Unisys prc3000 ups
Model #prc3000
Routing ospf unisys
OPPF is a protocol that works between two routers to choose the best (fastest) route.
The Unisys needs to be able to pick up two routers on the same IP configuration, both giving it data that might come from the same source.
I.e. it puts them on the same network as if they were cabled together, which is what you can do and then feed the one connection into the computer.
Aug 25, 2014 | NetGear Computers & Internet
I use a Unisys uds9718 printer. I receive 935 service print head error. Any suggestions? I have wiped down all the rollers.
This is similar to an error I fixed for a relative, who has an HP printer. What you need to do is call the manuacturer, and ask for another print head. My relative got hers free, because she was under warranty. Hopefully it's the same case for you.
Just change the print head and your good to go. Hope I helped. Post on my site and I will get back to you.
codfanboys.comli.com
Nov 22, 2011 | Office Equipment & Supplies
What is the power rating of AP9215?
The AP9215 control panel itself does not have a power rating. It is compatablbe with the following UPS models.
PowerView supports the following APC UPS model families:
Smart-UPS: SU450, SU700, SU1000, SU1400, SU2200, SU3000
Matrix-UPS: all models
Symmetra: all models
Click here for the manual
Hope this helps.
Zeppelinx12
Mar 07, 2011 | APC PowerView AP9215
Insignia NS-LCD42HD 2+ years old - color problem (getting lots of green, both composite and hdmi) - had been VERY happy with picture quality. Question should I repair or replace? (have done computer...
The TV is very low Grade considered a cheap china knockoff and the panel has gone bad as expected you need t replace the TV and next time steer clear of the non brand products (aka walmart)
Feb 12, 2018 | Insignia NS-LCD42HD-09 42 in. HD-Ready LCD...
Need operating maual for Unisys UDS 132 printer
Your printer is a Lexmark Optra T520 series and you can probably obtain a manual at the Lexmark web site.
Jan 24, 2010 | Office Equipment & Supplies
I need a CD-ROM drive and cable for an Asus P2L-N/P2E-N board
Is this what you are looking for?
As for the conflict with the master drive, double check the jumper settings. Some drives have different settings for Master, Slave and Single drive. When given the option, try CS (Cable Select) and them them sort it out themselves.
It's also not usually recommended to connect an optical drive on the same cable as a hard drive. Sometimes you can't help it, but the optical is going to slow down the transfer rate of the HD.
Jul 01, 2009 | ASUS Intel 440LX Chipset P2L-N Motherboard
Unisys model uds25 has a error message "invalid engire"
on power up let me guess the most frequent errors on power up are 922 fuser error means ac circuit is open replace the fuser. 201 jam error no paper present replace the main motor drive. 954 nvram error hold right arrow go and reutrn buttons down power on the machine if it doesnt reset repplace the engine board this is just a band aid thie error is known to return. there are also several scanner errors that can come up a biy more info would be good
Feb 19, 2009 | Lexmark Optra T614 Laser Printer
SONY DVD RW AWQ170A
yes you can use nero 7 or cyberlink power dvd this software allow you to watch dvd movies. window media player doesnt play dvd without this softwares..
Feb 12, 2008 | Sony 16X DVD+/-RW Dual Layer OEM Black...
Unisys UDS 25 Printer Problem - Identical to Lexmark T614
check the Technical Support Team for this machine My guess is the drum is on its way out - or some other replaceable control item but they will know.
May 25, 2007 | Lexmark Optra T614 Laser Printer
19 people viewed this question
k24674
jasbo
jasbo
