Question about Kenmore Washing Machines
As goes through cycle starts and stops until done
No matter what agitate setting or cycle I set the machine on the washing machine will fill just fine then once it starts agitating will stop after a moment pause for a couple of minutes then start again just to agitate for maybe 30 sec. at a time. . Will continue this until cycle is completely done. Take 7 HOURS for normal cycle to finish. Will then even start and stop to drain and spin so no sure what is going on.
  • 15,935 Answers
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
Roper washing machine does not fill for rinse cycle. Goes directly to rinse agitate without water.
Without Model number I am only guessing but I suspect you have a blocked sensing tube that travels from the Level selector switch to the side of the tub somewhere. It is possible for this plastic tube to become partially clogged and not allow trapped air to vent when tub is drained of water. Usually this problem manifests itself as an overflow of the tub. Check the full length of this clear hose and see if the end nearest the tub looks like it may have debris or dirty detergent clogging it.
This hose is pushed onto a nipple mounted to a reservoir on the side of the tub. Push a thin copper wire 4-5 inches into the those after removing from nipple and also down into the nipple an inch or two before reinstalling the hose to the nipple. You MIGHT even blow into the hose while you have it off and you SHOULD hear a clicking sound coming from the level selector switch body.
Good Luck. Come back with Model number under lid if that doesn't help.
Nov 28, 2015 | Roper Washing Machines
General Electric Washing Machine want agitate. The washer fills, spins, drains but simply stops agitating or washing during different cycles. I have checked the lid switch, coupling under the agitator and...
The water level switch may be going bad. As the water level rises to the proper level, it switches a set of contacts inside to stop the water fill and cause the machine to start agitation. Make sure machine is empty before you replace the water level switch---it works off of air pressure from a small hose attached to it.
Feb 16, 2015 | General Electric Washing Machines
Centennial series stops agitatimg
Usually a top loader will not agitate until the fill sensor is satisfied. If the water has shut off, and is up at the desired level, the fill sensor has done part of it's job. Check the connections there, and at the timer. It may just be a loose connection.
Nov 29, 2013 | Maytag Centennial Series MVWC200XW
Amana NFW7300WW Washer
does it seem to take a long time to fill-you have gone through alot of work on this machine already-frustrating! Is it filling, agitating,then draining-where is it stopping-we will get you through this, hang in there-Denny
Oct 19, 2013 | Washing Machines
Washing machine won't drain but it will spin.
sounds like a motor problem, the motor turns 1 way to agitate and the other way to drain and spin
Feb 16, 2010 | Kenmore Washing Machines
Agitator starts before water fills. When adjusting
There may actually be more than one setting on the diaphragm control, or you may two diaphragms each with their own setting control. I hope this helps you! Good luck!
Dec 29, 2009 | Washing Machines
Kenmore Series 90 top loading washing does not fill with water
Well you eliminated the fill valve when you said it does fill with water. More than likely its a bad connection on the control board. I wouldn't betmy paycheck on it but thats where I'd start. Take the cover off the control board and while machine is on being really careful wiggle each wire until the water starts in the tub and you have found the problem.
Aug 23, 2009 | GE WVSR1060A Top Load Washer
My thintwin spincycle is not working
Yes, although I would hate to think he meant to. After looking at the diagram of your machine, I can only think of one thing he might have done. Did he say anything about needing a coupler? This connects the motor to the transmission. If he left this off, it would fill and pump out but not agitate or spin you clothes. Here is how to find out. Set machine to wash a load. Don't put any clothes in. Watch the machine. After it fills. It should start to agitate. Listen to see if you here the water is moving around. Then advance the machine or just let it run until it goes into spin. After it starts spinning open the lid. If the tub is spinning you should see it stopping when you look real fast. If it is not sloshing in wash cycle or spinning in spin cycle, you have not got a coupler on it or it broke after he put it back together. The only reason he would have had to remove it is if you needed one and after he removed it he found he didn't have one to replace it with or he just forgot. The coupler is a real common part that goes bad. I myself replace them on most every machine that has them when I open one. I only do this if the customer is there so that I can show them the ware on it so that they will not think I'm just replacing parts to run the bill up. If you would, please let me know what you find out. Thanks
Please rate if helpful.
Aug 02, 2009 | Whirlpool LTE5243D Top Load Stacked...
Must repeatedly slam top loading door shut for machine to start
on the inside of the lid there is a lid switch hole that a plastic tab goes down through the switch could be bad or the screws holding the switch in could be lose or broken
Mar 28, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
21 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
