Question about Okia (OKIA550WP4PS) Power Supply
Hello can you tell me if this problem concern the power supply
Hello i have a problem,power on the computer, the computer greenled on ,the hdd red light don't light,the monitor screen is black ,on the screen i see no video signal and the monitor goes in sleep mode
Check your VGA cables to make sure it's properly connected (if you haven't already). If that does not work, Take the CMOS battery out of your motherboard and leave it out for a minute, then put it back in. If that still doesn't work, make another post with more specific information about your system.
Posted on Mar 12, 2009
My transcend external hdd power unit is 5vdc .it has two usb one for power .i hv adapter that converts ac to 5vdc which is charger of my tablet.can i use it to power up hdd externally and connect another...
Without seeing the specs of the adapter it's hard to tell the voltage is correct but what you need to be concerned about is the amperage(mA) USB ports on computers only put out a max of 500mA per port the tablet charger could put out more than that.
Dec 04, 2013 | Computers & Internet
My computer burned 2 hdd
After i Read your Explaination,i really sure if the Problem is at your Computer POWER SUPPLY.
Change your Power Supply to Higher Watt.
i Recomended to you to Using SIMBADA Power Supply ATX.
and to Fix your HDD bad Sector,Try to use LLF (Low Level Format).
LLF will destroy all data and Partition.So after you Format using LLF,you need to make a New partition at your HDD.
LLF is Working for me to Fix Bad Sector in a So many times.
Jan 18, 2012 | Gigabyte Ga H55m D2h Desktop Motherboard...
Just had to reatach my fan back over the processor but i took the mother board out and my wires came off the mother board which where for the power switch and the reset button, can anyone tell me which...
Hello Sir, hi, the wires on your casing are usually labeled, like in the picture below: cyberdyers_0.jpg
the power led green wire goes to the power led + and the white goes to the - . Now the HDD + goes to the HDD + the red wire, power switch can be interchange, same as the reset switch.
Dec 01, 2010 | Computers & Internet
What is the red /white wire for that comes out the back ,marked H.H.D Led ? where does it go
actually the HDD led was nothing all about.. it will just support the hard disk to have power.. if you have a good power supply and you trust your power supply .. the hdd led is no use..
Oct 07, 2010 | LogiSys 5.25" Multifunction Panel with Fan...
Computer was working when the power turn off and power led turns red
IT seems that the power destroy your power supply, the question now when you try to turn your computer, do you hear anything? or it doesnot turn on at all. if this is the case, replace the power supply.
Thanks for using Fixya
Oct 07, 2009 | Intel Compaq Deskpro EN Pentium 3 1Ghz /...
Fantom hard drive Flashing LED - Unreadable
As for known problems, this sounds like a failure in one of the circuit boards, either the one on the hard drive or the USB conversion board. If it is off warranty, the simplest method to test this is to transfer the drive into a new enclosure which you should be able to do at any PC shop.
If the drive works in the new drive enclosure then you're good to go. If it doesn't then you will likely need to replace it and if there is important data on the drive enlist a pro to recover the data.
Try the swap and let me know how you make out, if the results are indicating the need for a pro then reply with your Country, State and City and I will point you to an appropriate pro near you.
Hope this helps FixYa,
Chris
Sep 08, 2009 | Fantom Titanium II (TFD500C16) 500 GB USB...
3 red lights and yellow power supply light
at the very least the main board is acting flaky with the 3 red lights flashing. Here is tutorial courtesy of LLAMA to show how to resolve that problem:
http://www.llamma.com/xbox360/repair/ring_of_light_x-clamp_fix.htm
As far as the yellow light on the power supply is concerned. Unhook it from the Xbox 360 and only plug it into a power outlet. If the light is yellow then the power supply is bad. If the light stays green then plug it into the xbox 360, if it tells yellow then, at that point you know that the main board is causing the yellow light on the power supply and that means the main board is bad.
Aug 03, 2009 | Microsoft Xbox 360 Console
DELL SX270 WILL NOT COME ON HAVE LITE INSIDE PC
the power supply is probably bad. It's really hard to tell without a little more information. When my power supply went bad on my computer. the hdd light would come on but nothing else and the computer would not even try to start.the power supply puts out several different voltages with both positive and negative outputs.
Aug 01, 2009 | Dell OptiPlex SX270 PC Desktop
When powering up my computer, I get a failure. Primary hard drive 1 not found Strike the F1 to continue F2 to run the set up utility. I think the power supply fan is not working. What do I do?
your system can not detect your primary hard disk which host the operating systems,so you check the data cable to the hard drive and the power supply to the hard drive for supply
Jul 19, 2008 | Computers & Internet
Power supply crow bar
Hi, if your computers manual tells you that you have a power supply fault you need to replace the power supply or take the computer to a repair shop and have them do it for you. Regards mistyman
Sep 22, 2007 | Compaq (176763001) 120-Watt Power Supply
Computers & Internet Logo
94 people viewed this question
Top Okia Computers & Internet Experts
David Payne
David Payne
Are you an Okia Computer and Internet Expert? Answer questions, earn points and help others
