Question about Sewing Machines
Singer 6217 mechanical sewing machine
How to replace a bobbin case in a singer 6271
SOURCE: Bobbin Case
I'm having a similar problem today. I took out the bobbin case and when I went to put it back in, the whole system locks up. I've tired cleaning, changing needle taking the metal plate and piece that holds bobbin case out and put it all back in after cleaning. Nothing. My symptom is I can't get a complete stitch, the needle goes down, the whole deal acts like it will work and as soon as the arm of the bobbin case gets to 8 o' clock on the gears, It jams and won't hardly move. I cannot pull the bobbin case out easily after this. Perhaps there is someone out there that can help us!
Posted on Jun 23, 2008
SOURCE: singer futura model 900 sewing machine
Recently had same problem. Underneath the bobbin area on the bottom of the machine is a small white plastic piece that resembles a fan. Singer calls this the bobbin cam actuator. It is usually cracked along the sleeve that fits over the metal pin, bar? This is the mechanism that lifts the bobbin when it is wound. When its broken it can't lift the bobbin to be wound properly.
Posted on Sep 12, 2009
  • 6 Answers
SOURCE: The bobbin case on my Singer Inspiration 4210
unscrew the black plate that holds in the bobbin case and move it over to the left just a little bit, but make sure there is still clearance between the lower right corner of the case and the plate. The case should be able to wiggle a little, but not so loose it can pop out..
Posted on Mar 21, 2010
  • 18 Answers
SOURCE: How to replace the bobbin case in a singer sewing
If you go here and search for 9005, you can find a free downloadable instruction manual.
http://www.singerco.com/accessories/manuals.html
Posted on Jul 22, 2010
SOURCE: Singer 4562 t bobbin case won't fit properly, what am I doing wro
Make sure the bobbin case sets sort of on top and not under the ridge of the metal ring. There is a small latch on the upper left of the bobbin case. It is metal. rotate the latch to cover the bobbin case and this should stabilize the case without making it immobile
Posted on Aug 01, 2010
How to remove the bobbin case on singer 4411 sewing machine. Thread is accumulated under the bobbin case and the case is sin wrong position.
Hai, I think your machine time is changing. So you can't remove the bobbin case. Please go to mechanic shop. First time you look and see. Next time you can try.
Apr 01, 2014 | Singer 4411 Sewing Machine
Bobbin case for 7462 singer how do u put in the machine
Open Up The Door Below The sewing Foot. Lift Lever And Then Pull Out the Bobbing Case Replace Bobbing And Put Back Together
Feb 02, 2014 | Singer 7462 Mechanical Sewing Machine
Singer sewing machine needs a bobbin
Which machine do you have? Many Singer parts are still available, even for older machines. (I have a Touch & Sew 620 from the late 60s and can get parts for it from http://www.sewingpartsonline.com and other sites.)
What is your specific problem with the bobbin case? Is it the timing problem or damage to the bobbin case/hook mechanism? The parts list for most Singer machines can be gotten here: http://www.singerco.com/support/replacement-parts-chart .
Please add a comment with more details of your problem and the model of your machine.
Jan 03, 2013 | Sewing Machines
Singer 2263 needle hitting something in bobbin area (loud thunk) and needle moves
try taking the bobbin out and putting it back in the bobbin
case if it's a top loading bobbin
if it's a side or front loading bobbin make sure the bobbin case is
inserted correctly
if the bobbin and bobbin case are inserted correctly then
it sounds like the sewing machine could have a timing
problem and needs to be checked at a sewing machine shop
Nov 12, 2012 | Singer 2263 Mechanical Sewing Machine
Singer 4228 bobbin case
try youtube for a video,, type in singer 4228 bobbin case
Apr 27, 2012 | Singer Inspiration 4228 Mechanical Sewing...
The bobbin case on my singer 5050 keep popping up?
is this a top or front or side loading bobbin case?
Jan 16, 2012 | Singer 5050 Mechanical Sewing Machine
How do I replace the bobbin case in singer machine 7442. The manual diagram is minimal and I replace it incorrectly and just got it out after several attempts. Can't seem to get it aligned proper;u
When you insert the bobbin case, make sure the "knub" on the bobbin case (#1) is just to the left of the position finger bracket (#2). It should sit in there nicely and you should be able to spin the hand wheel freely.
Let me know if you need more help,
Chris
Jun 07, 2010 | Singer 7442 Mechanical Sewing Machine
Singer model 2732
It is either inserted incorrectly or the bobbin case needs replacing. Check the bobbin case by running finger tip around the outside of case, if rough spot needs replace. There is a ltch that is spring loaded you must hold back with small bladed screwdriver while inserting case for proper placement
Oct 25, 2007 | Singer 2732 Mechanical Sewing Machine
Sewing Machines Logo
22 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
