Question about Sherwood Audio Players & Recorders
Have a Sherwood S-277OR CP Audio/ Video Receiver. The Graphic Equalizer/Spectrum Analyzer display will not light-up.
The past 2 weeks I have taped the side of the amplifier to get the GE/SPA to light-up and now it won't light -up at all. Seems like a loose connection.
2 Suggested Answers
  • 128 Answers
SOURCE: I have a Yamaha HTR-5890 receiver and I am trying
must have the tape monitor to work the regular tape loop does not physically go back into the receivers processor.
only other solution is if the receiver has PRE out and ins use the PRE out to the EQ then back into the PRE in.
if you have the OUT but no in then the solution would be to go out of the EQ and into an external amp.
In my experience "young adults" like using EQ's to boast bass output.
If that's your goal a POWERED subwoofer is what you need.(check out polk audio direct on ebay)
Your unit is a 7.1 surround receiver the reason that it doesn't have the capability for an EQ is that it messes up the surround sound processor.
If the sound is not what you are looking for the issue more than likely is with the speakers. post a messege with what you want to achieve and I'll try to point you in the right direction.
Posted on Dec 29, 2009
Can I connect an external Technics SH-8036 Stereo Graphic Equalizer to my Technics SA-500 receiver?
You can but you will need to use one of the tape loops to do so. That means you will also have to use the tpae monitor switch of the front panel. Just get 2 sets of interconnects and run one from the tape out to the input of the equalizer and the other from the tape in to the out put of the equalizer.
Feb 11, 2016 | Technics Audio Players & Recorders
I have a Sherwood audio/video stereo receiver S-277OR CP. Why would it work but not put any sound out?
Check speaker selection switch. If set properly then perhaps the amplifiers are blown - check for fuses that may be open.
Dec 01, 2015 | Sherwood Audio Players & Recorders
Is the Phono output on the RX4109 considered a preamp output in to a Power Amp?
The phono connection is an INPUT and it is a low impedance circuit. It is easily overdriven because the signal that goes into it is very small. You plug a record player into it. Any pre-amp connections on an audio device are in place after equalizer controls. There are no pre-amp connections on the Sherwood.
Sep 13, 2014 | Sherwood RX-4109 Stereo Receiver Black
AUDIOSOURCE EQ EIGHT REPAIR MANUAL
all of the level light's stay on and I got a hum and not music
Aug 31, 2012 | AudioSource Eq Eight/ Series Ii Graphic...
I have a Yamaha HTR-5890 receiver and I am trying to hook up a Yamaha EQ-32 10 band graphic equalizer to the receiver. The frequency spectrum analyzer on the equalizer is working but the graphic...
Dec 29, 2009 | Yamaha HTR-5890 Receiver
Sherwood 460 equalizer hook up
Connect the EQ to the Sherwood as if it were a tape deck: EQ's outs connect to receiver's tape ins (play) and EQ's ins connect to receiver's tape outs (record).
Then you hook the tape deck up to the tape ins and outs on the EQ: Tape deck outs connect to EQ's tape ins (play) and tape deck ins connect to EQ's tape outs (record).
This will put the EQ in your receiver's tape loop.
The CD player should be connected to the receiver though the CD in's and out's (or if your Sherwood doesn't have a CD in/out, then use AUX or TAPE2).
To hear the EQed signal with all receiver sources (like the CD player) you'll need to engage the 'Tape Monitor' button or switch which will route the tape loop to the speakers.
Jan 09, 2008 | Audio Players & Recorders
Sherwood RD-6108
Not sure - just make sure the tape player button is not pressed.
Dec 09, 2007 | Sherwood RD-6108 Receiver
Clarion arx9170
if you have an ohm-meter check those bulbs. If not just replace them, but, before, check fuses (if there're any)
May 02, 2017 | Car Audio & Video
Equalizer hook up.
only hook up to tape monitor or else u wont get an audio signal . .....also hook all equipment to amplifier not eq ...it goes tape cd tuner and any type of external equipment to amp.then find tape 2 it sould be called tape moniter and have a separet botten for u to select it goes record to eq and play from eq
Aug 27, 2007 | Spectrum Technical Hifi EQ-B5100...
48 people viewed this question
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Josh Whitehead
Josh Whitehead
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
