.
Sep 03, 2010 | Coffee Makers & Espresso Machines
Kenmore "Hot Surface" light
hot surface light is turned on by a auxiliary switch across the plate. it is possible that the switch has stuck in the closed position. it is also possible that the plate is not turning off. feel the plate and check if it is at all warm. if not, then the auxialuary switch is stuck closed. not dangerous. to fix means replacing the limiter which is the rod you can see across the plate. sometimes you can only get the complete plate with limiter which is a bit pricey
Jun 26, 2008 | Kenmore 30 in. 42701 / 42702 / 42709...
Retail Supplies Logo
958 people viewed this question
Top Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Retail Supply Expert? Answer questions, earn points and help others
