Question about Apple iPod Touch 8GB 32GB 64GB 3rd Generation iTouch Zebra Skin Case Cover Protector Pink and Black
Ipod is disabled for22606452minutes how to fix
How to restore it
  • simone ross Apr 22, 2013
    how to fix disabled ipod touch
  • Apple Master
  • 7,482 Answers
Hi Simone ross
1...Make sure you have an Internet connection, you may need to download new updated versions of the iTunes or iPod Software.
2...Download and install the latest version of iTunes.
3...Open iTunes.
Connect your iPod to your computer using the USB cable that came with your iPod.
4...After a few moments, your iPod will appear in the Source panel in iTunes.
5...Select your iPod in the Source panel.
You will see some information about your iPod appear in the Summary tab of the main iTunes window.
6...Click Restore.
7...A progress bar will appear on the computer screen, indicating that stage one of the restore process has begun.
When this stage is done, iTunes will show one of two messages with instructions specific to the iPod model you are restoring.
8...Disconnect iPod and connect it to iPod Power Adapter this typically applies to older iPod models.
Leave iPod connected to computer to complete restore this typically applies newer iPod models.
9...During part two of the restoreing process, the iPod will display an Apple logo as well as a progress bar at the bottom of the display.
NOTE: It is very important that the iPod remain connected to the computer or iPod power adapter during this stage of the restore.
10...After the restore process is complete, the iTunes Setup Assistant window will appear.
It will ask you to name your iPod and choose your syncing preferences.
Please take time to rate me.
Bud
Posted on Apr 23, 2013
Itouch disabled
You may reset or restore your iPod for a try, this can fix many general iPod problems. Or you may take a look at this iPod FAQ, it's informative.
http://www.mac-dvd.com/ipod-tips-and-ipod-faq.html
If it doesn't work, you can contact Apple technical support for help.
Dec 08, 2013 | Audio Players & Recorders
How do i fix my disabled ipod
Step 1:
If you enter the wrong passcode repeatedly on an iPod Touch, it will display a message that says "iPod is disabled." At first, the iPod will only be disabled for a minute, but if you continue to enter the wrong passcode, it will become disabled for longer periods of time, and finally, you will need to connect it to the computer with which you last synced it. From here, you will need to restore the iPod Touch to factory settings.
Open iTunes. Click "iTunes" in the upper-left corner, then select "Check for Updates" to ensure you have the latest version. Connect your iPod Touch to your computer with the USB 2.0 docking cable. Click your iPod's name under "Devices" on the left-hand side of the iTunes browser. Click the "Summary" tab. Click "Restore." Follow the prompts in the dialog box that appears to finish the restore. Your iPod will return to factory settings. Choose to set up the iPod as a new iPod or from a backup in the screen that appears when the restore is complete.
Mar 29, 2013 | Apple iPod touch
IPod 4 is disabled
Heres what you must do,However, be aware that this process will erase all data on your iPod Touch. To fix the disabled problem, you must go into DFU Mode and restore.
DFU Mode
  1. Connect your iPod to your computer
  2. Turn your iPod Off
  3. Press and hold the power button for 3 Seconds
  4. While continuing to hold the Power button, press the home button as well for 10 seconds
  5. While holding down the home button, release the power button for another 10 seconds
  6. iTunes should detect the iPod in recovery mode, press OK, and restore your iPod, from this point forward you may release the buttons. If you have not reached this point, then you have not entered DFU Mode
Your iPod should be running again after this process. From this point you can restore from a backup, if there is one present.
Mar 22, 2013 | Apple iPod touch
My iPod touch 4th gen is disabled and won't shut off, what do I do?
The iPod 4G (fourth generation) is easy to restore to factory settings. This may reinstall the software, and it always wipes all music, video and other data from the iPod. Restoring is the most effective way to fix problems with the iPod that haven't been fixed through traditional troubleshooting. You will not be able to retrieve data from your iPod 4G once it's restored, so make sure you back up your information first.
Plug your iPod 4G into your computer with its dock connector USB cable. Install the most recent version of iTunes and open iTunes. Wait a moment for your iPod to appear in the side bar. Click on your iPod in the side bar and select "Restore." A pop-up window will ask if you're sure you want to clear your iPod and restore to factory settings. Click "Continue" and enter your password, if prompted. Leave the iPod untouched and on a flat surface while it restores to original settings. It's important that you don't try to disconnect or use the iPod while it's restoring. You'll see a progress bar either on the iPod or your computer that indicates how far along the process is. Select your new syncing settings (automatic sync or manual) when prompted after the restore is complete.
Feb 10, 2013 | Apple iPod touch
My ipod is disable for 21023384 mins how can I fix this problems
That's kinda long time! But no problem, you just have to follow my instructions on how to put your iPod touch to DFU mode and restore and this problem will be history.
Only thing though is that all data from your iPod will be deleted.
For more iPod touch and iPhone tips, click here.
Feb 09, 2010 | Apple iPod touch
Ipod is disabled connect to itunes how do i fix it
Use the Five Rs to restore the iPod. You will lose the data that is currently on it if you restore but you can always re-sync the data to the iPod.
http://www.apple.com/support/ipod/five_rs/
-=/ Daft Tech /=-
Oct 21, 2009 | Apple iPod touch
My ipod touch is disabled for about thirty years and i can only turn it on and off!
Two reasons this is disabled for so long.
1. You have entered the incorrect 'power on' password many, many times.
or
2. You have jailbroken (jailbreak) your iPod Touch and one of the apps you have installed has caused the problem. Possibly a malicious app.
Two ways to fix it. Either wait 4317939 minutes or restore it using iTunes.
The first link below gives details of why a non-jailbroken iPod Touch is disabled.
Second link gives instructions on how to restore your iPod Touch using iTunes.
http://support.apple.com/kb/HT1212
http://docs.info.apple.com/article.html?artnum=305744
Jul 03, 2009 | Apple iPod touch
I dont know what to do please help me my ipod touch is disabled.
press and hold the home and power buttons, when it turns off DO NOT let go of the home button continue holding until it restores itself then connect it to your computer and restore it. unfortunately it will erase everything.
Feb 02, 2009 | Apple iPod touch
IPOD TOUCH DISABLED.
try restoring your iPod.
1. Make sure your iPod is on and connected to iTunes( does not matter if detected or not)
2.Now, hold the home button and sleep/wake button together until the screen blacks out
3. When the screen blacks out, immediately release the sleep/wake button but keep on holding the home button for like 10 seconds maybe or until iTunes says it has detected an iPod in recovery mode and must be restored to be used
4. Now restore it and I hope it turns out better!
Or , option number 2. you try contacting Apple and tell them the problem or go to an Apple store near you and get them to fix it.
Hope this helps!
Oct 06, 2008 | Apple iPod touch
8GB iPod Touch Disabled
Thanks to everyone who provided solution inputs. I finally have my iPod back. The solution is: 1. Turn of your iPod. 2. While holding down the 'Home' button, connect to iTunes WARNING: Doing this will return your iPod back to original 'out of the box' settings and you will lose everything. On the bright side, you get a 'fresh' start and it will auto update to the most recent software version. Good luck!
Jul 14, 2008 | Apple iPod touch
Apple iPod Touch 8GB 32GB 64GB 3rd Generation iTouch Zebra Skin Case Cover Protector Pink and Black Logo
53 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
