Question about SanDisk Sansa m240 MP3 Player
My Sansa m240 freezes at the title screen.
When I turn it on it freezes up on the title screen that says "Sansa m240 1.0GB". When it is connected to my computer it freezes at the title screen aswell and is not detected by my computor. It is completely non-responsive.
Take it back its to simple i did it
Posted on May 26, 2008
I have the same problem. I called tech support 1-866-726-3475 and they talked me thru several cures. None of which worked. My unit is about 8 months old. After trying all the options, they gave me a rma number and are sending me a replacement. I think they have had some trouble with this lot of players, they were very nice and it took no prodding from me for a replacement! Good Luck1
Posted on Aug 13, 2007
Rearrange songs on the SanDisk
Creating Playlists on the Sansa M240
The Sansa M240 is a decent device, but if you are like many, you have not been able to create playlists. The instructions with the player and the maker’s website offer little help. Here a solution that I found on-line with some additional detail. The step by step instructions for even those with little computer savvy.
1. power up your M240 player without connecting to your computer. Scroll thru the menu to the “settings” menu. Select “USB”, deselect “auto detect” then select “MSC”. (I don’t know if this step is critical, but I picked up this suggestion from another site)
2. Power down the MP240 and using the cable supplied with your player, connect to the USB port of your computer. The display will show “MSC” when connected.
3. If you have not already done so, download the songs you want to include on your playlist from your computer to the M240. Any number of media player software packages will allow you to copy or burn your songs to a “portable media device” for this step.
4. After your songs are downloaded, on your computer, go to “My Computer” and open the "Sansa M240" icon. On the explorer task bar, select “view”> “details”. You should see several standard folders and all your songs. (Note I have used this for both .wma and .mp3 formats and have intermixed them in the playlist)
5. On your computer, open a new Notepad document and save it to your desktop.
Name it whatever you like, but it has to have “.m3u” as a file extension when you save it.
For example I named mine…. playlist1.m3u, playlist2.m3u, playlist3.m3u.
6. Next, in this newly saved notepad document, type this exactly on the very first line < #EXTM3U > without the brackets.
7. Now, find your first song in the open M240 folder, place your cursor on it, right click and select "rename". When the song title is highlighted hit control + C or "Copy" the entire title, being careful not to change anything. Now place your cursor immediately after the #EXTM3U text, hit return and paste the title of your first song directly below it with NO line space in between.
8. Repeat the steps to copy the title of your next song from the M240 folder. When copied, place your cursor immediately after the previous song title copied in the step above. Hit return Twice to create a single line space after the song title and paste in the next song title at the beginning of the line. Repeat this process til you have built your playlist.
8. After you’ve entered your last song title, it should look something like this. (Either .mp3 or .wma extensions can be used)
#EXTM3U
First song.mp3
Second song.mp3
Third song.mp3
And so on.mp3
Now, within your notepad playlist document, click File/Save (noting where it was saved) and close the file. Now, find that same original playlist on your computer. Highlight it and copy / paste it onto your M240. I copied mine into a folder called “playlist” on the M240. Then I repeated the process for other playlists, giving each a unique name.
After allowing sufficient time for the file to copy, use the icon in the lower taskbar of your computer to “safely disconnect hardware” to unplug your player. Disconnect the USB cord, power up and your ready to enjoy your playlists.
Jan 28, 2008 | SanDisk Sansa m240 MP3 Player
Screen frozen when powered on
turn it off, take out the battery, then replace it, turn it back on. see if this helps.
Mar 15, 2008 | SanDisk Sansa m240 MP3 Player
My Sansa m240 does not play music, it freezes.
Try going into your USB Settings on your device and ensure the unit is set to msc
Jan 09, 2008 | SanDisk Sansa m240 MP3 Player
Playlist
You have to create the playlist on your computer. Here is a tutorial on using Windows Media Player (version 10). http://mp3support.sandisk.com/wmp10/wmp10playlist.wmv Best of Luck.
Sep 10, 2007 | SanDisk Sansa m240 MP3 Player
Problem with my MP3 player...
I am having the same issue. I loaded my M240 with music, then umpluged it from the USB cable. It didn't do the "building library" thing like it always does, and now when i turn it on it just loops from the "Sandisk" startup screen to the "Sansa initiallizing" screen. The same as you, when i connect it to the pc it isn't even recongnized and the player loops the "initiallizing" screen again. I put a request in to Sandisk last night, so i might have a solution for us later today.
Jun 15, 2007 | SanDisk Sansa m240 MP3 Player
Reset button
This is a well know fault with the m240. The easiest fix is to take it back to the store you bought it from and get a replacement :)
Jun 12, 2007 | SanDisk Sansa m240 MP3 Player
How do you setup Playlists? - pls help
if you hold down the menue for like 15 secends it will ask to add to favorites you cant put in playlists I dont think. ~Grim
May 11, 2007 | SanDisk Sansa m240 MP3 Player
Mp3
Jan 21, 07 I called and spoke with a Sandisk rep on Jan 16 about the "Sansa m240 startup screen" freeze-up problem that so many are experiencing. He said a bad batch was sent out in early December and on those m240''s there is "NO POSSIBLE FIX" for that problem, but no plans for a recall. He said he could not discuss what the problem was, but I guess it would be a hardware issue, since a firmware issue could easily be resolved. He said anyone with this problem is requested to call Sandisk and get a MRA number, then return the m240 to Sandisk for a replacement. If you have one that''s frozen on the Sansa m240 startup screen (all other freeze-ups can probably be corrected) take it back to your place of purchase or call Sandisk immediately. <>
May 04, 2007 | SanDisk Sansa m240 MP3 Player
How do i put a playlist on a sansa m240
#EXTM3U
First song.mp3
Second song.mp3
Third song.mp3
And so on.mp3
Mar 11, 2007 | SanDisk Sansa m240 MP3 Player
My sansa M240 WonT turn on all the way
Jan 21, 07 I called and spoke with a Sandisk rep on Jan 16 about the "Sansa m240 startup screen" freeze-up problem that so many are experiencing. He said a bad batch was sent out in early December and on those m240's there is "NO POSSIBLE FIX" for that problem, but no plans for a recall. He said he could not discuss what the problem was, but I guess it would be a hardware issue, since a firmware issue could easily be resolved. He said anyone with this problem is requested to call Sandisk and get a MRA number, then return the m240 to Sandisk for a replacement. If you have one that's frozen on the Sansa m240 startup screen (all other freeze-ups can probably be corrected) take it back to your place of purchase or call Sandisk immediately.
Dec 27, 2006 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa m240 MP3 Player Logo
109 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
