Question about Photography
Frig beeps every min. also flashes #4 on the frig side
How do you set the minutes on the clock?
There are two ways to set the clock on your coffee maker. 1- When you initially plug in the coffee maker, the unit will beep and "12:00" will flash on the LCD display for a few seconds. Press immediately the h/min button (o) to set the current hour. If "12:00" starts to flash, press the PROG button (n) for a few seconds until the "12:00" flashes again. Then press the h/min button (o) to set the current hour. There are AM and PM indicators on the top right side of the LCD screen. To set the current minutes, press the PROG button (n) and then press the h/min button (o) until the correct minutes appear on the LCD display. After 5 seconds, the unit will beep and the time will stop flashing. 2- At any other time, you can set the clock or change the set time by pressing and holding the h/min button (o). The unit will beep and "12:00" will flash on the LCD display. Use the h/min button (o) to set the current hour. There are AM and PM indicators on the top right side of the LCD screen. To set the current minutes, press the PROG button (n) and then press the h/min button (o) until the correct minutes appear on the LCD display. After 5 seconds, the unit will beep and the time will stop flashing. Notes: Your clock has now been set and will continue to keep the correct time, even after the coffee maker has been shut off. Unplugging the coffee maker or a power failure will reset the clock to 12:00 AM. Repeat the instructions above to reset the clock
Source : Krupsusa.com
Link to manual : http://product-support.groupeseb.co.uk/Download/Pdf/366/km730
Mar 21, 2016 | Krups KM730D Breakfast Set Coffee Maker...
ALARM WONT STOP BEEPING
unplug it let it set for 5 mins then plug it back up hope this helps. if it continues then there is a problem with the frig that needs to be repaired. find out what's happening to cause the alarm. is it cooling? is it defrosting? what's up with the frig?
Aug 24, 2014 | Hotpoint Refrigerators
Frigidaire refrigerator model ffhs2313lpo
The problem is most likely the=> 241739710 Temperature Control Board That is the electronic display that you said is not working. Sometimes there may be signs that the board is defective but most times there is no physical sign the board is defective, I am here should you need me, Thanks John Tripp Appliance 911
Apr 28, 2014 | Frigidaire Ffhs2313Ls 23 Cu Ft Side By...
FRIGIDAIRE SIDE BY SIDE FRIDGE SIDE TOO WARM
adjust the temp on the freezer setting where it links up with the frig'...
Feb 03, 2013 | Refrigerators
Codes flashing on door screen after power blip
You had a power surge due to the storm, unplug the unit for 5 min's and see if it resets the faults.
Jul 09, 2017 | Samsung 24.6 Cu. Ft. 4-Door Side-by-Side...
High pitch/humming noise from Frigidaire Refrig.
You have to isolate this problem. It could be one of three things. The compressor, the condenser fan motor or the water valve that feeds the ice maker and wtaer dispenser. Also if the high pitch sound is compared to that of a bird then it is definitely the condenser motor. To isolate the problem take the back cover off. LISTEN FOR THE HIGH PITCHED/HUMMING NOISE! Use a flash light and see if you can tell where it is coming from while it is doing the noise. Dont try this unless you know what your doing. Stop the condenser fan blade with the end of a hard object, but stop it gradually. Dont try this cause you might brake/bend the blade. But if you did and the noise stop then you figured out your problem. If not ythen disconnect the water valve. It has to doulble harness wires attached to it. if problem still exisit then it has to come from the compressor. Unless you have a warranty then theres nothing no one can do except change it. $300-400 job easily.
Mar 27, 2010 | Frigidaire FRS26RLECS Side by Side...
Beeping sound
ok the only other option the latch located in the fridge has a loose wire which need to repaired by a fridge tec but also if the fridge seems like its not getting cold the thermostack that make the fridge cold may be malfunction
any how it needs repair
Jul 07, 2008 | GE Profile¿ Arctica® Energy...
Whirlpool gold conquest refridgerator
if u find out let me know. when we turn both frig/freez switches off the frig light comes back on flashes to number 6. it still seems cold be like this 2-3 days the food still seems cold. good luck. jax, fl
Mar 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Defrost
Could be. Is the unit working right otherwise? Sometimes replacement units (field service components) do different things than factory. Flashing all the time seems wrong, though.
Dec 08, 2007 | Samsung RS2630SH Side by Side Refrigerator
Photography Logo
236 people viewed this question
Top Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Are you a Photography Expert? Answer questions, earn points and help others
