Question about ASUS Computers & Internet
My bios can not detect usb configuration why? my usb ports can not be Used?
  • 516 Answers
If you already tried to clear the bios settings of your motherboard or change the bios settings but still the same. The best solution for you is to buy a pci (Peripheral Component Interconnect) card with usb port commonly with 4 usb ports. The pci card will install on your free pci slot on your motherboard and depends with your operating system if the card will plug and play or manually install using it's driver.
Posted on Jun 13, 2014
If the BIOS cannot detect any USB ports then this laptop cannot have an USB port as a boot device, because the firmware BIOS does not support this.
The USB port is useable only when Windows is up and running when the USB driver is operating.
Apr 22, 2013 | Computers & Internet
Usb ports not working
Go into the bios and check to make sure the usb ports are enabled if that is an option. Reboot the computer and notice the screen to see which key it says to hit to get into the Bios or System Setup. Hit the key and look through the bios for settings that affect the USB ports.
If you computer recognized the devices in the past it should recognize them now unless the drivers are messed up or missing, or the ports have gone bad.
If you are using usb devices that you have not used before on the computer then try one of your old usb devices that you have used before on the computer. It could be that the new usb devices are too advanced for the system. Some old systems for example can't read or detect a 1TB usb external drive.
If the usb device came with drivers, install the drivers.
May 04, 2012 | Toshiba Satellite L500 Series Notebook
My Dell Laptop USB ports are not working any more
Do they not work on any device? Have you tried using a device that they used to detect in the past? Maybe the device you are using is too advanced for the old D600. For example, I would imagine it would have a hard time detecting a 1TB external hard drive.
If it will not detect a device that used to work in the past I would go into the BIOS or System Setup and make sure the USB is enabled. When you turn the laptop on just watch the screen and it will tell you which key to hit to get into the Bios or System Setup. I think it is the F2 key for the D600.
Apr 30, 2012 | Dell Computers & Internet
Windows did'nt find any hard drive
Go to the BIOS configuration and see it the BIOS detects the hard drive. If it doesn,t detect the hard drive then the hard drive coulf be faulty.
Another way to check the hard drive. Remove the hard drive and connect it to an USB hard drive adapter and then connect this to a computer's USB port. If this computer does not detect it as and external storage device, then the hard drive is faulty.
To get your laptop operational again, insertl a new hard drive and install Windows on this hard drive, together with the laptop's device drivers and your programs.
Sep 21, 2010 | Computers & Internet
Please can you give steps to disable the onboard usb controllers to use the CPI USB Card. I've installed the PCI Card after the onboard stop working
2.4.2 USB Configuration
The items in this menu allows you to change the USB-related features.
Select an item then press <Enter> to display the configuration options
USB Function [Enabled]
Allows you to enable or disable the USB function.
Configuration options: [Disabled] [Enabled]
Legacy USB Support [Auto]
Allows you to enable or disable support for USB devices on legacy
operating systems (OS). Setting to Auto allows the system to detect the
presence of USB devices at startup. If detected, the USB controller legacy
mode is enabled. If no USB device is detected, the legacy USB support is
disabled. Configuration options: [Disabled] [Enabled] [Auto]
USB 2.0 Controller [Enabled]
Allows you to enable or disable the USB 2.0 controller.
USB 2.0 Controller Mode [HiSpeed]
Allows you to configure the USB 2.0 controller in HiSpeed (480 Mbps) or
Full Speed (12 Mbps). Configuration options: [HiSpeed] [Full Speed]
BIOS EHCI Hand-off [Disabled]
Allows you to enable support for operating systems without an EHCI
hand-off feature. Configuration options: [Enabled] [Disabled]
NOTE!!!
Do not disable the BIOS EHCI Hand-Off option if you are running a
Windows® operating system with USB device
hope above given details with give you a detailed description as you desired.
good luck
Feb 04, 2010 | ASUS P5LD2-VM Motherboard
Hard disk ST9120822AS ATA Device
If the computer cannot Bootup with an error message that hard drive nor detected or no boot device then you could have a faulty hard disk.
Go into the BIOS configuration and see if the BIOS detects the hard disk. If it is not detected then it is probably faulty.
Next reset the ATA data cable on the hard drive and at the motherboard. Bootup the computer again, also check the BIOS configuration again to see if it detects the hard drive.
If it still does not find the hard drive then remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If this computer does not detect it as an external hard drive then this proves the hard drive is faulty.
To get your computer working again, replace the hard drive and install Windows together with the device drivers and your programs.
Nov 06, 2009 | Dell InspironTM 1501 Notebook
Need front usb motherboard configuration
You dont need to configure any usb ports if the usb ports are enabled in BIOS all the usb ports will be activated automatically(front and rear). If still you want to check, go to BIOS and check if they are enabled.
Oct 04, 2009 | Computers & Internet
When i turn it on it has a disk read error occurred message
The Toshiba cannot find a boot disk, this problem could be caused by the BIOS could not detect the hard drive because has lost the configuration or the hard drive is faulty or the disk controller is faulty.
Check the BIOS configuration to see if it has detected the hard disk and some BIOS have a utility to test the hard disk, if this is available then run the hard disk test.
Another way to test the hard disk, remove the hard disk from the laptop and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If this computer see it as and external hard drive and you can open the folders and files the the hard drive is OK and the fault is most likely the laptop's motherboard.
If the computer cannot detect or open the files on the external USB adapter then the hard drive is faulty. The hard drive needs to be replaced in the Toshiba and Windows installed to get the laptop working again.
Aug 02, 2009 | Toshiba Computers & Internet
Usb port not recognising devices and mouse pad not responding
hello there. It sounds as if your motherboard (bios) is not configured correctly, or your windows drivers somehow got corrupted. check in your MoBo's manual to see how to access it's bios options. and make sure that your onboard usb options are enabled.
Nov 23, 2008 | Microsoft Computers & Internet
Mecer Laptop USB port not detecting
Reset the Bios.That solved the same problem i had.
Aug 30, 2008 | Computers & Internet
Computers & Internet Logo
41 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
