Question about Maytag MER5775Q Electric Kitchen Range
Oven will not work unless range is lit
WE have a Maytag Gas range RS, model #MGR5750ADW. The problem is with the oven, it only works if one of the burners on the range top is lit. The broiler works fine. Thank you
  • 21 Answers
You probably have a neutral return that is open. By turning on the stove top you are completing the path of return for the bake element. Work back from the element (unplug the oven first!!!) and check continuity back to the plug. Again, make sure you unplug the darn thing from the AC outlet!
Posted on Mar 13, 2009
  • Gary Redden Mar 14, 2009
    Good Evening, I'm sorry I misread your question; I didn't realize it was a gas stove (so much for speed reading!) Please disregard my response and sorry I couldn't help you. good luck with it. Gary
My Maytag Gas Oven MGR5750ADW preheats on certain temperatures and not others. For example it wont preheat at 350 degrees but will preheat at 380 degrees. At 350 we smell gas.
What you have is an ignition problem get this corrected before you experience a delayed ignition, the hot surface ignitor pulls enough amps 3-3.4 to power up and open the gas valve but ignition did not take place reason you smell gas don't know how old unit is ignitor may be weak good on draws 3-3.5 amps burner ports may be dirty or the bracket that the ignitor mounts too may have bowed away from the burner
Jan 29, 2015 | Maytag MGR5750 Gas Kitchen Range
How to turn on my oven model mgrh865qds
Gas controls are usually push and turn. The pilot has to be lit and the thermocouple warmed up before the gas will come to the oven. If the pilot is lit for a while and gets a little bigger when you turn on the control, but the oven doesn't come on, the thermocouple is bad. Hopefully it's not built into the control, because they are real expensive.
Nov 22, 2013 | Maytag MGRH865QDB Gas Range
My maytag oven m#MGR5750ADW wont light. The broiler & top are OK . I replacesd the safety valve with the oem#74006427 and I am still having the same trouble! HELP! Jay
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 11, 2011 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Oven Stopped Working..
It sounds like the igniter. The oven is not getting a spark to turn on, and heat up. We had the same problem, but changed the igniter, and it works fine. Good luck!
Jun 02, 2010 | Maytag CWG3100A Gas Single Oven
Oven wont light unless you turn on a stove eye and
Sound`s to me you need a new hot surface ignitor. Sorry to hear you may have changed the valve & regulator for nothing, but that happen`s quite often when you get the symptom`s you`ve described, I`ve even seen tech`s. do it. The reality is 9 times out of 10 when a hot surface ignition gas/lpg oven won`t light it is the ignitor.
Pick up part number 74007498 for approx. $40 and you`ll be cooking.
Hope that help`s. If so please take a second and rate the solution I provided here at fixya for you.
Good luck.
macmarkus :)
Dec 05, 2009 | Maytag Kitchen Ranges
When the oven is turned on to preheat, the buzzer goes off and an "F1" error message is displayed and the oven turns off. The model # is MGR5750ADW. Is there something we can do to fix it?
An "F1" error code means you have a defective clock assembly (also called ERC- electronic range control). You will need to replace the clock assembly, and they are not cheap, around $200. Hope this helps you, good luck.
Oct 04, 2009 | Maytag Ovens
Maytag oven will not get hot
the ignitor is bad, the ignitor opens the valve when there is enough amperage. the ignitor isn't pulling enough to fully open it
Sep 08, 2009 | Maytag MGR5870 Gas Kitchen Range
Maytag gas range model MGR5750ADW gave fault code F3 during self clean (25 mins. remaining). Can't get oven door unlocked and tried cycling power
hi thanks for the question the part you need is the oven sensor witch is located , in the oven top left /looks like a pen replace that part the number i got is 1365 from repair clinic . thanks the appliance doc
Sep 28, 2008 | Maytag Kitchen Ranges
MGR5750ADW Gas Range locked
Here is an excellent artical on that and should solve your problem.
http://www.appliance411.com/faq/cleanlock.shtml
Nov 18, 2007 | Maytag MGR5750 Gas Kitchen Range
Maytag MER5775Q Electric Kitchen Range Logo
295 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
