Question about Panasonic 1000w Commercial Microwave Oven
Sharp commercial microwave fan won't shut
2 Suggested Answers
  • 6771 Answers
SOURCE: Microwave was run empty and now it won't run. Display works but no fan or microwave. What to do?
The magnetron does not fair well when running empty, the thermal fuse usually kicks in if a metal object was put in by mistake, but should be checked along with the door switches.
Posted on Jun 01, 2012
Vent blower won't stop
I had the same problem with the fan not wanting to shut off after the repair. Once I set the clock though I was able to push the button to shut the fan off. So try setting your clock first and see if that helps.
May 07, 2013 | GE Profile Spacemaker Over-the-Range...
Sharp microwave & convection & turn table on model R1874F won't work
That would be just a defective secondary interlock (bottom door switch) or its mount.
My help file on door switches is here.
The service manuals you need are here and here.
You can get other Sharp parts from Encompass here or you can call them toll-free at 866-779-5835.
Jan 07, 2013 | Microwave Ovens
Sharp R-1870F Microwave Won't turn on
Could be just a fuse but probably the diode pack or magnetron.
May 24, 2017 | Sharp R-1870 Convection/Microwave Oven
Won't shut off
The problem is in the keypad control board or the smart board, costly venture to rectify.
Sep 04, 2012 | Sharp Microwave Ovens
Sharp Convection Microwave won't heat and turntable won't turn.
I typically find it is not door hinge issues but door switch issues, especially with sharp. You may heve a little movenent in the door hinge and that is allowing the door hook to move up and down on the plunger for a door switch that is probably a bit melted due to bad connections. If you check the door switches and look for any browning around the terminals where the wires push onto the switch you will probably find an overheated connectoion. Replace the bad switch and run better wires and better termninals to the new switch and it will probably be fine.
Oct 09, 2017 | Sharp R-930AK Convection/Microwave Oven
Kenmore microwave fan won't shut off
The fan is required when the microwave is running, cools the magnetron. The problem may be in one of the interlock door switches, it is to complicated to go through the steps and the testing requirements, plus the alignment is critical.
Mar 22, 2012 | Microwave Ovens
Sharp microwave door won't open
Usually a mechanical issue with the door release assembly. Likely needs to come apart and parts be replaced. More often, it's cheaper to just replace the microwave as a whole
Oct 10, 2011 | Sharp Microwave Ovens
Sharp R-520KS - When the door is opened, the light and fan comes on and the carousel rotates. I don't know if microwaves are emitted. How can I stop the fan from coming on and the carousel from...
You can tell if microwaves are being emitted if you get warm standing in front of it (seriously). But I wouldn't recommend that unless you want to cook yourself.
First thing that comes to mind is the door interlocks are out of adjustment or bad. Home microwave ovens are not supposed to operate like that. Some commercial models start the fan right away and run it after the cooking cycle is completed but I've never heard of a consumer model that does that.
Find your closest servicer here and have them take a look.
Sep 04, 2011 | Sharp R-520KS Microwave Oven
Door won't open on my sharp r-420b microwave
That truly sucks. Microwave door laches are quite complex. A double safety mechanism is in use and the door actually locks shut. Safety, safety. We wouldn't want you to microwave your head.
If you are going to be opening the case, unplug it and let it fully discharge. The voltages in a microwave are out of control. Keep all screws (use tape) and fully reassemble when you are done. Every part of the machine is needs assembled to keep the microwaves inside.
Smile. It could have happened to all of the locks on your house -- simultaneously. Now that would really **** :o).
Jun 03, 2011 | Microwave Ovens
Amana OTR Convection Microwave runs 59 seconds and shuts off
This sounds like either a thermistor or a damper switch/motor problem.
Amana's technical support line is 866-426-2621. This is the commercial side but they should be able to get you in touch with the domestic side.
Sep 12, 2009 | Sharp R-1850A Convection/Microwave Oven
Panasonic 1000w Commercial Microwave Oven Logo
22 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
