Question about GRACO INC Magnum Texfinish Tx 90 Interior Exterior Texture Sprayer Paint Stucco
I need a roto flex hose - GRACO INC Magnum Texfinish Tx 90 Interior Exterior Texture Sprayer Paint Stucco
How to attach pet tool adapter? Do I disconnect the flex hose (handle end)? If so, how?
Hi Sarah! The flex hose doesn't need to be removed to use the pet tool adapter. Just attach the pet tool to hose and begin vacuuming.
Jul 27, 2013 | Bissell Powergroom Pet Vacuum
How do I change the rear brake rotor on my 2006, Toyota Rav 4?
Take off the tire, remove the bolts that hold the brake caliper on. Use a coat hanger to keep the brake hose from stretching. Do not allow the caliper to hang from the hose without support. Grab the rotoe and slide it off the studs.
Apr 01, 2013 | 2006 Toyota RAV4
I need a instruction manual for a de longhi roto fryer
Hi there.
You can get Owner's Manual of your Roto Fryer at the Kitchen Appliances page of http://www.delonghi.com
Regards.
Feb 26, 2011 | DeLonghi Roto Fryer F2872 Deep Fryer
I need to purchase a new oil drainage hose
they have this replacement hose at this link for $4.95:
http://www.partstore.com/Model/De%27Longhi/DeLonghi/D882UX.aspx?SearchTerm=True
Nov 21, 2009 | DeLonghi D882UX Cool Touch Roto Deep Fryer
I was cutting 1/4" wall tile. On the 3rd or 4th cut my rotozip RZ5 quit working. There is power at the outlet. The machine was pretty warm. Is there a fuse or thermal reset or do I need to send it in foer...
I have had similar problems in the past using my Roto-Zip on jobs. You may want to check the internal brushes in the machine have not been clogged with the dust from the ceramic tiles. The unit may have simply overheated from the stress of cutting the tile. This will also affect the brushes in the Roto-Zip. A can of compressed air may help clear any dust built up around the brushes. If they brushes are caked with to much dust, you may have to take the unit appart and manually clean the brushes. But, be careful because the brushes are spring loaded. Hope this information is helpful.
Aug 17, 2009 | Bosch RotoZip RZ05-1100 RZ5 Base kit
Can't find a hosee kit for it.
call sears they should be able to get it.if ot call all-type vacuum and janitorial supply 314-275-8006
Apr 23, 2009 | Vacuums
Internal flex suction hose is leaking
The hose where it hooks to the motor unit usually splits there, if this what you are talking about, then you can replace the hose asm. Part # H-90001336
You can go to http://vacuumsuperstore.com/
and order it thru them, or call a local service shop.
$36.00 tableWorkaround2(1)
May 26, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Code for dryer vent connections
Yes, the semi-rigid metal flex tubing is recommended because it resists crushing, crimping, collapsing and heat. The old plastic flex hoses would collapse easily, develop more clogs, melt and rodents could chew through them easily. When installing a new flex hose, the SHORTER and STRAIGHTER you can keep the run, the better. The more bends you have, the greater possiblity you have of creating areas where lint can clog. I hope this helps you. Post back if you need further guidance.
Mar 31, 2008 | Dryers
GRACO INC Magnum Texfinish Tx 90 Interior Exterior Texture Sprayer Paint Stucco Logo
37 people viewed this question
Top GRACO INC Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a GRACO INC Air Tool and Compressor Expert? Answer questions, earn points and help others
