Question about Xerox Phaser 7750DN Laser Printer
I have xerox phaser 7750 by mistake i bought 7760 yellow toner shall install it to 7750
  • Xerox Master
  • 32,281 Answers
Not yet, check with the supplier and ask if it is compatible with the 7750, if not then exchange the 7760 for a 7750 yellow toner cartridge. Once you open the cartridge the supplier will not exchange.
Posted on Apr 22, 2013
  • 18 Answers
SOURCE: Xerox phaser 7760 streaking
to fined out what the problem could be you need to open a word doc and sent a blank page to the printer. from this it will show where the problem is in the printer
if u still get streaking it couls be a faulty toner and it may not be the cyan toner either. i would give the fuser unit in the printer a check. if there marks on tthis unit i can cause this problem as well
Posted on Nov 23, 2007
  • 2072 Answers
SOURCE: Grainy image quality on my Phaser 7750
Try something, Send a job with 5 pages to it.
Shut the machine off as a page it halfway out of the exit area.. Open the machine and look at the jammed copies. Are they clear in the imaging unit areas but not upon exiting the machine?
If the image is clear around the drums and imaging unit, then the problem would be in the fuser. If the image is grainy and fuzzy in the image area, You could have a bad second BTR roller, the soft black roller on the left side door. One of the developer housings could be bad. You have to remove the imaging units and look in the opening with a flashlight to see if the developer housing brush is thick on the developer roll.
Could have a bad transfer belt or one of the color housings could be bad.
Less likely is a bad laser. But have you taken the wand that is on the front cover and cleaned the laser exposure slots?
Posted on May 15, 2009
  • 110 Answers
SOURCE: hi i got xerox phaser 7750 and i have error code
Cheap fix : reset the Developer Life Count in the Service
Tools menu. Hold down the back ARROW key with the "i" them with your other hand turn on the machine.
Expensive fix : What has happen is that the developers have come to the end of the life and once it gets to a certain page count it will print out no more until you have replace the developers. One thing xerox forgot to do is reset the engine control board too for this machine. So you might need a new engine cotrol board too.
Procedure
1. Replace the Developer
2. After the Developer has been replaced, reset the Developer Life Count in the Service
Tools menu.
NOTE: It is recommended that all the Developers and Beads be replaced at one time rather
than on sccessive visits.
Good luck.
Posted on Oct 29, 2009
  • 21 Answers
SOURCE: Print quality problems after installing imaging unit.
pon ese en el amarillo, si el fondo ahora es amarillo....
Posted on Dec 02, 2009
SOURCE: Xerox Phaser 6180MFP i have replaced toners
Supposedly the 6180MFP allows the user to select a non-genuine mode (select "Non-Xerox Toner" on the maintenance menu). This option is listed on page 9-18 of the User Guide, and I think it's the same as the Non-Genuine mode described on page 1-38 of the Service Manual. However, when I actually look for this option on my printer it doesn't appear to be present. Maybe Xerox removed it and didn't update the documentation? Anyone else know about this setting?
Posted on May 11, 2010
Why phaser 7760 toner cartridge not recognized
You will need to contact your local Xerox concessionaire for further information. It can be a faulty CRUM chip on the side of the toner cartridge (very un-likely) or if your machine is quite new then I've seen an NVM location needed to be updated. (slim possibility)
Xerox Concessionaire is the best course of action.
Good Luck.
Jul 02, 2014 | Xerox Phaser 7760/YDX Laser Printer
Tip
XEROX PHASER 7750 7760 FAN ERROR.
Hey guys this is a Xerox Phaser 7750 and 7760 fan error video tutorial.
In this video you will learn how to fix the error code 48 on the Xerox phaser 7750.
Also you will learn how to fix the error codes 010-391,010-392,010-398 that are related to the Xerox Phaser 7760.
This video shows how to remove covers.
All the wires that you need to disconnect from the machine to fix these errors.
There is also another video part two that shows you how to reinstall everything back
in it’s place. Step by step tutorial hope you enjoy.
http://www.youtube.com/watch?v=yMud-Md2xpc
on Dec 30, 2009 | Office Equipment & Supplies
Xerox phaser 7760 saying "black ATC sensor failure - code 009-380", i changed developer and xerox phaser 7760 saying "black ATC sensor failure - code 009-380", i changed developer and xerox phaser 776
When you have a sensor failure, you need to replace the black ATC sensor and recalibrate it. Another reason for sensor failure is you are not getting toner moved down to mix with the developer...the toner tube/auger spring could be clogged up or not functioning.
Also if you changed the developer housing when you changed the developer, you need to change the value to the new sensor # that comes with the housing.
Feb 16, 2014 | Xerox Phaser 7760DN Laser Printer
How do you reset toner counter on phaser 7750? Thanks
On the back of the 7750 toner there is a metal piece you can push in near the end that goes in to the machine first, this will tell the printer that the toner you put in has not been installed until now. I would not suggest doing this unless the toner is full and is using geniune xerox 7750 toner.. If you refill it with generic or non-7750 toner it can damage the machine and will void any warrenty you may have left on the machine.
If you switch machines with the 7750 toner the machine will not know how much toner is remaining in that toner. Xerox changed this method on the 7760 to use a toner chip to fix this.
Hope this helps, thanks
Apr 01, 2011 | Xerox Phaser 7750DN Laser Printer
I am looking for parts list for a XEROX Phaser 7760 we got a service manual but no parts list need to find feed rollers and one way bearings for # 4 &5 trays ASAP any one able to help
600K78460 Roll Kit (3 Rolls/Kit) but they are the same as a 7750
the bearings don't have no number on the 7760 service manuel.
but you can check this manuel for the 7750 they should be the same.
http://www.office.xerox.com/userdoc/P7750/7750_Web/partslist/index.html
Nov 05, 2009 | Xerox Phaser 7760DN Laser Printer
Put the old image unit back in, if it prints normaly then you might have bought a defective image unit.
Apr 16, 2009 | Xerox Phaser 7750GX Laser Printer
Toners
Staples, Office Depot, Best Buy
Jan 19, 2009 | Xerox Phaser 7750GX Laser Printer
Phaser 7750 Toner Levels
did you shake the toner really well first? sometimes this fixes on this machine.
Dec 13, 2007 | Office Equipment & Supplies
Nov 22, 2007 | Xerox Phaser 7700 Laser Printer
Xerox Phaser 7750DN Laser Printer Logo
142 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
