Cordless phone on same bandwidth as wireless belkin router
I think my cordless phone is on the same bandwidth as my wireless router. It is a Belkin Wireless Router N600DB N model F9K1102v1. My previous router was a linksys and I followed instructions from Youtube https://www.youtube.com/watch?v=hVgeH-XhFwg to stop my phone from interfering. Is there a similar way to do it with my belkin router? I cant seem to find instructions anywhere. I don't think it was a problem until just recently but it's started knocking us offline when anyone is on the phone. I've had the router at least a year or 2 and the same phone for 10 years. Please help. Thanks!
  • 826 Answers
Yes, you can change the bandwidth of your router if you are facing the interference problem. You can change the bandwidth and check whether both are still in the interference or not; continue to change BW, till its not in interference.
Posted on Apr 22, 2013
2 Suggested Answers
SOURCE: Belkin wireless G will not play Youtube videos completely
I had the same problem - I updated the firmware pre-release version from the belkin support site - located here - http://www.belkin.com/uk/support/article/?lid=enu&pid=F5D7230uk4&aid=9080&scid=0
Double check the version no to be sure to be sure - this is for V7.
Problem has gone away.
Posted on Aug 19, 2008
I lost my belkin N600 DB Wireless N+Router Model:F9K1102v1 cd software,so i want to download it online by the net.
You don't need the CD to setup the router. I made a video showing how I did it to my F9K1003V1.
Feb 28, 2014 | Belkin Connect N150 Wireless N Router
Cant connect to a new labtop
1, You should always secure your Wireless. 2, try different channels, setup the dual-bands as 2 SSID, 1-2.4 and the other as 5.0 with diferent channels. I would suspect it's the laptop, Disable the UAC and the Anti Virus. Is the wireless adapter, on the laptop turned on? Do you see the Wireless listed in Available Wireless Networks? For dual-band setup :http://www.pcworld.com/article/229521/dlink_setup_a_wireless_router.html
Jan 09, 2013 | Computers & Internet
Belkin n1 vision router freeze up. download mode or looping in bootup mode. what next?
Disconct wireless devices...connect to pc via cable...Go to SSID settings... change bandwidth from 20/40mhz to 20mhz only ... rebooting issue will be soloved... link speed will show 65-150 Mbps .. bt dont worry.. u will get the whole bandwidth available .... after that reconnect wireless devices ... it wont reboot by itself ...
Jun 19, 2011 | Belkin N1 Vision Wireless Router
How many pc's, laptop's & printer's can i link up to belkin n1 vision wireless router model f5d8232-4
You can uplink a fairly good number of PCs or laptops with Belkin N1 as it supports high bandwidth. Keep in mind that upon adding every new PC, the overall bandwidth for the other PCs is reduced. If the PCs/ laptops do not require much bandwidth, you can connect / add more PCs to the network.
Generally, I have uplinked upto 10-15 clients to one router and the network worked just fine. It all depends upon the network environment and the bandwidth usage by each client PC. If the PCs are using just email and simple internet browsing (and remain idle for most of the time), you can add more clients to your network as not all the systems consume network resources at the same time.
Hope it helps! Good Luck!
CreativeTECH
Apr 01, 2011 | Belkin N1 Vision Wireless Router
I have a belkin router, cordless phone interferce
cordless phones and wireless routers transmit on the same frequency. Move the router away from the cordless phone if it's near, if not try changing the channel on your belkin router
Now if your WIRELESS connection drops, when the phone rings it's usually because of this:
You have a cordless phone in your house that is using the same channel as your wireless router. Now routers are generally quite different so there's no one way to fix this. Just look up your make and model of modem on Google and find out how to change the channel on your modem. It's pretty straight forward and not very time consuming to fix.
Also one thing to note is that you shouldn't automatically jump to the highest channel that you can because your wireless card may not be able to go that high.
Apr 18, 2010 | Belkin (F5D7230-4) Router (587009)
Belkin wirless router lose signal after approx. 30
Check the wireless channel on the router.
Is it properly set ?
you can try changing the wireless channel on the router.
Or if that doesn't work then you can try to upgrade the firmware of the router.
for this you will need to open the set up interface of the router.
Click Here to know more about routers
Oct 26, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Keep losing my wireless signal. always have to disconnect and reconnect. Happens on my computer and now also on my ipod. Only fix i found is reseting the router. I have a Belkin N1
Enable 802.11g only disabled DHCP use CH6 and WPA also set the Bandwidth to 20/40 MHz instead of just 20 MHz. Also upgrade firmware if you haven't done so.
Oct 22, 2009 | Belkin Computers & Internet
Belkin lock
To secure your wireless network and prevent unauthorized access you need to setup your wireless router with these settings :-
When you first setup your wireless router you should change the login password and then the wireless configuration, setup WAP or WAP2 encryption (WAP2 is the strongest encryption) and change the SSID and turn off SSID broadcast.
For further wireless protection enable MAC address filtering. The MAC address of the wireless card in your computer is entered in the router MAC address filter table, which allows only the wireless card with this MAC address to connect to the wireless router.
Also if your router has a firewall then you should enable this feature.
The wireless card on the computer needs to be configured with the wireless router's settings. The LAN cable can be removed and the computer communicates wirelessly with the router.
Sep 21, 2009 | Belkin Computers & Internet
Lose internet connection when phone is in use
Your cordless and wireless mode is running on same frequency.
You can do couple of things...use the wireless mode in b instead of g in the router.
Else use a different cordless phone which runs in 5.8 or 6.0 frequency.
Hope this helps.
-Pankaj
Mar 26, 2009 | Belkin (54G F5D7230UK4) Wireless Router
Phone ringing disrupts wireless connection
Are you using cordless phone? If yes then there is a wireless interuption between your cordless phone and wireless router. Normally Cordless is running at 2.4ghz same as the router. Its better if you can relocate the phone or change it with 5.8ghz cordless phone.
Sep 28, 2008 | Belkin (F5D7230-4) Router (587009)
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
