Question about Cannondale IQ200 11 Function Computer
Cannondale iq200 how do I set the distance
Have golfbuddy wtx how to change yards to meters.
5.1 Distance : Unit of Measurement This setting allows you to change your distance measurement from yards to meters. The default setting is set to yards. ? The tab next to "Distance Unit" in the tools menu, shows the current unit of measurement that your unit is set to. To change from yards to meters and vice-versa, touch the tab, and then touch "Done" on the bottom of the screen, to save the setting. https://golfbuddyglobal.com/doc/usermanual_worldplatinum.pdf
Mar 07, 2018 | GolfBuddy GPS
Tip
Susspension set up for Motorcross bikes
When I need to set up a motorcross bikes suspension I set all the settings (both rebound & compression) to the middle of the range on both the front suspension & the rear suspension
Now, measure the distance from the inside of the rear mudguard and the top of the rear tyre & note the distance.
Now repeat with the rider seated in position and note the difference,
This value should be 20mm. If not adjust rear spring pre-load to correct.
Now, measure the distance from the inside of the front mudguard and the top of the front tyre & note the distance.
This value should be 15mm. If not adjust front spring pre-load to correct.(if adjustable).
This gives you your starting point for the fine tuning with the dampening adjustments to suit the riders preferances.
Regards Andrew Porrelli
on Dec 05, 2009 | Motorcycles
See 13 engine time and Mark for crankshaf
Hi, Anonymous sorry you can't find the first and best tool you ever bought for your Cannondale despair not for a mere $0 you can download another one. For more information about your issue and free downloads that you will need please visit the websites below. Good luck and have a nice day.
Cannondale Motorcycle Feedback
Cannondale 440 timing marks Google Search
http://www.cannondaler.com/manuals.php
Cannondale Parts
http://www.blackwidow-ok.com/om
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 28, 2014 | Cannondale C 440 Motorcycles
It wont work
Check to make sure the distance between the magnet and the sensor is 5mm or less. Also, check to make sure the magnet is lined up with the correct spot on the sensor. Make sure the computer is pushed all the way into the harness so that the contacts are in place. Lastly, inspect the wire for any breaks or fraying.
Mar 29, 2014 | Cannondale IQ100 Computer
How to set timing marks
Cannondale Parts
Jan 08, 2014 | Cannondale C 440 Motorcycles
How to time canondale 440 atv
Hi, Anonymous for more information about your question and free downloads that you will need please visit the websites below. Good luck and have a nice day.
Cannondale Parts
Apr 08, 2013 | 2002 Cannondale E 440
How to get to airbox on cannondale 440
CannondaleRiders com Your Cannondale ATV Resource
Performance Official Cannondale ATV and Motorcycle Dealer and Cannondale...
Cannondale Parts
Feb 19, 2013 | 2002 Cannondale X 440 S
Cannondale IQ200 11 Function Computer Logo
80 people viewed this question
Top Cannondale Cycling Experts
Charles T Nevin
Charles T Nevin
dante
Tom Chichester
Are you a Cannondale Cycling Expert? Answer questions, earn points and help others
