Question about Home
Ps3 termostat sensor - Home
Teperature needle is going straight to top when engine is started.sensor or termostat problem?lancia delta hpe 1996
Check the wire to the sensor is not touching the engine and shorting out. Replace the sender unit.
Oct 30, 2013 | 1995 Lancia Delta HPE
How to change thermostat
The Termostat fit inside the Termostat Housing. It normally links to one of the radiator hoses leading from the engine block or radiator. Depending on the model you have, the termostat housing needs to be opened, the old termostat removed and the new termostat inserted. It's quiet simple. Before closing up, make sure that the both surfaces on the housing are clean and free from dirt and old sealant. If you remove a gasket, then replace with new gasket. If the housing takes a rubber O ring, then it is advisable to replace this.
Good Luck
Dec 29, 2011 | 2004 GMC Yukon
Runs fine in park, boils over in 1 block when driving, but meter does not reach 1/2 way to hot mark
I'm willing to wager that you've either get a pinhole leak in your radiator (I doubt it) or you have a blown head gasket. When you're driving, do you see white smoke out of your tailpipe? If yes, the head gasket is likely blown.
Dec 19, 2010 | 2002 Dodge Intrepid
Is over heating, has new ratiator, termostat, hoses, sensor in the termostat and still over heating
Does the electric fan work...if not the thermatic sensor is faulty, quite common.
Oct 15, 2010 | 1999 Honda Civic
How ican fix the high temprature problem
Water level, good thermostat, good water pump, fan working? All things to check.
Sometimes an airlock will prevent water circulation
ALSO verify your temp gauge and sensor is working correctely. A failure of these may appear as high temp and even shut machine down if the sensor is bad.
Apr 26, 2010 | Pramac GBW30P Encl Diesel Genset w/Perkins...
2000 Buick LeSabre No heat, blows cold air.
check to see if both hoses are hot going to your heater core if they are then core is fine.That would point to your temperature sensor.
Feb 07, 2010 | 2000 Buick LeSabre
How much does a MAP Sensor Cost, and a Termostat?
MAP sensor runs between $81.00 and $117.00.The thermostat runs $ 43.00 it includes thermostat and water outlet and seal.
Jan 05, 2010 | 2003 Chevrolet TrailBlazer
Service engine light is on
if its a 6 cylinder the sensor is located on driver side behind the alternator .the sensor alone is about 80-100 dollars. but it is difficult to get to if you dont know what you are doing. the shop should charge you 150 to have this done.
Apr 19, 2009 | 2003 GMC Envoy Xl
I have a 2000 pontiac grand am, why dont the
Good day
You have a bad temp sensor,or loose wires for the sensor. The sensor is usually located in the rad or neer the termostat on the block.
chears
Apr 08, 2009 | 1988 Honda Accord 4 Door
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
