Question about Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System
Jacuzzi keeps going to half full of water
By evening time our jacuzzi is only half full of water it is fine when the pool pump is on which is between 8am and 12pm but then by the next morning before pump switches on is only half full, once pump switches on it fills up very quickly?
  • 21 Answers
Replace the spa bypass check valve
Posted on Oct 03, 2009
  • 27 Answers
This is nothing to be concerned about, manually shut off the pump and watch for water leaking somewhere and fix
Posted on Jul 20, 2009
How to adjust air flow on jacuzzi vectra II
Yes you can, there should be air induction knobs: Adjusts air flow from off to maximum.
Turn it down.
It looks like this...
Jun 15, 2014 | Jacuzzi Pool & Spa
Pool pump running low psi
your pump should be just fine once the water starts flowing again. You may have run it too long without enough water to cool the seal.
If it is leaking water between the Jacuzzi Pump housing and the motor then you will need a new pump seal. Those are common pool parts.
Rod
US Parts Center
888-521-6183
Jun 09, 2012 | Jacuzzi Magnum Force Series Pool Pump 1...
We have a hot tub or jacuzzi inside or on the side of our pool. We had a new heater installed. The jacuzzi should heat up very quickly but now the pool tech claims the drain from the jacuzzi is blocked,...
Is the equipment to heat and filter the hot tub separate from the pool equipment or do both bodies of water share a common heater and filter pump? In most cases they share a pump and heater with valves that direct the flow of water depending on how the pool owner wants to use the pools.
The first thing you need to determine then is if the equipment is working properly. Is there flow of water to and from the spa? If so, is the heater burner kicking on? If it is running, is it running properly with sufficient gas pressure, 3-4" tall bright blue flames and stays on continuously during the heating cycle for the spa?
What is 'very quickly' for the time to heat the water? In other words, if everything appears to be operating normally but the water is not warming fast enough or at all how much time is elapsing before deciding the heater is not working?
How old is this equipment and how much experience do you have with this pool tech or the company they are from?
Nov 07, 2010 | Jacuzzi Pool & Spa
I've got no water coming thru the side jets in my pool, even though water is pouring through the jacuzzi jets. The jacuzzi is all part of the pool.
This is an ether or situation. Most systems now are set up with three way valves and if you turn the jets on you will shut the pool returns down. If you turn the pool back on you will shut the spa jets off.
Sep 27, 2010 | AO Smith 1 hp Swimming Pool - Jet / Well...
Which valve do I use on the Jacuzzi Magnum 1500 to drain lines
There two plugs on your pump, one one the side of the pot at the bottom and one dead center of the pump housing on the front. this will only drain your pump if you live in cold country and are winterizing you will need to drain all your equiptment filter, heater and any thing else. then you need to drain your pipes and seal them at poolside to keep the water out.
Sep 26, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
My jacuzzi pool pump cracked so I need to replace it. Jacuzzi is no longer making parts, so what would be a good brand where I could still use the same pipes, filter, etc.?
here's a site where I found tons of jacuzzi parts and accessories.
http://calwesthot1.reachlocal.net/AdvancedSearch.aspx
under select catagory scroll about half way down to jacuzzi pumps and hit search.
If you find what you need can I borrow the jacuzzi .. lol
Jul 31, 2009 | Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM...
Jacuzzi - GFCI keep tripping prventing Jacuzzi from starting Jacuzzi Whirlpool Bath, model H240000
i have the same model after unplugging everything one by one i got the breaker to stay on with the transformer unplugged. ordered new transformer installed works great!!
Mar 28, 2009 | Jacuzzi ALADDIN GO-KIT14 JACUZZI MAGNUM...
One out of 5 jacuzzi outlet works with force, the other do not even when the air flow is totally open.
try turning off the 5 previous jets in order to see if there is enough water flow to get to the last jet.
Feb 17, 2009 | Jacuzzi Cyget In Ground Pool Pumps
Pump won't shut off
You need a new impeller kit. Does any one know where to find one?
Jan 21, 2009 | Jacuzzi ALADDIN GO-KIT14 JACUZZI MAGNUM...
Scheduled maintenance
Jacuzzi pumps are very reliable. If you keep the debris out of it, you should be fine. It will let you know when it needs help... a squealing bearing immediately comes to mind.
Nov 25, 2008 | Jacuzzi Pool & Spa
Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System Logo
247 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
