Question about Philips 42PF9630A 42 in. Plasma Television
Just bought a philips 42 inch ambilight plasma t.v,and didnt know the plastic screening round the out side is supposed to light up, how do i go about setting this up?
    Scholar:
  • 73 Answers
Some models didn't come with the ambient light, the sides of the TV speakers will have long clear lenses that look like flouresencent bulbs. If so, Marvic is right. The button on the remote should turn it on. Its not so visible in bright room tho.
Posted on Mar 23, 2009
Testimonial: "turns out the philips t.v. i bought wasnt ambi light as it goes,my friend has exact t.v. with the ambi light and remotes for both t.vs are different."
Bottom left button on your remote should turn the light on and off. if this doesn't work sort through the options on remote and select ambiant light functions
Posted on Mar 19, 2009
Ambilight screen
Should be a back-light problem itself. If you wish to know more about the back-light system of this Philips TV, check this link. Pull up older posts there, either by its left side bar, or see it in Timslide option. http://electronicshelponline.blogspot.com/
Jun 24, 2013 | Philips 42PFL5603D 42 in. LCD HDTV
50 in philips hd plasma with ambilight model number 50PF9631D/37
The x-sus and y-sus panels have some fuses,check to find out wich panel is broken and replace.
Sep 04, 2009 | Philips 50PF9631D 50 in. HD-Ready Plasma...
I have a philips 42PF9641D/10 and the ambilight on the left side will not come on (lcd tv) any ideas? On turning on the TV both ambilights came on then the left side went off after about a minute!
probably you got a processing unit problem, which makes your tv stopping recognizing the screen information .
you should try resetting all factory default settings, if this doesn't work, you will have to take the TV to an assistance center .
Jul 30, 2009 | Philips 42PF9631D 42 in. Plasma Television
42 inches samsung plasma screen with sound and without image
Check this link to find the LJ41-02759A board for your TV. These boards fails quite often and the TV will power ON but with the same symptoms as yours.
Jul 15, 2009 | Philips 42PF7220A 42 in. Plasma Television
Phillips ambilight 50 in red light problem
I had this problem on a 42" Philips Ambilight. After reading in another forum, opened up the back, and found 2 leaking capacitors on the center circuit board (main power supply pc board) toward the bottom. Tops of the capacitors were bludged out (10v 3300uF) and leaking electrolytes. Unsoldered the old ones myself, went to Radio Shack. They were out, so order 12 on ebay for $6.63 including shipping. Resoldered and works fine. Can't do it yourself? Take the board out (just unhook the cables & unscrew it ), and take it to a computer shop or tv repair or someone who knows how to solder, and have them change them. Piece of cake!
Jul 10, 2009 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Got 2 faint white lines on screen on philips 42 lcd ambilight
Sounds like plasma burn in. I'm fairly positive this TV has a white out burn in removal in the menu somewhere. Look for it. It should be a program that makes colored static all over the screen or a white scrolling bar followed by black fading into white again. Run it for an hour or so. If that doesn't fix it, there's not much else you can do.
Jan 05, 2009 | Philips 42PF9630A 42 in. Plasma Television
Phillips plasma problem
I have the service person coming Thursday to look at the same problem. Will let you know outcome.
Aug 03, 2008 | Philips TV Tuner Video Capture PCI Card -...
Philips ambilight 42inch plasma
You can fix this yourself with a software upgrade - get the upgrade from Philips website - go to www.usasupport.philips.com, enter your model number, click on the verison of your model ending in /37, and click on "Software & Drivers"; click on the link that says "Firmware Upgrade - Software". Instructions are on the same page - make sure you only transfer the .upg file, not the entire zip file to a portable memory stick.
Jun 08, 2008 | Philips 42PF9630A 42 in. Plasma Television
Philips Ambilight
most likely its the audio amplifier board where your having the problems
Jun 05, 2008 | Philips 42PF9630A 42 in. Plasma Television
Philips 42PF9630A 42 in. Plasma Television Logo
234 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
