Question about GE Spacemaker JVM1640SJ Microwave Oven
Microwave on but does not heat
Made pop noise and no longer heats. is this repairable of more cost effective to buy a new one?
If it is less than 5 years old, it is probably worth it to fix it. Sounds like a magnetron. The part should be covered by GE
Posted on Mar 13, 2009
Cooking with metal probe not fully inserted into ham Frigidaaire Gallery Series Micro....noises occurred ...popping sound....and microwave shuts off....no visual evidence on buttons or surface ...can it be...
Unfortunately when the metal probe was inserted in the ham it caused the magnetron to arc to the probe causing it to short out, but usually the thermal fuse will open and shut the system down preventing damage. It usually takes 30 to 60 minutes for the fuse to reset and allow the microwave to run, try heating water! if you are lucky the oven is unharmed. But if there no change the magnetron will need to be replaced which probably would not be cost effective, cheaper to buy new unit.
Mar 07, 2011 | Frigidaire Microwave Ovens
Started flashing and making popping noises, but still heated ok. Then stopprdheating and just makes a loud buzzing noise
The magnetron is most likely the problem, it heats the food and is the heart of the of the microwave oven, if it was followed by unusual odor more noticeable when you open the door that would confirm it, but that is not always the case. The cost to repair would exceed the cost of a new one
Jan 19, 2011 | Thermador MBBS Microwave Oven
Went to use and everything works except it does not heat
No heat means that the magnetron circuit has failed. It is the part the generates the microwaves that heat the food. Magnetrons replacement cost are high, usually as much as a new oven so it is rarely cost effective to repair. Sorry.
Jan 08, 2011 | Whirlpool MH1140XM Microwave Oven
Sharpe model R-1480 not heating (it sounds a little louder)
A loud sort of "groaning" noise and no heat is the sign of a bad magnetron tube. The magnetron is the microwave source, and when they go bad it's usually time to replace the oven. Most microwave repairs, especially a magnetron replacement, should be left to professionals. There are lethal voltages under the cover, and the chance of microwave leakage if the repair isn't done properly. With the price of a replacement tube and labor for the repair, it's often doesn't cost much more (and sometimes even less!) to buy a new oven.
Sorry I can't give you a more positive answer, but thanks for using Fixya!
Oct 31, 2010 | Sharp R-1480 Microwave Oven
Microwave GE JES738 doesn't heat
Almost certainly the magnetron tube in your oven shorted and caused the light show and sound effects. This is the microwave source, and without the waves there's no heat. The tube is replaceable, but it's a costly parts. Add in repair labor, and you'd be better off replacing the oven. New ones are often cheaper than the parts alone today.
Apr 03, 2010 | GE JES738 Microwave Oven
Noisy and won't head up
That's usually a sign the magnetron tube (the microwave source) is no longer working. While the tube is replaceable, it's usually more economical to buy a new oven. New tubes can cost up to $100, plus the repair labor.
Mar 07, 2010 | Sharp R-520LW Microwave Oven
Microwave no longer heats, makes more noise than it did when it was heating. Microwave is a Maytag, model # MMV4205BAW. Thanks.
Sounds like the magnetron has failed. There are some high voltage circuits that feed the magnetron and you can potentially get hurt if you don't know what you are doing. Would recommend you have it serviced by a professional if you want it fixed, otherwise look for a new one since the cost of repair can come close to the price of a new microwave oven.
Nov 27, 2009 | Maytag Appliances Over-the-Range Microwave...
Whirlpool MH1160XSQ-1 microwave oven will not heat
all microwaves have a magenetron which produces the heat. if this is gone and it is not under warranty, it is not cost effective to repair. check you manual, most mag's have a 3 - 5 year warranty.
Nov 07, 2009 | Microwave Ovens
Stoped heating and had a smell like somthing electrical was burning? Fix it or buy a new one?
HI, normally, when you smell the burning electrical wires and board components, this will confirm a major capacitor malfunction. in this case, all electronic component will be fried or destroyed. these parts are the running diode,magnetron tube,cut-off fuse,noise filter and control board as well. all these parts will be costly to replaced, and it will be more cost effective to just cut your loss and purchase a new unit. the newer unit will be cheaper than the actual repair bill in this case.
Aug 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM 1443 - Unit makes a deeper noise and will not heat
Hello mrobinert,
The sound you may be hearing could be the filament transformer breaking down or the magnetron tube failing ..they will arc and eventually fail. If you aren't getting any microwave energy ( to heat material in the cooking compartment) then in all probability it is either the transformer, magnetron or high voltage capacitor.. None of which are something you want to repair yourself... My advice is that if the cost to repair exceeds teh cost to replace then just buy a replacement model. If yours is under 1 year old, then you may be able to negotiate and get a replacement from the store where you purchased it.. If it is older than a year, it's probably cost effective to just buy a new model.
Regards,
Rick
Nov 23, 2008 | GE Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
199 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
