LCD bad screen - Computers & Internet
  • 32,281 Answers
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Posted on Apr 22, 2013
Setting up another laptop,to check a bad lcd screen
First when you attache the Ac adapter are there any lights do you see any lights? sometimes there is a light by the connector (jack) where you attach the AC. Otherwise this might be a mobo problem. Have you try to attach an external monitor? The top of the question mentions a desktop E520 but below points to a LCD. I am assuming a laptop. If you have another laptop with the same LCD screen then you can take the suspected bad LCD and place it in the good laptop. Also you can take the good LCD and place it in the bad laptop. First read the first lines of the preliminary troubleshooting.
Aug 09, 2014 | Dell Dimension E520 PC Desktop
No backlight
A) Replacement LCD screen backlight could be bad.
Happens. Sometimes you get a bad part. (Bad LCD screen assembly, in this case)
LCD screen may not be the correct one.
http://support.gateway.com/s/Mobile/2008/GodzillaFX/2528410R/2528410Rsp2.shtml
http://support.gateway.com/s/Mobile/2008/Godzilla/2528407R/2528407Rmv.shtml
A screen Inverter, and an LCD screen; are a MATCHED unit.
B) Screen Inverter:
May be bad, or the Wrong one
C) You may not have the screen Inverter, connected correctly to the Backlight.
Connections aren't tight.
D) The Display Cable TO LCD screen connection may not be tight, or correctly connected.
I know the display shows graphics, but a poor connection of Display Cable to LCD screen, can make the Backlight dim out.
I'm betting it is a poor connection, or the wrong screen Inverter, or wrong LCD screen.
Regards,
joecoolvette
(Be shame to kick that laptop to the curb. Nice laptop)
Jan 07, 2013 | Gateway P-6860FX Notebook
Fuzzy pink screen on hp dv2000
pink and fuzzy, what a place to be, no?
no photo posted, so not much anyone can do but guess.
sounds(seems) like a bad LCD
if the PC was made in 2008 the nvidia GPU chip has solderballs
defect. try twisting the screen then base see if screen changes,
yes= bingo. for bad GPU/LCD.
this PC is carbon dated at year 2007, so is in the window bad GPU.
no screens post
do the twist (no not chubby checker ) but by hands.
if the screen changes, with gentle twists the GPU /LCD is bad.
if only the screen frame changes the lines or colors twisted the screen LCD is bad (sure it is cable is falling off inside , only happens on molested, LCD, (service) as HP has it taped down secure day one, but others forget to put it back correctly.
Feb 18, 2018 | HP Computers & Internet
Lines at bottom of screen on asus x83v
Your lcd screen is going bad or your video card inside the computer is bad. To isolate the problem Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the laptop. If the Borrowed monitor displays ok then your video card is good and the lcd screen on your laptop is bad. If the Borrowed monitor displays the same lines as your lcd screen, then your video card inside the computer is bad.
The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
May 29, 2012 | ASUS X83VB-X2 Notebook
I haveMy compaq presario CQ40 and my monitor screen got flicker always for past few days and more red horizantal lines @bottom of the screen, where i couldn't see the data,time,date... Plz help me...
This is usually a sign of either a bad LCD screen cable, a bad LCD screen, or a bad display adapter.
If you connect an external monitor & you get a picture without these red horizontal lines, then your display adapter is OK.
Diagnosing a bad LCD screen cable or a bad LCD screen requires that you disassemble the LCD screen panel, & swap them one at a time with a matching part. This way you can identify which part is causing the problem & replace it.
Sep 02, 2011 | Compaq Presario CQ40 Series Laptop Charger...
Blank screen when turned on.sound is fine though.when i use external monitor it works on the external monitor.
Hi. I have 2 units of T23, 1 unit T22 and T30. All of them has the same problem as yours. 3 units has bad inverter and the other 1 has bad CFL. Inverters can be replaced but if you have bad CFL, it is better to replace LCD screen. If your problem is CFL, you will be able to see a very faint image on your LCD screen. If the LCD is completely black and you can't see anything, then it is an inverter problem.
Inverter is located below the LCD screen. You need to remove the LCD face plate to access the inverter. Please click here for the step-by-step instruction how to access the inverter or replace the LCD screen. Inverter and LCD are available at ebay.
Note: T23 has thin plastic parts that can be easily broken when disassembling.
Good Luck. Let me know further.
Jun 28, 2010 | IBM ThinkPad T23 2647 Notebook
My lcd monitor loses the picture. it is still on
Sounds like the bulb in your LCD screen is going bad, or the LCD inverter or cable is going bad.
If moving the screen back and forth causes the LCD screen to show a picture normally, but intermittently, then the LCD cable is probably bad.
Jan 26, 2010 | Computers & Internet
15" Magnavox LCD TV Screen
Without checking much. my guess is trash it, or find one on ebay that has a bad backlight or something else good on your's that is bad on it, that you can swap. I've never seen anything with an LCD screen that cost less to replace than item cost to replace.
Sorry for the bad news.
Feb 17, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Staining on LCD tv screen
The LCD screen is bad this may have been caused by presure exerted to the screen fracturing the cells of the LCD. any way the LCD is bad and needs replacing.
Dec 27, 2007 | Philips 32PT6441/37 32" TV
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
