Question about Epson Stylus Photo R1800 InkJet Printer
Epson R1800 won't power up, tried everything.....spoke to an epson authorize technician, they said it cld be the board or the pupply supply inside. aby suggestions, can i do this myself?
  • gabb974 Mar 13, 2009
    Thanks...I did speak t a Epson service shop, they said it cld either be a power supply or the board.....if its the power supply, it won't be that much (around $100), if its the board then around $200...i am talking about Canadian dollars.
    Maybe I will just sell it as is....the problem is that I still have a lot of ink in it.
  • Anonymous Mar 28, 2009
    I have the exact same problem. I think it is the power cord as well and we have a **** load of ink too. Sucks!
  • Epson Master
  • 419 Answers
I appreciate this is not what you want to hear but unless your power cord has a fault, a fuse that's blown, etc... then it's likely that your printer has essentially died and gone to inkjet heaven.
It's likely that repair will need a service center and a high cost (unfortunately)...
Don't just throw it in the bin though... The parts are well worth something to enthusiasts and repair techs so if you decide to get rid of it, put it on ebay as spares & repair and get at least some of the money back.
Sorry to be the messenger on this one..
Posted on Mar 13, 2009
  • Martin Smallridge
    Martin Smallridge Mar 13, 2009
    For $200CAN I'd say get it serviced... a Brand new R1900 (the next generation up) would be considerably more and with all that ink you'd be losing a lot more.
    Just to check (as I didn't think to ask), I'm assuming you are not seeing any other lights or activity at all from the unit, (ie: any sound of movement, etc...)
Epson R1800 won't start up
Unplug the power cable from printer while the printer is powered on.
Press and hold OK and HELP buttons while plugging in the power cord.
Wait for the screen to go black or blank before releasing the keys.
Just turn on the printer and configure your printer new
If you need any technical help on printer then you can reach at here
Mar 06, 2013 | Epson Stylus Photo R1800 InkJet Printer
Replace main board epson r1800
I'm having the same problem. I was wondering if the Epson board was the same as the Anajet board or was there a difference.
Anajet board is $800 and a new Epson board is about $225.
I'm willing to gamble on the Epson. Dont really want to spend another $1K on parts.
Jun 23, 2012 | Epson Stylus Photo R1800 InkJet Printer
No power. We had power outages. Is there a fuse inside? thanks... Greg
Check that the Fuse F1 on the Power Supply Board has not blown.
jackpot00_106.jpg Download this service manual for Epson Stylus Photo R1800 ..>
http://www.resetters.ru/download/SM/R_1800_2400_B.pdf Go to page #206 .
Note:Note: Epson manuals are provided in .PDF format, which requires the free Adobe Acrobat Reader. If you wish to save the .PDF file to your computer for later use, right click over the link and choose "Save Link As" or "Save Target As.")
Jul 26, 2011 | Epson Stylus Photo R1800 InkJet Printer
R1800 Won't Power Up
Just check the power cord of your printer it maybe don't have any lost connection or change the power cord. If did not work also their was a problem of your powersupply. You need to bring it to the electronic center technician for the proper repair of the power supply.
May 26, 2010 | Epson Stylus Photo R1800 InkJet Printer
Epson R1800 Printer turns OFF
Here is my solution to your problem.
Power Failure is not reason here. I think you Epson have a problem inside the circuit board.
It has two output, the PRIMARY & SECONDARY Output, one of this are not function due to power or wattage failure.
I did encounter such problem but I open my printer and I see inside its nothing but the PCB Board have leak of one of my capacitor inside.
If this case is still comes out then better to check that with EPSON PRINTER Technician.
And about resetting EEPROM it useless.
At least this information give you such ideas why you have this kind of problem. Resolving such problem are not only on talk but let our hands do it also.
I tell you one way or another, careful of that maybe it has a short circuit. Good luck!
Aug 07, 2009 | Office Equipment & Supplies
Epson R1800 with magenta blinking ,and wont recognize the said ink
Hi-
Try reseating all the ink cartridge, make sure you have the right cartridge for each slot and make sure all are genuine epson in. try another magenta ink as well if you have a spare. if all fails call epson at 5622761300.
Hope this helps
Nov 08, 2008 | Epson Stylus Photo R1800 InkJet Printer
Rebuild Epson R1800?
You could run head cleaning from the driver a few times and see if the nozzles start to clear out. If you send it in for repair they run a solution through it that is supposed to clean it out. If the solution doesn't work the head is like a $400 part.
Oct 04, 2008 | Epson Stylus Photo R1800 InkJet Printer
Problem using sublimation inks
Since you are using sublmation ink, the cartridges are probably aftermarket and may not meet Epson standards. Aftermarket chipped cartridges are notorious for failing to 'communicate' with Epson printers, even when the cartridge is brand new. Before taking the printer to a service center, you might try purchasing new cartridges of your ink from your reseller. If that fixes the problem then your fight is with the ink reseller, not Epson. If it doesn't fix the problem and your printer is still under warranty, take it to an authorized service center, and remember, using non-Epson ink does NOT void the waranty.
Jun 16, 2008 | Epson Stylus Photo R1800 InkJet Printer
Broken Ink jet nozel on R1800
Compass Micro, Inc.
(503)408-8725 or (800)388-8595 Micrologic Systems, Inc. (903)561-0007 National Parts Depot (845)469-4800 or (800)524-8338 TSAworld, Inc. (770)417-2323 or (800)633-6626 Vance Baldwin Electronics (954)723-9191 or (800)432-8542
You can get replacement parts from any one of these.
or you can get it fixed at any Epson Authorized Servicer
http://pos.epson.com/service/SCR.htm
Nov 05, 2007 | Epson Stylus Photo R1800 InkJet Printer
Power supply
try www.theprinterworks.com or www.percisionroller.com and type in your type and model printer then search all parts
Oct 24, 2007 | Epson AcuLaser C900 Printer
Epson Stylus Photo R1800 InkJet Printer Logo
703 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
