Question about Vehicle Parts & Accessories
Super ka plus installation guide - Vehicle Parts & Accessories
  • Jose Manique Apr 22, 2013
    Hi i need the user manual ( in English ) of super ka plus radar detector
Tried to change the batteries in my thermostat, Chronotherm IV Plus, and it didn't work, I looked for other batteries, came back and when I tried to take the batteries out, they were super Hot!
the batteries that you installed were installed incorrectly and the super hot indicates that they were dead shorting from the incorrect installation
Nov 11, 2017 | Heating & Cooling
Installing a jensen ka 5
try http://www.jensenmobile.com/amplifiers/
Although I do not see the one you describe
Apr 05, 2013 | Jensen 100W x 4 Amplifier KA5 Car Audio...
Radar Detector Upgrade
Ka is actually a newer band and it was added after X band radar. Rarely are these units able to be upgraded. The exception is the Valentine which has some limited upgrade capabilities, but not sufficient to operate at a new frequency.
Jun 13, 2009 | Vehicle Parts & Accessories
Im tryin to replace the tape deck in my ford ka
Rather than cutting wires i'd advise you to buy a pc2-17-4 autoleads ford harness. you can get them in a shop such as halfords or on ebay for between £3.50 to £10. You can plug this directly into the car and straight into the radio you are installing provided it has a standard iso block on it. it means when you sell car you can reinstall the old radio and take new one with you. Plus no tedious wire cutting.
May 10, 2009 | Car Audio & Video
Ford ka window switches not working
Check for loose wiring connections behind the door panel on the offending side.
Nov 27, 2008 | 2007 Ford Edge SEL Plus
Driver
arer ap ka pas creative cam ka model no.pd1100 ka softwarie ha to moga sand kara mari id yea ha rafay_super@yahoo.com ok
Oct 19, 2008 | Creative Labs Creative Webcam
Panasonic DP 2500 J81-J82 paper jam
Check the sensor lever spring and cable on top of dual path guide (on top of fuser unit) also if the door stopper has been broken there is a good chance the door may be slightly deformed in which case a gentle adjustment may be reqd. check on the diverter solenoid there should be NO spring attached to the white guide. that is supposed to be removed when the adu option is fitted.
Mar 03, 2008 | Panasonic Workio DP-2500E Copier
Vehicle Parts & Accessories Logo
863 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
