Question about Canon Pixma MP500 All-In-One InkJet Printer
Canon Pixma MP500
One of the little brass doo-hickies (beneath the print head) that fits into the ink cartridge broke off when a cartridge got stuck and I had to wrench it out. I'm told by a business machines repairman that he doesn't think it can be fixed, but is still checking on it. I've checked w/ Canon online and they do not sell these parts, but that the closest Canon service store is about 150 miles away.
  • Hopeless Ros Sep 09, 2008
    I accidentally inserted an 8bk cartridge into the 5bk cartridge slot and it is now jammed stuck! I am trying to get it out but worried about breaking it....
    Genius:
  • 2,985 Answers
Printers generally are made so cheap that parts are not usually available Nothing for it but to replace the machine and espicially 'doo-hickies' I didn't think Canon used them any more- no one else seem to
Posted on Aug 04, 2007
SOURCE:
My Canon Pixma mp500 won't print black for text. There is no error message. I have run through cleaning cycles, updated the driver, changed the cartridge with no results. Other colors all print fine. ...
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage. Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head. Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Feb 20, 2011 | Canon Pixma MP500 All-In-One InkJet...
My cannon pixma mp500 won't print in black
Hello
Please replace or re-fill the black cartridge.
Good Luck
Jan 17, 2011 | Canon Pixma MP500 All-In-One InkJet...
Print Head Problems??
The ink cartridges on your Canon Pixma MP500
print head not problem your yellow cartridge &black
problem
Oct 07, 2009 | Canon Pixma MP500 All-In-One InkJet...
I have canon pixma mp500. The blue ink won't
This is common in Canon Pixma printers (all models). If you are refilling your cartridges or are buying refurbished cartridges this will happen more often. Take the cartridge out and put it back in. If this does not work, then replace the cartridge altogether. If that doesn't work, you need to contact Canon (us.canon.com if you are in the U.S.) for help. Let me know if this helps you.
Jul 07, 2009 | Canon Pixma MP500 All-In-One InkJet...
Black ink cartridge is leaking and black line is running down back of page
YOU CAN TRY PULLING THE CARTRIDGE OUT AND WITH A CLEAN , VERY SOFT CLOTH , CLEAN THE HEAD GENTLY ....SOME CARTRIDGES ARE JUST FAULTY ....HAVE YOU TRIED RETURNING IT OR GOING TO CANON SITE AND TROUBLESHOOTING ?
Jun 02, 2009 | Canon Pixma MP500 All-In-One InkJet...
Canon Pixma MP500 error
ok I figured out what to do. Open the over take out all your ink cartriages. Then flip the print head level on the left hand side up and squeeze the top of the print head (where all your ink sits on) and lift it up. You may want to blow off any dust that may be in there and put the peint head back and replace al your ink put the level down and you should be good to go if not you may have to replace the head.
Aug 05, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon MP500 PGPK cartridge wont print
i have the same problem too. This is obviously a product defect. If Canon not fix it, i wont buy Canon printer anymore.
May 21, 2008 | Canon Pixma MP500 All-In-One InkJet...
Pixma mp500
  • Replace a new Canon ink cartridge as it could be due to the unique features that Canon has build on their ink cartridge not done properly which resulted to be faulty. Report the issue to Canon if your existing ink cartridge is not from other 3rd party band, Canon should be able to do 1 to 1 exchange once confirmed that it is their ink cartridge problem. Cannon has build the unique feature to prevent users from misusing 3rd party ink cartridge on their printer.
  • Other times if by replacing new ink cartridge the problem for error code still occurs, it might be the pin on the print-head has lost the alighting, this will require for Canon to service to alight back the pin on print-head in order for the printer to operate smoothly again.
  • Or missing pin has dropped off from the print-head which causes the printer not able to read the ink cartridge, printer needs to be serviced.
  • (Maybe check with your own nearby technician if by any lucks they can help to rescue your printer, which I hope Canon does not have further enhancement on their printer with other Unique features to prevent users from using 3rd party technical support.)
Nov 25, 2007 | Canon Pixma MP500 All-In-One InkJet...
Canon Pixma MP500 All-In-One InkJet Printer Logo
79 people viewed this question
Clive
Clive
old marine
old marine
