Forced air heater lites but blower run a few minutes and shuts down. Service board blinks seven times. don't have manual
  • Norman Moore Mar 12, 2009
    I Have A Coleman Evcon Forced Air Natural Gas Heater. About 5 Yrs Old The gas lites the blower comes on and then shuts down in a few minutes. Board Blinks seven times
  • 716 Answers
Watch The Unit's Ignition Process See If The Unit Is Getting Fire Most Likely It Needs A New Thermostat. The Thermostat If Bad Will Cause The Unit To Turn On Ignite But Will Not Detect The Heat From The Flame And Then Shut Off The Gas To Protect The Home From Carbon Dioxide.
If The Unit Fails To Light At All Check The Igniter.
I Hope This Helps,
Sincerely,
Michael Scott
Posted on Mar 12, 2009
    Brigadier General:
  • 8,619 Answers
Hi!
Please tell me the make and model number to provide you the solution.
  • Rylee Smith
    Rylee Smith Mar 12, 2009
    Bkinking light 7 times means "Lockout Caused By No Ignition". And if this fault is false then it will reset itself automatically after one hour, when the heater is turned off.
    Please check for Defective Solenoids. They are on top or inside the body of the gas valve body. Solenoids also supply voltage to a glow coil {if applicable}gas to the pilot flame {if applicable} main burner gas and or other parts and componets of the entire electrical loop.
    Also, check theFlame Sensor. It is located on the burner or near the pilot assembly. If it's defective, it will cause the glow coil to not function. You can test this part with a continuity tester/multimeter.
    Try cleaning the flame sensor element and check the range.
    Please ask for any clarifications.
    Thanks
    Rylee
  • 412 Answers
Clean the Air Filter....
switch off the ac for a hr...
  • 6,784 Answers
Hi, the control panel has some issues. the board is damaged. you will need to purchase a replacement board. there are resistor issues as well.
Rinnai energysaver 556 blinking
Hi jmsocr2315,
If my description of what your heater is doing please read through to the end.
The heater is turned on and a room temperature is selected.
You can hear the noise of a small fan start, which shortly after the heater starts.
After a short period of time the heater stops and the red led begins to flash and shuts itself down.
This type of heater has a balanced flue, which means it draws air in one pipe and exhausts it out another.
Have the balanced flue checked for blockages, the problem will most likely be in the flue pipe which draws the outside cool air into the heater and not the flue pipe which blows out the hot air.
it may be full of cob webs or something else which restricts the air flow to the heater.
A service person can perform a quick test to prove the above theory. At the rear of the heater there are two pipes, one is an insulated metal pipe and the other is plastic pipe.
Disconnect the plastic pipe from the flue box and restart the heater.
If the heater runs normally this will confirm that there is a blockage.
Feb 05, 2014 | Rinnai EnergySaver 556 Air Conditioner
Ac unit runs, inside blower shuts off after 2 mins, compressor continues to run, t-stat still calling for cool
My central AC unit decided to stop on the hottest day of the year. It would start and run normally for a few minutes and then the blower would shut off. After checking the breakers, thermostat and overflow shut off (did not have one) I saw something about a blower motor capacitor. This was easy to get to and replace and my last hope before waiting for someone to come fix it. The capacitor cost $4.04 with tax and had my AC working again. Needless to say I was beyond happy. I hope this can help others with a similar problem.
May 20, 2012 | Heating & Cooling
The furnace kicks on then shuts off within a few minutes but the blower is still running. the light blinks 4 times and the code thing says it is a high limit valve open/ What and where is that/
Check your air filter, make sure all ducts are wide open and no restrictions for both hot air registers and cold air returns. Make sure room air blower is operating. You may want to inspect the exhaust pipe to make sure it has no restrictions as well.
Jan 10, 2011 | Heating & Cooling
Board in furnace is blinking seven times and only runs for a few secondsand then shuts off
Hi, remove the panel where the led is blinking, and you will find a chart glued to the panel, or there somewhere. It will tell you according to how many times it blinks what is going on. It may say that 7 times is a reset on a roll out switch you can reset. It may be many things, but will pretty much tell you what is wrong, and 9 out of 10 times you can fix it. Check it out and let me know.
Shastalaker7
A/C, Heating Contractor
Please rate me on this :))
Nov 23, 2010 | Heating & Cooling
Blower keeps running even after thermostat is in off or in auto? The forced air unit stays on even after temp setting is reached or will switch thermostat switch to off. The heat stops but blower stays...
This could be an indication that there is an error code flashing on the control board and needs to be addressed. Most newer units like this indicate a problem by running the room air blower to alert the homeowner something is wrong. Really! Without shutting off the power to the unit, look for a small viewing port that looks into the cabinet. You should see a blinking light that will blink a number of times, pause then blink another number of times. Once you get this number, say 3-4, look at the wiring diagram pasted on one of the door panels for a diagnostic chart. It will give you a starting point where to look for the problem. If you have one. Or you could have a bad control board or shorted wire. Make sure the air filter is clean since you will be in front of the unit, you would not believe how many times I have to charge $100 to replace a filter the home owner could have done for less than $20.
Mar 11, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
My heater is not working. When the thermostat is placed in HEAT mode, it sounds like the blower is kicking on - but then it shuts down a minute later. I looked in the unit in the attic, and I can see that...
Yes. First go into the attic and look thru the the inspection hole in your furnace. It is a small hole with a glass cover you can look thru. Therer will be blinking light inside. The numrer of blinks tell you that what the problem is. Example three blinks means air switch open. Your problem could be ignitor,air switch or pikot. Get back to me asap and I will walk you thru this or call me. Rus
Dec 05, 2009 | Weather King 12AJA4801AH Air Conditioner
My Carrier 58WAV136 forced air heater's problem is as follows - Thermostat works fine, when desired temp is reached, the fan motor (blower) kicks on. Sometimes it stays blowing for a couple of seconds,...
There should be a code list inside the furnace panel access door. Find it and see what code 41 says, as I can't remember right off hand. Some of the possible causes could be air in gas line or low gas pressure. Could have blocked vent especialy if vented with plastic. Check for bird nest or dirt dobbers in vent. If vented with plastic could not have proper rise 1/4 per foot and have water trapped in pipe blocking vent. Is this a new problem or has this occured since installation?
Oct 07, 2009 | Carrier Heating & Cooling
Possible Contactor Issue
Sounds like a bad fan switch in your unit. That unit has a fan board in it that is time delay on and off. Turn the fan to the on position and let it run all the time. If it keeps temp and does not shut off it is the fan realy board. The board also controls the compressor. Check that first and then the tsat. Russ
Jul 24, 2009 | Carrier 38CKC042 Air Conditioner
Furnace runs OK, but blower runs again a few seconds later
Could be a defective thermostat in the plenum.
When a gas furnace shuts down the fan(blower) will run until the plenum cools to the safe range. Usually 1 and 1/2 minutes.
Intermittent operation is a defective thermostat or relay.
Mar 11, 2009 | Carrier Heating & Cooling
Blower starts ans stops
May be a short in the wiring or a bad control board.
Jul 07, 2008 | Goodman CLQ36AR49 Air Conditioner
Heating & Cooling Logo
107 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Cris Sparks
Cris Sparks
