Question about Smeg A2.2 Gas Kitchen Range
My ram double fitted oven blows the electric fuse every time i
Switch it on.i think it must be something to do with the earth,can someone help as i am not very technical.
  • 36 Answers
It sounds like you have a hot wire going to ground (earth) and your oven is protecting you as it should. Finding the problem will take a little know how and I would advise you to find a serviceman or friend with some electrical experience to check it out. Someone could try and talk you through it, but that would be an unsafe option.
Posted on Jan 04, 2010
Troubleshooting power issues for whirlpool accubake double oven
Nothing Works, or the Oven / Range / Stovetop Works Only At Certain Times:
1.Home breaker flipped or the fuse blown?Possibly an electrical surge has flipped the breaker. Check your breaker or fuse box and replace or reset as necessary.
2.Power cord plugged in?Grab the plug and wiggle to determine a good connection.
3.Power cord damage?Damaged rubber with wires showing through or the wire is being pinched can cause issues. Electrical tape is acceptable for covering damaged wires.
4.Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
5.Even a bad relay door switch will hinder your oven from operating.
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
Mar 02, 2015 | Whirlpool Ovens
Tripping fuse box
  • There is an earth fault. check that the oven is wired correctly at both the oven side and the outlet it is wired into. Failing that check that oven control switch is wired correctly.
Apr 07, 2014 | Baumatic AS15 Studio Solari Stainless...
Wiring up
  • If it is a single oven attaching a 13amp plug and connecting it to a socket is fine. If it is a double oven it needs to be connected to a dedicated cooker circuit from your fuse board via a cooker control switch with 6mm twin and earth cable.
Apr 02, 2014 | Ovens
No power after self cleaning
5.
6.Even a bad relay door switch will hinder your oven from operating.
Dec 14, 2013 | LG LWD3081ST Electric Double Oven
The grill on Zanussi FM9232 keeps blowing the main fuse
the grill element needs replaceing or you have a wire on the grill element thats come off and touching down to earth
Sep 07, 2011 | Zanussi ZHQ575 Electric Double Oven
My neff fan oven keeps blowing it element is there something wrong wit it? I have a double oven and its the bottom one that keeps blowing
It is quite common for neff elements to fail, make sure you have fitted the correct wattage element to it, as there are more than 1 element that will fit it.
Nov 12, 2010 | Neff U1721 Double circotherm Electric Oven
I tried to fix the wiring in an external light. Did the job, but with bad connections, put in bulb and switched on. Blew fuse and now the switch will not turn off and I am left with a live wire in front of...
Switch contacts fused together
In most external fittings there is a live coming from the switch a neutral going back to the lighting ring main and an earth wire for protection
You are not competant to be rewiring any house wiring , the statement about the earth wire proves that.
No earth is akin to jumping into a lake without a life preserver on
Get an electrician involved before you burn the house down
Dec 31, 2009 | Jenn-Air JJW7530DDS Electric Single Oven
Gaggenau EB 194 Double Oven fuse blowing
from your description, it seems the little fuse is overheating sometimes, a short is a short and an immidiate fuse blower. i would use a higher amperage fuse, 30 amps. any electronic tech can replace this, doesnt have to be your Gaggenau guy, as it seems to me hes made a regular income of this
Apr 17, 2009 | Gaggenau EB294/295 Electric Double Oven
Thermador oven sc302 no heat
On modern electronic control ranges, the oven temperature sensor
is the part that regulates the oven temperature. If it is not working properly it could be the reason why the range or oven won't start. This part can be found inside the oven on the rear wall near the top. Most modern ovens will display a fault code if the oven sensor is at fault. If you think the sensor may be the issue you can check the resistance with a multi-meter but will need to know the correct resistance of the sensor at room temperature. Remove power from the appliance before performing this test.
1.Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
2.
3.Even a bad relay door switch will hinder your oven from operating.
Mar 05, 2009 | Thermador C302U Electric Double Oven
Smeg A2.2 Gas Kitchen Range Logo
99 people viewed this question
Top Smeg Kitchen Ranges Experts
Richard Ballard
Richard Ballard
Level 1 Expert
Joseph Mueller
Joseph Mueller
ashburton
Are you a Smeg Kitchen Range Expert? Answer questions, earn points and help others
