Question about Garmin StreetPilot C330 GPS Receiver
Garmin died and will not turn on
I was traveling down the interstate and the Garmin just shut off...I made sure it was connected good and that the plug in for the charger worked...I plugged in the charge cable and tried to turn it on and got nothing...
  • Anonymous Mar 19, 2009
    Garmin Died.
    I bought a new dc cord for the car and it was fixed. My friend had the same Garmin and replaced the fuse in the cable to fix his.
  • 31 Answers
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Posted on Mar 30, 2009
While driving on the interstate, my 2011 Mustang GT suffered a complete electrical shut down. The car died and nothing electrical will work. Twelve hours later i still do not have any electrical powe
ck the back of your alternator , ck the wires , also the same for the starter sounds like a wire broke of or shorted out , look good you will find it or your alterantor went bad and will kill the battery for sure , ck that too,
Dec 15, 2014 | 2011 Ford Mustang GT
Vehicle dies while driving
is the check engine light on ?
Mar 13, 2014 | 2002 GMC Envoy
The car (2001 pontiac firebird 3.8L ) was running fine down the highway and all of at shut off.
You'll need to know if it is spark or fuel related to proceed.
Will it start using starting fluid ?
Jan 24, 2014 | 2001 Pontiac Firebird
I recently purchased a Garmin Nuvi 750 GPS. While
you can set the types of roads you want the unit to follow. Highways or otherwise.
Dec 27, 2009 | Garmin (010-00583-00) for nuvi 750/760/770
Describe your How can I set my garmin nuvi 350 to
If you have set it to fastest, as opposed to shortest, it should take you on interstates for the most part.
Oct 25, 2009 | Garmin Nuvi 350 Car GPS Receiver
Shuts off, won't charge battery
Mar 26, 2009 | Garmin StreetPilot C330 GPS Receiver
2 Garmins, BOTH shut off right after they are turned on
>>>>>Posted by judyferris82 on Mar 15, 2009 "My Garmin nuvi 650 stopped keeping a charge for more than 60 seconds. It is still connected to the car charger. Will a battery replacement fix this problem? I have had this unit for 2 years."
<<<<<REPLY: In your case, the battery seems to be getting weak. You must change it.
Mar 15, 2009 | Garmin StreetPilot C330 GPS Receiver
2004 dodge durango engine shuts off while driving
I had this happen to me before. My battery had went out and I had put another in (didn't buy a new one-- it was holiday). It did this exact thing to me. The scary part is once, it was on the interstate going about 75 mph... didn't die but all gauges went to nothing. It turned out that the battery I was using didn't have enough cold cranking amps and was pulling down the alternator too much so the computer shut it down. The one time it didn't... it was because the RPH's were too high. Try checking the battery and alternator... make sure you have the right battery and have an alternator shop test your alternator if the battery is good.
Nov 17, 2008 | 2004 Dodge Durango
Garmin Nuvi 350
Might be a good idea to look at your route preference settings. If you have accidentally told it that you're a nervous driver who wants to avoid Interstates at any cost, it will do all it can to honour that request.
A.
Oct 07, 2008 | Garmin Nuvi 350 Car GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
506 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
