Question about Philips 150MT 15" LCD Monitor
150mt10p I Have no picture not for TV nor Computer
Cannot connect compaq presario v400 to tv
Did you mean you want to connect your computer to a TV?
If you did and connected it but nothing happened then you may have to select the correct input on the TV remote. It used to be called AV but some of them have a little picture of a screen with and arrow pointing in to it from the left.
You just switch your TV on, switch your computer on, then press the button on the remote a few times until you get the PC input picture. You may also have to hold the Fn key on the computer and press one of the keys with a Monitor / TV screen symbol on it. It maybe one of the Function keys or one of the number keys at the top of the keyboard.
Feb 08, 2012 | Compaq Presario V400 14" CRT Monitor
No picture on TV with Dell Inspiron 6000
the problem is your video configuration its supposed to be Tv-in on computer so you can receive video on the laptop screen
Jan 25, 2010 | Dell Inspiron 6000 Notebook
Connect dell latitude d400 vga to vga on tv picture looks scrambled
yes your computer is running a different HTZ ... that vga is really made for a external computer moniter not a TV :() thou it can be done the picture is S%%T
Dec 27, 2009 | Dell Latitude D400 Notebook
How can i use my digilogic lcd tv as a computer monitor? it has the connections as my current monitor but when i connect the tv to the computer there is no picture,the computer base is recogniseing the tv...
Have you checked the menu set-up option on the TV set ? Your computer may be sending an out of range signal, so set it to low resolution and try that. Obvious other thing is the "input" setting, it may not auto detect it.
Nov 19, 2009 | Computers & Internet
Howto connect a ficture/film from computer to tv
there is a wireless signal sender that you can connet to the tv from your computer and it will send the signal so you can use your home tv as a computer monitor from any room in the house. search the internet
Sep 09, 2009 | Televison & Video
No picture from computer to pc
Please check the following things:
(i) You're using an appropriate cable to connect the TV to the Computer.
(ii) The cable is connected to the out port on the Computer and the corresponding in-port on the TV.
(iii) You've selected the correct input on the TV.
(iv) Dual display is enabled on the Computer.
(v) The resolution of the video signal being transmitted from the Computer to the TV should map the display resolution support by the TV. In this case, you may try lowering down the resolution of the TV in the Display Settings window of the Computer after selecting the second display.
Aug 31, 2009 | Toshiba Computers & Internet
No tv picture - only audio - after pc to tv box hook-up
Hi I am a silver surfer but this is how I got it working
First off get the program tou want to watch up on PC Moniter(screen) Then connect 3 cables
Yellow cables / One end to tv other end to yellow hole rear of PC/TV Box
Grey cable small end goes in PC/TV Box just behind the wirds "kworld" other end goes into back of your Computer ,you need to check your Computer manual to see the which one is the connection to your Computer screen(moniter),mine was blue with 2 screws , disconnect this and screw in Grey cable
Black cable narrow flat end into front bottom of Computer ,other end intoPC/TV Box end hole next to yellow cable
Switch on TV and change AV until you see your program, sound will be thu your Computer Speakers NOT your TV
THIS IS FOR A DESKTOP COMPUTER
Jun 15, 2009 | KWorld PC to TV (0872880887527) Video...
When displaying pictures from Nikon D60 on TV (HDTV & non-HDTV) the pictures are not as sharp as when the pictures are displayed on the computer. How can this be resolved?
View the pictures on the computer. NTSC television is about 700x500 resolution. I'm sure your computer has much better resolution, and you can also zoom in.
Aug 07, 2008 | Nikon Cameras
Philips 150MT 15" LCD Monitor Logo
20 people viewed this question
Top Philips Computers & Internet Experts
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
