Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Need a wiring diagram for a model # 2680
I need know how to bypass all safety shut off switches on this mower.
(dead man) switch in seat has already been bypassed. There is a switch on the brake pedal that is malfuctioning and causes the mower to shut off when you remove pressure from the pedal.
I want to bypass all of these switches if possible
    Problem Solver:
  • 11 Answers
Hello
tobypass the switch simply remove the wires usually 2 and just connct together this should do it
hope this helps
Posted on Mar 15, 2009
Engine starts fine. When you try to go forward by pulling in the levers from neutral position, the engine goes dead. Seems like it is a safety switch? RZ5424
Sounds like the safety switch in the seat has went bad and doesnt think your in the seat. Someday they will be forced to be responsible how they use the safety switches on mowers. A cluster of led lights to tell us which switch is not happy would be the answer. Some of the switches are closed when in the seat and some are opened. Start with lifting the seat, switch should be in the center on bottom side and unplug the switch and try it, then if that dont work put a paper clip in the two spade holes on the wires that pushed over the seat safety switch so they are connected to each other.One way or the other it will bypass the switch and know you are in the seat.
Mar 23, 2016 | Garden
I need a wiring diagram, mainly from ignition switch to coil/stator.
pull the black ground wire off from the coil,try to start the motor,if it starts,put the wire back to shut it off,,,one or all of your safety switches is bad,you can bypass all the safety switches(as long as you dont care),by putting a switch connected to the coil and the other side,a ground,if you want safety switches then you have 3 to choose from to replace,2 stop the mower from starting and the 3rd stops it from running if it did start,here is a 42 inch,pretty much the same,you didnt tell me what model or make, http://www.ereplacementparts.com/craftsman-917279841-riding-mower-parts-c-158286_174089_460323.html
May 05, 2015 | Garden
Replaced battery and will not make a sound
Troubleshoot as follows: 1. Using a set of jumper cables connect the Black side of the jumper cable between to the (-) of battery and a the block of the engine. Connect one (red) end of the jumper cable to the (+) of battery...And just touch the other end of the red cable to where to mower battery cable touches the starter. *Only tap it and starter should turn over. This bypasses all switches and wiring. If it does not turn the starter, the starter is likely bad. If it does turn over, check the starter solenoid, seat safety switch, blade engagement safety switch, clutch brake switch, or wiring in between those components. A wiring diagram would be most helpful. It came with the mower, or can be found online...likely at a sears/craftsman web site, but sometimes also at parts retailer website too. Similar bypass method can be used for troubleshooting. DO NOT OPERATE WITH BYPASSED SAFETY SWITCHES, ETC. Bypassing is for troubleshooting only.
Nov 23, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
L130 mower shuts down when getting off seat with parking break set and PTO disengaged. I know it's safety lock circuit problem, but I don't know how it's wired
you can bypass the seat switch and see if the switch itself is bad, I do not know on a JD but on a Cub Cadet the RMC controls the safety switches, which is a small black box with a connect plugged into it. Hope this helped Tim
May 21, 2011 | John Deere 22HP VTwin 48" Riding Mower
Okay, I have a Ariens, Sport Zoom, Zero Turn, 12 HP mower. The battery was dead. It has a built in kill switch for safety. If there is no weight on the seat the engine shuts down.The battery is located...
Hi Tina, yes you can do as you asked and this will bypass the seat switch. No there is no need to disconnect the battery as the wires are not live unless the mower is running. Regards Phil.
Apr 21, 2011 | Briggs & Stratton Garden
Need the wire diagram to rewire my Ariens lawnmover to bypass the safety switch. It is Ariens GT-19 model # 931026 Serial # 001463. Can you help? It is an old Ariens mower but still runs good but now I...
here is owner manual:
http://apache.ariens.com/manuals/030305C.pdf
usually the switch is behind the ignition, sometimes at the N position of gearshift, just look for a switch with one wire coming in & one going out (usually the same color); disconnect the two wires & jumper them together to bypass the switch. Looks like yours has one under the seat.
Apr 25, 2017 | Sport & Outdoor - Others
I RAN OUT OF GAS WITH A HUSQAVARNA RIDING MOWER AND PUSHED IT WITHOUT RELEASING THE BRAKE IN THE BACK OF THE MOWER, REFILLED WITH GAS AND NOW EVERTIME I RELEASE THE CLUTCH THE ENGINE DIES, ANY SUGGESTIONS?
Hello:
From your Description it Sounds like the Seat Safety Swithc has a Bad Connection or Requires Replacing. The Safety System is Registering No Pressure on the Seat when the Clutch is being Engaged.
>>The Following is the Instruction File for Checking the Seat Safety Switch.
>>***PLEASE REMEMBER THAT THE INSTRUCTIONS FOR CHECKING THE SAFETY SWITCHES IS JUST THAT!!! FOR CHECKING ONLY.***
>>I NEVER Suggest a Mower be Operated with a Safety Device or Switch Disconnected or Bypassed. **Make Sure the Switch has a Good Connection. Now; On Some Model Mowers you can Simply Unplug the Safety Switch from the Harness. On Other Models you have to Place a Jumper Wire Between the Harness Terminals (on the 4 Post Switch Jumper from Same Color Wire to Same Color Wire). The Seat Safety is Showing No One is Seating in the Seat when the Clutch or Blades are Engaged.**
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 15, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Ariens lawn mower 1332 dies when put in gear
Hello
From your Description it Sounds like a Bad Saet Safety Switch.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Good Luck
Respectfully
jbridger (John)
May 10, 2009 | Ariens Garden
Craftsman Lawn Tractor - Electrical
make sure you mower deck is not still engaged. that might make it not start with that safety switch.
Oct 04, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
696 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
