Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
How to replace Ice Door Solenoid
The ice chute door opens properly, but doesn't close. From what I've read, it probably needs a new solenoid.
I've removed the plastic cover from the inside of the freezer door. Where do I find this solenoid?
Is it above, buried in all the insulation, or below under the metal plate?
Thanks...
I got help from repairclinic.com , and didn't see any reference to a solenoid. I fixed my GE fridge, its model is #TFX27FJB,,,,Free!!!! The replacement part would have cost 46.60.
On inside of freezer door, behind ice dispenser, there is a panel about 7x9
(plastic) that you can gently pull the tabs free and remove the panel. You will see the mechanical stuff. There are 2 gear like (pulleys) that are in the center area,supposed to be connected by a part that is about 3-5 inches long , like a small wire cable with hook type ends, think it's called "lanyard cable" , mine was broken, so I patched it with some scrap wire,,,one end hooked to one pulley and the other to other pulley(gear). When my ice door quit closing after getting ice,this cable had broken, What I did was find a small wire, to fix the break,, using as much of the original cable as possible, make sure that total length is same as original. Hook one end to one pulley and wrap it around it, it has to be wrapped a certain way, I can't remember counter-clock wise or vise-verso, till it will take up all slack, and just reach and hook to the other. I think it is a spring that opens door, and then the gears turn to close it, that is why it has to be wrapped with no slack.
It cost nothing and it works great now,, the repairclinic.com will show you specs so you can see what you are doing.
I didn't want my food to thaw, so I had a large piece of Styrofoam that I cut to fit in door jam, to keep food safe.
Good Luck
Hope this helps.
Barbara H.
Posted on Mar 20, 2009
Model tfh22prsbaa ice dispenser door not closing
This model fridge uses an solenoid to open and close the ice chute door. Most likely the solenoid valve is sowlen not allowing the door to close
Sep 01, 2011 | GE Refrigerators
The ice dispenser chute sticks open allowing warm air into the freezer. Once the chute sticks open, you have to reset it manually but sticking your hand into the ice chute in the door.
There is a solenoid that operates the door that could have stopped working. Can you hear it?
The hinge on the door could be broken or the bracket it goes in could be broken. You'll have to look to see what's wrong.
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Aug 15, 2009 | Refrigerators
GE Profile 26.6 cu. ft. side by side is frosting in the shoot
Oddly enough, the problem is with your ice dispenser. What happens is that the door at the bottom of the ice chute is probably not sealed. This is likely because there is a solenoid that is supposed to hold that door open when you push your cup against the dispenser arm, and THEN, close it again when you release. If the chute door is not sealed, warmer, moist air from outside the refridgerator will be canstantly drawn up the chute where the moisture will freeze as frost. Gradually, this frost builds up in the chute until there is no longer enough room foir the ice to fall. You can usually look up at the chute from outside and see that the door is not sealed. In my case, I left it unsealed because the door would not open to let the ice out. It took me about 3 months to figure out that this was causing my frost-clogging problem. The solution is to replace the solenoid that is supposed to open and close the chuite door. If you remove the despenser panel, you will see that this solenoid is probably all rusted up and not working. The following link will allow you to enter you model number and see a diagram of the offending area. http://www.pcappliancerepair.com/model-display.php
Jun 10, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
ICE DOOR WILL NOT LET ICE FALL DOWN CHUTE,
the ice door has a solenoid that opens and closes the ice door. since you were able to replae the door i assume you can take it apart pull it back apart and the crank the door attaches too is connected on 1 side to an electrical soleiod test if the plunger moves up and down freely. also look for heat deformation around the plastic as well. if it turns out the solenoid is bad i would also recomend replacing the the fountain boards as well. I dont think you can put to much tension on the spring..
Jan 30, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Ice maker chute icing up
The flap is probably not closing properly. Dispense some ice, then open the freezer door and look to see if the flap is still slightly open. If so, you will have to take the front cover off of the control panel and clean the muck off of the flap mechanism and also clean the solenoid. I have to do this about 2X year. Not a big job, but be careful.
Nov 13, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice dispenser flap/door will not close properly
I have a similar problem. The repair guy took a look at it and stated everything is working and did not order any solenoid or any other parts. After he left the problem returned where ice comes down the chute it tends to lodge and keep the door open. I am disagreement with the repair guy and am leaning toward the idea that the spring has lost tension and is just too weak to close with any authority. There is a video on how to replace the spring on youtube. This is what I will be doing next weekend and will try to return to post results.
Jun 10, 2008 | GE Monogram® ZISS420DMSS Side by Side...
Ice chute door does not open
the solenoid is right beside the ice chute door. there is an arm coming off he door to the side and the solenoid has a stirrup hooked to the arm. you have to remove the trim surrounding the dispenser area to access this stuff. you don't repair the solenoid you replace it. ca. 20 bucks for the part
Apr 25, 2008 | Maytag MFD2560HES Bottom Freezer French...
Ice chute door on maytag refrigerator
the door is opened by a solenoid. it is bad or it is not getting voltage due to bad control or wiring
Apr 24, 2008 | Maytag MFD2560HES Bottom Freezer French...
Shorted control board dispenser
Look and see if the door for the ice chute is closing all the way. This model is bad about that door breaking. If it doesn't shut properly then warm air getting in will cause this condensation. Will also cause ice in bucket to melt and water can leak onto these parts. If it isn't obviously hanging open then shine a flash light from the inside down the chute and see if any light comes thru to the outside. Maytag has a chute door kit that you can find on appliancepartspros.com. Their part # is AP3140440. Let me know if this helps or we need to go further.
Oct 09, 2007 | Refrigerators
GE Icemaker flap door won't open causes ice jam in chute
There is an electric solenoid that opens the door. If you look up inside the dispenser you can see the solenoid. Either the solenoid is bad or the dispenser module that puts power to it is out. You will need to remove dispenser front and check for voltage to solenoid. If you have power from module, replace solenoid, if no power, replace both parts. It is common for solenoid to short out and damage the module so that both must be replaced. If solenoid is shorted and you replace module, new part will fry.
Oct 02, 2007 | GE 17.2 cu. ft. Top Freezer Refrigerator...
Refrigerators Logo
892 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
