Clean pump light whirlpool 6th sense WFS1072AW 7.5KG
I followed all the instructions on how to clean the filter at bottom of machine & rotor when the clean light comes on. HOwever there was a small round peice of white material in there that looked like it should be part of the filter but it wasn't attached to anything and was just scrucnched up in there. Is this a part of the filter or just a random rag that found it's way in there? if it should be in there how do i put it back on correctly?
  • 1028 Answers
SOURCE: clean pump!
remove bottom panel torx or 7 mm nut driver needed.pump has "knob" turn counter clock wise ..have plenty of towels handy to unlock door first reach up to bottom of door lock tear shaped plastic tab pull down door will open
Posted on Apr 28, 2008
robshow
  • 367 Answers
SOURCE: clean pump light keeps coming on
That is the way to fix the issue. remove the debris and hope nothing else gets caught in the trap
Posted on Jan 19, 2009
richardsimpl
  • 230 Answers
SOURCE: Getting faulf code F06 on Whirlpool 6th Sense AWM 8143
Hi There
I have found what you looking for and i hope this help's yo. let me know.
F/06 Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Thank you for writing to fix ya.
Best regards Richard
Posted on Dec 12, 2009
gregory_91
SOURCE: front loading whirlpool machine WFS1072AW which needs pump clean
WFS1072AW has a clip in panel at the bottom across the front.
Removing this will reveal a black plug on the right.
Unscrew this and water will gush out along with (hopefully) the offending coins.
Posted on Sep 06, 2010
SOURCE: I have a whirlpool 6th
f13 is a problem with the door lock, I have the same machine and it takes 4 minutes for the door latch to open and if it dont in the 4 minutes F13 comes up and the machine will go off and not start again.
Posted on Oct 21, 2010
How do I clean the pump on a Whirlpool 6th sense frontloader
The pump filter is situated behing the white plastic kick strip on the front at the bottom of the machine.
Instructions for use Whirlpool UK
Sep 19, 2014 | Washing Machines
Whirlpool 6th sense washing machine manual
can you hear the pump
there may be something in the pump or in the pipes to and from the pump clean out
Dec 30, 2013 | Washing Machines
Whirlpool 6th sense - pump issue
The drain pump probably just needs cleaned. If you've never cleaned it i can direct you to videos that are step by step. Let me know.
Jan 20, 2013 | Whirlpool Washing Machines
Can't open pump
Dear Sir :
See the diagrams and proceed accordign with common sense.
God bless you
May 13, 2012 | Whirlpool AWM8143 Front Load Washer
Front loading whirlpool machine WFS1072AW which needs pump clean
Feb 13, 2010 | Whirlpool Washing Machines
I have a whirlpool WFS1072AW washing machine. a red light comes on to clean pump. I am not sure how to do it
The WFS1072AW has a clip in panel at the bottom across the front.
Jan 07, 2010 | Whirlpool Washing Machines
What does F7 mean on a whirlpool 6th sense washing machine?
F7 in whirlpools means "Clean the filter”.
The following troubleshooting steps would help fix it. Remove the filter on the floor of the machine, including the metal grill. Press & hold the start button (like you do when you want to cancel a program this will drain the water out of your clogged up drain outlet. Clean your filter and grill and replace it. My guess is that the sensor in the drain (a little glass tube) measures whether the water going out is clean enough to decide that your dishes are now rinsed correctly. If your filters clogged, the water going down the drain is still dirty. After a while it gets sick of trying and stops the machine.
Thank you for contacting www.Fixya.com
Jul 30, 2009 | Whirlpool Washing Machines
Clean pump!
Apr 26, 2008 | Whirlpool AWM8143 Front Load Washer
Washer will not complete a cycle
hi,
i have a whirlpool 6th sense washing machine, it has come up with clean pump, does anyone know where the pump is on the machine, as i have lost my instruction manual.
regards
jackie
Nov 08, 2006 | Whirlpool AWM8143 Front Load Washer
Washing Machines Logo
90 people viewed this question
Top Washing Machines Experts
