Question about Acer Iconia TAB A200-10G16U 10.1 inch NVIDIA Tegra 2 1.0GHz/ 1GB/
Acer 200 sound distorted
Both speakers and head set
How to fix my acer aspire 5740G model lap top sound distortion, When it with Speaker connection its clear, Without speaker its more distorted, any one can give solution?
This is due to the internal speakers which might need replacing, it sounds better with external speakers because they are plugged into the headphone socket which shows the internal speakers are damaged, get them checked out.
Jun 08, 2014 | Acer Aspire Computers & Internet
I have jamo sub200. I connect to pioneer vsx-rs320k audo video receiver. when I turn the volume of subwoofer to a higher value with the receiver, the bass sound becomes distorted and not satifieng to...
hi,
Do one thing set the control behind the sub. set the level and cutoff control at it half position. Set phase control at "0" position. Then test the sound. if you ate using tower speaker as front speaker then you have to set the position of phase control 180 ,
ok
Apr 11, 2011 | Jamo SUB 200 Subwoofer
Putting Speakers in Door Dont Know how to wire them correctly
Wiring speakers with reverse polarity doesnt have adverse effects. It cant give distorted sound. Seems like the wiring from the head unit to the speaker might be at fault. For testing purposes, connect the speaker directly to the head unit, bypassing, the car wiring. If the sound comes out alright, you have to replace the car wiring. If it is still distorted, speaker might be at fault. Try with a different speaker.
Oct 20, 2009 | Pioneer TS-G1642R Car Speaker
Acer 5520 distorted sound
speaker is getting faulty change it
Jul 28, 2009 | Acer Aspire 5520-5156 Laptop
Acer aspire netbook sound distorted
need to bios update. its acer's well known  problem. you should go to service  they will do it under warranty
May 28, 2009 | Acer Aspire 5720 Notebook
Distortion on speakers from CDX-M630
sounds like you have a faulty head unit
Sorry
Mark
www.blueice-electronics.co.uk
Nov 23, 2008 | Sony CDX-M630 CD Player
High distortion
The head unit may be rated at 200 watts but it cannot produce more than ~20 watts of real power per channel. There's no way that it can drive the high end speakers to a level that will be needed to compete with the subs on a 1000 watt amplifier.
Apr 18, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Distorted and crackling sounds
please check sound using external speaker.
if the result is same as using internal speaker, it's mean your mainboard may have problem, but try to install sound driver first.
if the result is different, you may have some loose screews inside your laptop and it stuck on internal speaker.
if you still have warranty, send it to acer.
Apr 12, 2008 | Acer Aspire 5610-4648 Notebook
Brand New Speakers Distorted and not right...
Are you still using the same head unit? You could try to run a short set of new wire to one of the speakers directly from the unit. Had you previously used these speakers in another vehicle...what I'm getting at is that you need to isolate the problem. If the speakers test fine in another vehicle, I would think there is something wrong with the existing head unit
Dec 31, 2007 | Pioneer TS-A1057 Coaxial Car Speaker
Acer Iconia TAB A200-10G16U 10.1 inch NVIDIA Tegra 2 1.0GHz/ 1GB/ Logo
49 people viewed this question
Top Acer Audio Players & Recorders Experts
NOEL
NOEL
Are you an Acer Audio Player and Recorder Expert? Answer questions, earn points and help others
