Question about RCA 27F530T 27" TV
Standby light is on, but power switch does nothing
When going through the menu screen, I clicked an "off" option to "on." The screen read "FPA ON" seconds before the tv shut itself off. The TV turned off immediately and will not turn back on, but red light (displaying power) is still on. Is there a physical override on the computer, or do we have to do something through the TV?
  • stan glicas Aug 04, 2007
    the rca is model #27F522T.
  • 398 Answers
The FPA (Front Panel Access) lock is on. This allows you to prevent kids from using the set when you are not there and disables the buttons on the front of the TV. The set should turn on with the remote only, and then you can go back into the menu and turn off the FPA, also called child lock.
Posted on Aug 05, 2007
  • 1 more comment
  • michael_neca
    michael_neca Jul 09, 2012
    What if you don't have a remote
  • Theorist Jul 20, 2013
    You need to buy an RCA universal remote in order to turn your TV back on and access the FPA control. This is a conspiracy through RCA to make its consumers buy universal remotes.
  • Lisa Schaller Aug 28, 2013
    I have universal remote but you need to turn on tv to program remote
Sky box green light on permanent
Sounds as if the software is corrupt. Try a forced software update...
1) Switch the digibox off at the mains power, so no lights are displayed on the unit
2) Press and hold the BACK UP button on the digibox (not the remote control)
3) Whilst holding, switch the digibox back on at the mains power so the red standby light is displayed
4) Wait approximate. 10-20 seconds for the remaining 3 lights to display, at which point you can release the BACK UP button
5) Allow the digibox to download the latest software, which can take 10 minutes before returning to standby
6) Leave 60 seconds then power up as usual
A software update/refresh will leave your recordings intact. You won't lose anything.
If this doesn't solve your problem, then the next step is more drastic. It's a Full System Reset and Planner Rebuild. Be advised though: Your recordings are at risk!
1) Switch your digibox on
2) In sequence, press on your remote 'SERVICES > 4 > 0 > 1 > SELECT' (this will access the hidden menu)
3) Select the relevant option (usually the bottom two) and follow the on-screen prompts (note that it's likely your digibox will reboot between processes)
Applies to Sky+HD Digiboxes only, running latest EPG
1) Press Services on your remote control. 'Options' in the Top Menu will be highlighted in orange.
2) Press the Right arrow once to highlight 'Settings' in the Top Menu.
3) Now press the Down arrow once to highlight the 'settings' tab in the Middle Menu.
4) Press 0, 0,1, Select on your remote in quick succession. The 'Setup' tab will then be highlighted within a hidden menu.
5) Select the relevant option and follow the on-screen prompts (note that its likely your digibox will reboot between processes)
Sky Digibox Planner Rebuild / Full System Reset (if stuck in standby)
Applies to Sky+ and Sky+HD Digiboxes only
Same as above, but applies if your digibox is stuck in standby and you cannot get to the hidden menu:
2) Press and hold the 'right and left arrow' buttons on the digibox (not the remote control)
4) Wait approximate. 30 seconds for the blue Sky+ ring of lights to display, at which point you can release the 'right and left arrow' buttons
5) Press 'SELECT' on the digibox (not the remote control)
6) Now the system will format the hard drive, the blue Sky+ ring of lights should spin backwards
7) Allow the system to format, which can take 10 minutes before returning to standby
8) Try to power up!
Sep 02, 2014 | Televison & Video
Turn off fpa lock without remote
Install an IR Remote App in android phone. The app link below worked for me to remove the fpa lock on. Configure the App for your RCA TV. Set TV as Device type, RCA as the brand. and choose the model (e.g., TV 20 F420T) also, select the Alternate IR Driver.
All the options of the command may appear in a list form. Close that and an actual remote with buttons should appear.
Then Power your tv will turn ON. Press the Menu. Pressing the Channel Down/Up Button to navigate to Preferences. Press OK button on the screen.. Then Navigate to FPA Lock. Press OK again. THis will turn the FPA Lock to Off.
Then you could use your on-TV buttons ZappIR Universal IR Remote Android Apps on Google Play
Nov 23, 2011 | RCA TruFlat 27F520T 27" TV
I have a TruFlat RCA model # 27F520T have lost original remote and FPA lock is on how do I unlock without original remote? Dish universal remote not working to unlock tv, it will pull up menu but cannot...
Try this -
  1. Press menu for main menu.
  2. Press CH + or CH - to highlight preferences.
  3. Press "OK" to enter preferences submenu.
  4. Press CH + or CH - to high light "FPA"
  5. Press VOL + or VOL - to turn the FPA on or off.
  6. Press MENU repeatedly to exit.
  7. Back to normal
  • FPA stands for Front Panel Lock. It makes it so kids don't push all the buttons on the front of your TV. The power button on the TV will still work and the remote will still function as normal.
Regards, Tony
Apr 30, 2011 | RCA TruFlat 27F520T 27" TV
My tv wont come back on fpa lock on
Press Menu Button from any Remote control ( RC) by which could turn on your TV, press menu , menu drop down list will be visible on ur screen then wait 4 a minute or more till ur RC stop blinking , then go to Preference menu , go to FPA lock, turn it off. enjoy.
Deva
Apr 21, 2011 | RCA 20F420T 20" TV
How do i unlock my acer laptop? i have forgotan my password
Start the laptop and press F8 to go into safemode. Once boots up, go to control panel and click on user account. There will be option to remove password or reset password.
Thanks
Nov 04, 2010 | Computers & Internet
FPA lock on can not turn volume or channel FPA ON is dislpayed on screen its a rca Tru Flat
you need a remote to access the FPA LOCK ON ..go to menu then try to locate the FPA off.
Sep 06, 2010 | RCA Televison & Video
Menu keeps popping up on screen on 52 r5wh73
This sounds like the front panel assembly(FPA) switches are acting up. What happens with this model is the FPA switches start to conduct just as if someone was pressing the buttons. This in effect locks up the system control or causes it to do erratic things.
The way to determine if the FPA is bad is to remove it by unplugging from set. This requires front panel disasembly. Note:The remote will still work with the FPA removed so the set can be tested.
Also double check that the remote is not the problem by removing it from the room or removing the batteries
Let me know if you need more help or info.
Dec 03, 2009 | RCA R52WH73 Projection Television
Not loading up to main screen
ok go to youtube and type" PS3 REPAIR/FIX" basicly what you do is put the ps3 on standby (the red light on) and then turn the main power off (the back switch) then hold the I/O button in the front (the on switch you use to put on standby) just hold it until it will go to standby then hold the I/O button again (the standby button) and then keep holding it until you hear one beep, then wait for two quick beeps. Then there should be a menu and select "Restore Defualt Settings". If it dosent work CONTACT SONY!
Mar 08, 2009 | Sony Playstation 3 (PS3) Console
FPA LOCK ON
FPA means the front panel is locked by the Parental Access Control Menu.
Unfortunately, the FPA can only be removed using the remote. There are no magic front panel button combinations.
The cheapest way out is to buy a Universal Remote Control at Walmart (about $10) and program it to your RCA TV. Then you can go into the Parental Control Menu and remove the lock.
Dec 23, 2008 | RCA G36788LV 36" TV
FPA Locked ON
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works:
  1. Hold down MENU on the remote and VOLUME DOWN on the TV it’s self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds.
  4. Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds.
  5. Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds.
Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Dec 10, 2007 | RCA 20F420T 20" TV
RCA 27F530T 27" TV Logo
288 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
