Question about Epson Stylus CX6600 All-In-One InkJet Printer
How do I recover data on a flash drive that is NOT recognized?
Yes, this flash drive is over one year old and has never been abused. It has been dependable (up to this point) day in and day out. I have 'no problem' taking it apart (if need be) and sacrificing the drive itself AFTER I retrieve the contents. I would appreciate any/ all possible options at this point.
Thank you, in advance, for your time and cosideration.
  • wanzinator Mar 15, 2009
    I wish to thank all of you for your assistance. but all fo your suggestions have beed attempted- but the drive contents remain 'un-openable.'
    Yes, I still seek additional guidance.........
  • Epson Master
  • 19,396 Answers
Posted on Mar 16, 2009
  • Ginko
    Ginko Mar 23, 2009
    Let us know if the problem is solved, or if you need more guidance.
    Thanks.
  • 70 Answers
The problem with flash memory is that it is extremely corruptible, flash memory can corrupt when u least expect it.
it is unlikely that u will be able to recovery any files off of the memory.
if it is a card then u might be able to but probably not
Posted on Mar 12, 2009
  • 8,197 Answers
This site worked for me with my drive.
http://www.jufsoft.com/badcopy/flash_drive_recovery.asp
Good Luck and Please Rate FixYa!
  • Jyackle5
    Jyackle5 Mar 15, 2009
    Did you get it fixed or working yet.
    If so Please Rate
    Brigadier General:
  • 3,614 Answers
you may need a card reader to be able to access it and connect & read it through your computer
  • Epson Master
  • 13,433 Answers
Hi, unless you can get the computer to detect the drive you will have to send the memory stick to a recovery/repair service. if you can get it detected at home, you can use a data recovery software. like File Scavenger
  • Ekse Mar 12, 2009
    Try FileScavenger in any case. http://www.quetek.com/prod02.htm
    see if the free/test version can recover files from the drive. if it can't you could try forceing a driver to install on the unregonized usb device and then try recovery again.
    installing a customer driver is done similiarly to this guide
    http://www.rr-cirkits.com/locobuffer-usb...
    Instead of going with the automatic you would need to use the advanced option - select driver yourself and then locate the correct one for the drive. You could compair the driver on a working drive and then install the same driver to the faulty one and see if it helps.
    Filescavenger will do the rest, its a awesome software. aslong as the drive actually works.
    if the drive is faulty and completely unreadable, recovery service is your only option and that may not be succesfull either.
  • Ekse Mar 12, 2009
    Also try the memory card on another computer or another cardreader keep pluging it in and out, eventually if its just a temporary problem it should install automatically. You can also try turning off the computer pluging in the memory card and then starting the computer up with the memory card connected. sometimes this can fix thatkind of a power problem with the card.
Recover data from flash drive gone bad
Yes, you can still recover the drive, you'll have to have it connected via SATA connections to get more information rather than usb
Nov 10, 2013 | PNY 64GB Drive
I have been using this Transcend FlashDrive 4Gb data stick for more than 2 years. Suddenly my computer refuses to recognize it. I tried in other computers too, but to no avail. How do I go about...
Try to find an IT Technician and ask them to use data recovery software eg. "Ontrack Easy Recovery Professional" to recover the drive.
If this solution fails then it likely that the data stick electronic components have completely failed.
Aug 24, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I am having one 4gb pendrive its not opening. now im inserting my pc please recover it.
Don't be panic. you can try some data recovery software. You can see
http://www.asoftech.com/adr/index.html
It tells the steps how to perform data recovery.
If above does not work, you may have to format the pen drive (use quick format), and then use above mentioned software to scan again the pen drive and recover your files.
Apr 05, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I pulled my flash drive from its slot suddenly. When I plugged it back in, I got the message "USB device not recognized". How can I recover the data on the flash drive?
plug in your flash drive then go to device manager then universal serial bus controllers expand it ..you will see usb mass storage device right click in it and select uninstall now remove your flash drive and restart your system ..now plugin flash drive.... this time it will detect your flash drive and.. now recover your data
Jun 15, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My computer does not recognize the 4gb USB Flash drive when plugged. Truied on 2 separtate computers now. Windows XP operating systems.
Hi m_j_lester
Do the computers that you tried it on make a sound or give any indication that a new device has been plugged in? If not then it could just be broken. It's not uncommon for these devices to fail altogether and they have a shelf life of about 10 years (depending on how much abuse they get of course!).
If you need any more help then let me know.
Scott.
Feb 01, 2010 | Dane-Elec DaneElec 4GB USB Drive Copper...
Usb flash drive not recognized when plugged into hub
data is lost,
test with H2testW'
fix with PD V1.08 B3
good luck !
Jan 25, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I really need to recover files from my sandisk cruzer
Have you tried this? restart your computer and plug your USB in again(this helps to clean the buffer), see if you drive can be recognized.
If you still can't access the data inside, try this data recovery program Wondershare Data Recovery. Get the program here,
Windows Data Recovery (Windows Version)
Mac Data Recovery (Mac OS version)
Take care - Before those items are recovered, stop saving more files to the device in case the file data are overwritten!
Nov 28, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
My U3 Smart SanDisk Cruzer Micro 2.0GB USB Drive Not Recognized
We can fix it -- and recover the data (provided it is recoverable -- which it generally is). If we don't get your data back, we ship the drive back to you and you pay nothing. We've been recovering data for over 16 years and are successful about 85% of the time.
Craftsman Computer Services, Cudahy, Wisconsin
Aug 02, 2008 | SanDisk 1GB Cruzer Titanium USB Flash...
Lost files during Sandisk update of cruzer 1.0 GB to work with VISTA.
you can recover lost files from sandisk Cruzer with card recovery software, recommended asoftech data recovery as it's one of the best data recovery software.
Jun 22, 2008 | SanDisk 1GB Cruzer Titanium USB Flash...
Epson Stylus CX6600 All-In-One InkJet Printer Logo
60 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
