NUMERICAL ERROR LASERJET 5500 59.5C - Office Equipment & Supplies
Hp color laserjet 5500 error 59 ck printer error
list of error codes
http://www.printertechs.com/printer-troubleshooting/hp-error-codes/195-numeric-error-codes-50-59-hp-laserjet
HP COLOR LASER PRINTERS 4600, 5500 ERROR 59.3, 59.4 1. A fuser motor error. 2. Replace the fuser drive assembly. 3. Replace the D.C. controller board.
Jan 04, 2017 | HP Office Equipment & Supplies
Error code 59.90 on color laserjet 470
59.9 is SCANNER MOTOR ERROR.
It is a rather tough part to service.
The entire scanning assembly would have to be replaced.
see
HP Color LaserJet 4700 Series Printer Numerical Control Panel Error...
Nov 01, 2016 | HP LaserJet 4700 Printer
Hp laser jet pro 400 m401 printer 59.A0 error
i have nOt used this site before but i believe they do have a description of the error code you describe. it said problem is defuser or main motor error, heres the link
HP LaserJet Error Codes 50 59
Apr 20, 2016 | HP Office Equipment & Supplies
Show error 52.00
Note this a not something users can repair themselves. It is a fault with scanning motor. may need motor or whole scanning assembly to be replaced. Only service centre can perform this.
HP LaserJet 4200 and 4300 Series Printers - Numerical Error Messages 52.XY PRINTER ERROR For help press? alternates with 52.XY PRINTER ERROR To continue turn off then on
Description
A temporary printer error has occurred.
X Description 0- Scanner error
1- Scanner startup error
2- Scanner rotation error
Action
  1. Press the (Select) button to continue.
  2. Turn the printer off and then turn the printer power on.
  3. If the message persists, contact HP Customer Support.
The laser scanner speed is incorrect. X description: 1 = Scanner startup error 2 = Scanner rotation error.
1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner. HP LaserJet 4200 and 4300 Series Printers Numerical Error Messages
Apr 16, 2016 | HP LaserJet 4350n Printer
HP PRINTER LASER JET 600 ERROR 59.00.90
www8.hp.com/us/en/support.html
Jun 17, 2014 | HEWLETT PACKARD - LASER JETS HP LaserJet...
Numerical Error
try to reinstall the printer drivers
Nov 20, 2013 | HP LaserJet 2300 Printer
I get an error in HP LaserJet 4345 MFP printer, 49.ff95 error, Tunr off and the turn on
a 49.xxxx error on an HP means that there is an issue with one or more hard disks. you can try to re-initialise the hard disk(s) by rebooting the printer while holding the green button. when the three leds are lit, release the green button, and navigate using the numerical buttons until you see "initialise hard disks" on the display of the printer. confirm by pressing the green button again. if all goes well, your printer will take two minutes longer than usual to boot. if you still get the same error afterwards, you need to replace the disk.
Apr 21, 2010 | HP LaserJet M4345 MultiFunction Printer
61 people viewed this question
jasbo
jasbo
