Question about Husqvarna Garden
I can not find the drain plug to drain the oil on my husqvarna mower with the honda engine
3 Suggested Answers
  • 15 Answers
SOURCE: oil drain plug
Drain plug is not necessary. Remove the dipstick and tip the mower to the side the dipstick is on and use the dipstick tube as a drain.
Posted on Apr 23, 2009
  • 351 Answers
may be under the blade plate under the mower, usually a plug with a quarter inch square drive, you can use a ratchet to loosen it if it is quarter drive, maybe a half inch drive
Posted on May 11, 2009
Where is oil drain plug
On the right side of engine towards the bottom, a square plug
at the drain plug.
Aug 21, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
What's your problem? Husqvarna YTH 2148 can't find the oil drain plug
the trans doesn't have one the engine has a black tube coming from he side you push in and turn the outer sleeve add a hose to the nipple and drain it out the might be a small yellow cap in the end of it
Aug 17, 2012 | Husqvarna Garden
Engine smokes for a moment when i start cutting model YT1942T
Is it Blowing White smoke, if Yes then
Use the lawnmower's oil dipstick to determine whether the oil level is correct. Maintain the correct level of oil. If you've overfilled the oil, open the drain plug, and drain some of the oil into a waste container. Dispose of any excess oil properly. Burning off excess oil is undesirable. It can foul the mower's spark plug, piston rings, and other engine components and contributes to air pollution. If your mower's engine has not been overfilled with oil, but still is smoking, it may have stuck or worn piston rings or another maintenance problem.
Some maintenance shops offer a mower transport service. Check to see if this is available in your area.
Jan 24, 2012 | Husqvarna Garden
Weed eater 961380017 where is oil drain plug located?
On the Weed Eater 961380017 it uses a Rato engine and the mower is made by Husqvarna, it is the same as their U.S. model 5521P. To drain the oil you have to first remove the dip stick and then tilt the mower over to drain the oil out into a pan.
Aug 04, 2011 | Garden
How to change oil In a craftsman lawn mower, that has a honda engine. Misplaced my manual. Have decided to change my own oil rather than have it serviced every year I was doing a number of lawns so I had...
Look for a drain plug under the deck in the bottom of the engine (under the deck) known as the crankcase housing. Drain plugs come in different forms, but you will know it when you see it. IF there is no plug on the engine bottom, then check for a small plug on the side of the engine (above the deck) with a square head. That would be removed and the mower tilted that way to drain the oil. If no plug on the side of the engine then the oil will have to be drained out the oil filler tube. Remove the dipstick and tilt the mower that way to drain the oil.
May 15, 2011 | Craftsman Garden
Lost owners manuel and need to know what type of engine oil to use for a Husqvarna 25-HP V-Twin Hydrostatic 54" Garden tractor
if engine is briggs use briggs sae 30 oil also change out filter use briggs black std oil filter or yellow filter if els version
if engine is kohler use kohler 10w/ 30 oil and use kohler oil filter
if its honda use 20w/50 oil and use honda oil filter
if its kawasaki use 20w/50 and use kawasaki oil filter
cheers pauly 46
Mar 26, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Will fire but stops after a few seconds. Not always reaching full rpm. checked for breather hole in filler cap
I would first check the spark plug and air filter. If the air filter has grass or dirt packed in the folds of the paper element, replace it. Also if the spark plug has a black charcoal like substance on it, it will need brushed off. The spark plug can be removed with a 13/16 deep well socket. If the unit will still not start, there may be water in the fuel tank. Drain the fuel tank and empty the contents of the fuel bowl on the carburetor. The carburetor fuel bowl has a nut on the side of it, it can be loosened with a 10mm wrench. Let it drain out completely, tighten the nut on the fuel bowl, and add fresh fuel. If it will not start at this point you will need to have the engine serviced. This can be done at any Honda Power Equipment repair shop. They may not want to work on it since it is on a Husqvarna mower, most will tell you that the only thing that they will work on is the engine. Alternately you can take it to a Husqvarna dealer and get the mower serviced there.
Mar 26, 2011 | Husqvarna 21" Lawn Mower with Honda GCV160...
I own a troy built self propelled mower with a Honda GC160 engine. I'm wanting to drain the oil and am looking at the engine where the manual says there is an oil drain plug, but there is no plug. Can you...
it's on the same side as the muffler near the bottom of the engine. carefull with the oil if you run it before you change the oil as it will be HOT!!!...good luck
Apr 06, 2010 | Husqvarna 160 CC Honda OHC Engine 21 in
Husqvarna R53SV Petrol Mower wont start. I think too much oil had been put in. I drained some out bu still wont start. Is the engine flooded? how could i start it? Thanks
Use starting fluid when it does finally start continue starting until all the oil is cleared out of the carburator you may need to repeatedly choke out the carb with the engine running to clear out the carb, do this by removing the air cleaner, start the mower on high speed rpm, and cover the air intake with your hand repeating this start/ choke/ stall procedure until it is cleared out it works, I just did this to a mower last week that had too much oil in it, the mower smoked quite a bit but eventually returned to normal
Jul 15, 2009 | Husqvarna 160 CC Honda OHC Engine 21 in
Oil drain plug
Apr 20, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
254 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
