Connecting that undervoltage release to siemens mccb VL160n
2 Suggested Answers
  • 101 Answers
SOURCE: siemens mccb vl160x is not holding its on position
Sounds like a bad breaker. Sometimes, breakers appear to be in a trip position, but they're actually in the on position. If you've had this breaker working for a while, and it began tripping under load - then I'd replace it. If you just purchased this breaker and are assuming it's not holding in the on position, then I'd install it - because it could just appear that way. Or, you can bring it to your local electrical supply store for a second opinion. They're pretty knowledgeable, and will help you for free. But, giving you credit - I'm sure it's a bad breaker. This is usually a pretty good indicator of it going bad. If you have any further questions, etc. that you'd like to ask or share - feel free to contact me again and I would be willing to help you. Good Luck! Jim
Posted on Apr 07, 2010
Mccb
meaning the breaker is getting hot? That is how a breaker works. It gets warmer the more current that goes through it. If there is too much current it get too hot and trips out.
If you are operating very close to the limit for extended periods of time the breaker may get long term heat damage. You need to reduce the load on the breaker
Jun 07, 2013 | Electrical Supplies
Activating shunt trip circuit on vl160n
A shunt is always energized and it has a purpose. The purpose is to bypass some of the load from the main circuit. It would be tripping due to overload
Apr 26, 2013 | Siemens Electrical Supplies
My vaillant ecoTec plus shows F49 , new vrt 360
F.49 eBUS undervoltage Short circuit on eBUS, overload on eBUS or two power sources on eBUS with different polarity F.61 Gas-valve control defective Short circuit/earth (ground) leak F.49 eBUS undervoltage Short circuit on eBUS, overload on eBUS or two power sources on eBUS with different polarity F.61 Gas-valve control defective Short circuit/earth (ground) leak i pasted the answer below hope it worked
Aug 02, 2010 | Heating & Cooling
CAN YOU TAKE THE SHUNT TRIP OUT OF A OLD EA203B 225 AMP MCCB AND PUT IT IN A NEW EA203B 225 AMP
You will no longer have a UL listing on it. Insurance companies love that excuse
Apr 27, 2010 | Fuji Ea203b 150a Circuit Breaker
Siemens mccb vl160x is not holding its on position even if there is no input supply to the mccb
Apr 01, 2010 | Siemens /ITE 100Amp 3-pole molded circuit...
Need IP change on gateway
  1. Log into the router's admin console. (Often http://192.168.1.1/)
  2. Release the IP address. (Method varies by router manufacturer)
  3. Turn off router, ethernet hubs/switches, and the cable/DSL modem.
  4. Leave off overnight.
  5. Turn everything back on.
Dec 13, 2008 | Computers & Internet
2001 C240 ''Undervoltage Consumer Defective''
The same thing happened to me and it turned out to be the alternator. Need to replace your alternator. Easy check, start the car and check the DC voltage of the battery, with the car running you should read around 14 volts. If you are reading 12-12.25 volts then the alternator is not generating.
Nov 18, 2008 | 2001 Mercedes-Benz C-Class
UNDERVOLTAGE CONSUMER DEFECTIVE
i have the same problem with my 2001 C240 and my a/c does not work properly as a result.
Oct 31, 2008 | 2001 Mercedes-Benz C-Class
Call Waiting Siemens 4200
It's the "MEM" key at the very bottom right.  I had the very same question and just found the answer at http://www.epinions.com/content_67070561924
(The last paragraph of the review gives the answer.)
When you hear the beep, press and release the MEM key.  The 2nd caller's phone number appears on the screen to indicate you've been connected to the 2nd caller while the first caller is put on hold.
To get back to the first caller, press and release MEM again: the first caller's number will appear on the screen.
I don't know if there's a way to see who the 2nd caller is without actually connecting to them.
Apr 03, 2007 | Siemens Gigaset 4200 Cordless Expansion...
Computers & Internet Logo
David Payne
David Payne
